WSPR, nuevo modo de...
WSPR, nuevo modo del WSJT
#726  - 10 julio, 2008 11:56
Joe - K1JT no para y acaba de sacar otro nuevo modo, o mejor dicho, nuevo programa; WSPR
[img size=150] [/img]
To: QRSS Knights and Friends
Subject: New software for MEPT
Date: March 13, 2008
About two weeks ago Murray Greenman, ZL1BPU, wrote to me suggesting
that I consider adding a mode optimized for MEPT to my software
package WSJT. I expressed interest in the idea, and we exchanged a
few emails about possible specifications. Then I sat down and wrote
out some detailed specs, and finally got busy to write a bare-bones
program implementing the new mode.
I write now to let you know that an early release of the program is
ready for testing. The program's name is WSPR (pronounced "whisper",
which seems appropriate for estremely weak signals). The name of the
digital protocol implemented in WSPR is MEPT_JT, where the letters
stand for "Manned Experimental Propagation Tests, by K1JT".
At present WSPR is a stand-alone executable, independent of WSJT. It
is functional for both transmitting and receiving, but it has no
frills -- no graphics, no GUI, etc. It is executed from a Windows
command prompt. Like WSJT, WSPR uses a computer sound card to
generate audio tones to modulate an SSB transceiver operating on upper
sideband. In receive mode the sound card digitizes audio from the
transceiver. The program scans a 200 Hz passband (the "QRSS window")
looking for MEPT_JT signals, and decodes them. Basic operating
instructions for the initial release can be found in the file
WSPR_Instructions.TXT at
http://physics.princeton.edu/pulsar/K1JT/WSPR_Instructions.TXT , and
the program itself can be downloaded from
http://physics.princeton.edu/pulsar/K1JT/WSPR.EXE .
Basic specifications of the MEPT_JT mode are as follows:
1. Transmitted message: callsign + 4-character-locator + dBm
Example: "K1JT FN20 30"
2. Message length after lossless compression: 28 bits for callsign,
15 for locator, 7 for power level ==> 50 bits total.
3. Forward error correction (FEC): long-constraint convolutional
code, K=32, r=1/2.
4. Number of channel symbols: nsym = (50+K-1)*2 = 162.
5. Keying rate: 12000/8192 = 1.46 baud.
6. Modulation: continuous phase 4-FSK. Tone separation 1.46 Hz.
7. Synchronization: 162-bit pseudo-random sync vector.
8. Data structure: each channel symbol conveys one sync bit and one
data bit.
9. Duration of transmission: 162*8192/12000 = 110.6 s.
10. Transmissions start two seconds into an even UTC minute: i.e., at
hh:00:02, hh:02:02, ...
10. Occupied bandwidth: about 6 Hz
11. Minimum S/N for reception: around -27 dB on the WSJT scale (2500
Hz reference bandwidth).
You can run Argo, Spectran, or WSJT at the same time as WSPR, in
order to provide a waterfall spectral display.
In normal operation WSPR displays information every two minutes and
is silent otherwise. In transmit mode in prints a single line when a
new transmission starts. In receive mode the program looks for all
detectable MEPT_JT signals in a 200 Hz passband, decodes them, and
displays the results. If nothing is decoded, nothing will be printed.
In T/R mode the program alternates in a randomized way between
transmit and receive sequences.
Like JT65, MEPT_JT includes very efficient data compression and strong
forward error correction. Received messages are nearly always exactly
the same as the transmitted message, or else they are left blank.
Version 0.3 of MEPT_JT is functional -- and extremely sensitive -- but
the user interface is rather spartan. Suggestions for improvements
will be most welcome!
Please email all suggestions to k1jt at arrl dot net.
-- 73, Joe, K1JT
Más info;
EA1YE
#43450  - 10 julio, 2008 13:31
ESTUPENDO !!!.
Este Joe...
Muchas gracias por la información, Máximo.
Habrá que probarlo, ¿no?.
