Kuhne DB6NT nos sorprende con un nuevo transverter para 144 MHz;
TR144 Pro
1385 €
New features
Status readout with an easy-to-read LCD-Display
New Local-Oscillator with VCTCXO and +/- 0.5 ppm stability and phasenoise better than -155 dBc/Hz @ 10 kHz
Output from Local oscillator for a second converter or synchro receiver or predistortion downconverter on software defined radios
Second independent IF Receiver port to connect a second receiver such as Spectrum readout, SDR receiver or a „sun and moon noise meter“
Two equivalent HF-Antenna ports free configurable as receiver port or transmit port or two independent antenna systems
Monitored power amplifier with several protection circuits
A lot of possibilities to configure the transverter for the most popular HF-transceivers
Free configurable delay time of the internal sequence generator and open drain outputs for maximum flexibility
Possibility to control the transverter with serial interface direct with PC (not RS232)
Internal Blower now temperatur-controlled
Well-tried functions and features
Input for external reference frequency for synchronizing to 10 MHz source and automatic changeover if an adequate power level is detected
The internal antenna relay provide an Isolation of typical 70 dB
Intermodulation >35 dBc @ 20 W PEP by new designed RF power amplifier with newest LDMOS technology
Infinitely variable transmit gain adjustment on front panel
Spurious rejection is better than 60 dBc, achieved by using an 5th order low pass
Usable for all modes like SSB, PSK, FM and many more
Low noise preamplifier with typical 0.9 dB NF and an OIP3 of about 40 dBm
Máximo, pues si que nos han sorprendido, sobre todo por el precio, sale más barato comprarse un equipo....
Saludos 73's.
EAQRP-122 - - - URE-51622
EGV-40 By EA3GCY =2,5W
Yaesu ft-818 =6W
Pixie 7,023Mhz =0,6w
QRP Labs QCX CW 30m=5W
Howes 40m =2W
El precio es una sorpresa pero positiva. Cuesta igual o unos euros menos que el anterior con todas las mejoras que el nuevo tiene.
De todos modos, estos transverters no son para todos, esto ya lo sabemos, no estoy diciendo nada nuevo.
Escribió:El precio es una sorpresa pero positiva. Cuesta igual o unos euros menos que el anterior
Efectivamente, yo cuando lo vi, pensé que sería mucho más caro. Incluso en la página donde salen todos los transverters, no tiene precio.
Ahora me fijo y veo que el modelo anterior ya no aparece en la lista, por lo que entiendo que lo sustituye. Quizás por eso mantiene el precio, por ser el único modelo para 2m (con caja y acabado).
Se supone que estos aparatos son los Rolls-Royce de los transverters. Solo los usan las mejores estaciones.
A todo esto, yo tuve uno pero lo vendí. Quizás ahora me arrepiento...
Yo tuve alguno de ellos o de SSB Electronic, el de 23 cm, LT-230S que es del mismo nivel. (éste hace más de 10 años costaba € 1500, no era broma).
Sinceramente, ahora no los tengo, y no me arrepiento absolutamente de que se hayan ido.
Por la actividad que hay, soy de los que sostiene que no valen la pena.
Y en estas bandas, por lo que aprendrí, AL arriba y un buen conversor arriba y ampli en Tx abajo. Me ahorraría el dinero en conectores y coaxial poniendo las cosas lo más cerca de la antena, más que nada en Rx, porque lo que no escucha la antena o se pierde en el camino, por más que amplifiques, no lo vas a recuperar...
Cuando se hacen las cosas seriamente, como en EME, iba a escribir se gana más pero creo que el concepto real es, se pierde menos (con calidad) en los detalles que otra cosa.
Si claro. Esto es para hacer Luna, quizás MS, y poco más.
Creo que en centro-europa también los usan para concursos, ya que en algunas zonas entre Alemania, Suiza, Holanda, Francia, Eslovenia, etc. salen muchas estaciones, con mucha potencia y antenas y desde montañas altas, por lo que es necesario tener buenos equipos.
Aunque con el tiempo, han mejorado filtros, equipos, y toda la cadena y puede que ya no sean tan necesarios como hace años.
73, Máximo
Sí, para concursos van bien, 20 W son un poco mucho como excitación de SSPA pero no importa, eso no es importante, siempre se puede bajar la potencia de salida.
Estos transverters vivirán una segunda juventud en tanto y en cuanto los SDR no lleguen a esas frecuencias por sí mismos... Una vez que esto suceda, o los usaremos los románticos o los meteremos en un cajón y ahí se quedarán.
Bueno, ya Kuhne se dio cuenta y se amolda al tema;
Escribió:Second independent IF Receiver port to connect a second receiver such as Spectrum readout, SDR receiver or a „sun and moon noise meter“
Por eso también decía lo del precio, tiene muchísimas mejoras respecto al anterior por un precio parecido