EA1YV
#43451  - 10 julio, 2008 14:38
Máximo, sirve cualquier tarjeta de sonido ?
#43477  - 11 julio, 2008 11:20
Agustín, que yo sepa si. No he leído nada que diga lo contrario.
73, Máximo - EA1DDO.
EA1YE
#43452  - 18 julio, 2008 01:04
Recien sacado del horno....... ya hay "WHISPER" en modo QSO.
EA3SD
#43987  - 18 julio, 2008 16:18
Hola a todos. disculpar mi ignorancia...., he probado el jt65a y jt6m y aun me aclaro algo. pero con este no. lo tengo instalado y recibo algunas señales como la de G4KLA, OY3JE, DH8SA, etc... pero no tengo claro como le contesto. o simplemente no se contesta y se pasa el reporte mediante la qsl directamente.?
Saludos y gracias.
Por cierto me transmite tambien y creo que transmite bien aunque se oye un tono soloamente.
73.s
EA1YE
#44013  - 18 julio, 2008 17:48
Hola EA3SD. Supongo que te refieres a WSPR. Efectivamente, no busques como contestar a las estaciones que van apareciendo.. Se trata de un protocolo en modor "balizas". Cada estación que se ajusta al protocolo automáticamente se convierte en una baliza, y puede seguir el rastro de las estaciones que le han recibido con su reporte en dbs (escala WSJT), y verificar la exactitud de la recepción de quienes te han recibido, comprobando que la potencia en dbm y tu locator han sido copiados bien.
He tenido reportes de -29 dbs y siempre lo clavan.
Del mismo modo, lo que tu estas recibiendo es reportado a la red para que se puedan ver reflejados todos los demás.
Como en el JT, es imprescindible que el reloj esté bien ajustado.
El sistema es muy util para ver hasta donde está el límite mínimo de potencia para ser escuchado.
Aquí el "premio" no se lo lleva la estación 9+40 "juer que señal me pones, tío". Todo lo contrario. El reto es ser reportado con 500mw, -si ya te oyen con 1w- a 6.000km, en la banda de 30mtrs, y con una vertical... por ejemplo. Y si no llegas, no hay problema. Puede que tú si estés reportando estaciones a 6.000 km con 200 mw... que no escuchas ni puedes ver...
A 6.000km o a 180km... que pueden darse saltos verticales casi imposibles.
En cuanto enredé con él, entendí que podría ser una maravilla incluso para 160mtrs. Pues bien, anoche habia reportes en 500khz con 2watios. Concretamente a 40km, -8db.
Ya has podido comprobar que la recepción va por tramos de dos minutos, dejando la tx en el segundo 110.
La señal del WSPR es de 6hz, y si te fijas bien hace como tres variaciones mínimas sobre el sonido central. Se ve bien en un waterfall, como el del mixwin. De modo que te está funcionando a la perfección en tx y rx.
El programa es muy suyo, y en ocasiones se puede tirar cuatro tramos (8 o 10 minutos) missing. Y de golpe te genera un listado.... Es normal. También he observado que se le va la pinza y le da por sacar varios tramos con un ruido de la leche sin que sea real y audible... y tal como viene se va y sigue funcionando normalmente. No hay que olvidar que es una versión experimental.
Una cosa más. Como en JT65, el alc que casi ni se mueva... Si la señal llega limpia y sin saturar, puedes recibir reportes de -32 db.
Saludos, Antonio.
EA3SD
#44014  - 18 julio, 2008 21:33
ok, Gracias por contestar.
Mas o menos me daba a entender con mi pobre ingles que se trataba de algo asi...
pero..... como se reportan a la red?? yo manualmente o el programa mediante la casilla upload spots?. ..
por lo demas voy recibiendo cosas que son increibles con un trozo de hilo en una planta baja en medio de barcelona ciudad. eso si, en 10138.6, no he probado en otras frecuencias. mi power minima es 5w.
Otra cosa .... esto de 20%, 25% y 33% que es?, veo que transmite solo en unos periodos de tiempo, pero no lo tengo muy claro.
Adios y espero pasar tu reporte pronto. jejeje.
saludos.
EA1YE
#43453  - 18 julio, 2008 23:06
Vas bien... Te tienes que dar de alta en:
http://wsprnet.org/drupal/
En Spot Database aparecen los reportes de las estaciones activas. Si tienes marcado el upload spots tal y como comentas, y esperas a que el sistema te detecte, (pueden pasar tres o cuatro periodos..) comenzarás a lanzar reportes de recepción. Solo nos falta la transmisión. Si marcas 20%, 25%.... le dices al sistema que automáticamente elija los periodos de tx en el porcentaje marcado. Y si quieres forzar a tx cuando tu quieras, marca TX y en cuanto comience a transmitir, marca RX. Cuando pase el periodo de 2 minutos, se queda listo para recibir.
Creo que no se me queda nada más...
A ver si nos vemos en wspr.
EA3SD
#44033  - 18 julio, 2008 23:34
Pues muchas gracias Antonio por las explicaciones.
Ya estoy dado de alta en wspr spot data base y me veo reflejado en algun spot. o sea que tx bien y rx bien tambien.
Muchas gracias por la ayuda.
73.s
EA1NX
#43454  - 18 julio, 2008 23:59
Hola a todos:
Ya me instalé el programa y he empezado a recibir.
Interesante ver lo que se puede escuchar con 5 w o menos (je, je, eso si nadie miente indicando la potencia).
Yo hasta ahora no me he podido ver en ningún reporte, pero claro, estoy saliendo con 5 w y acoplando con la yagui para 10-15-20 (estacionarias hasta arriba, aunque según la opinión de Antonio voy perfecto). Así es válido meter un poco mas de chicha ¿no?, 10 w o así, para salir con algo al aire.
Me voy a instalar la version 7 del WSJT para ver si hago algún QSO, ya que en las recepciones que hecho veo que la gente ya llama CQ.
Rafa
Mis intereses en radio: en HF DX en SSB y CW (100 w.) VHF en portable (50 w.)
EA1YE
#43455  - 19 julio, 2008 01:21
Que poca confianza en los acopladores, de verdad !!!.
Si quieres le pedimos el ampli al doctor...para compensar las pérdidas por desadaptación... ji ji.
Ya veis que la media de potencia es de 0,5W.... de verdad de la buena.
EA3SD, copiado con -20db. FB.
EA1CJF, copiado con +13db. Si, +13db. Es lo que tiene vivir cerca...;)
EA1NX
#43456  - 19 julio, 2008 01:37
Mi primer QSO con W6SZ en WSPR en 20 m. Después llamaba EB3JT pero desaparecío al poco.
Ánimo, que para los que ya le han dado al JT65 es casi lo mismo.
Por cierto, ya me han reportado bastantes en 30 m. Salía con 10 w (para compensar las prérdidas por desajuste de banda), pero no se porqué me ponen con +6 dbm de potencia.
EA1YE
#44036  - 19 julio, 2008 01:41
EA1YE
#44037  - 19 julio, 2008 10:11
Y enhora buena por ese QSO, Rafa !!!!!
EB3JT
#44047  - 21 julio, 2008 20:14
Ops... no sabia que alguien hubiese copiado mi CQ, de todas formas creo que ví una señal de WSPR en mi pantalla pero no tube narices de descodificarla así que lo dejé...
Espero pillaros algun dia jejeje...
EA1YE
#44185  - 21 julio, 2008 21:17
Hola Jordi... Parece que tendremos que "pelear" un poco este nuevo modo.
Juer, veo que os habeis lanzado rapidamente de cabeza a la piscina.... mola !!.:silly:
Es facil que Rafa esté esta noche o mañana por la noche activo en este modo. Creo que le ha gustado...
Si satisfago mi "mono" de telegrafia, lo mismo me uno al JT7.
Nos vemos...
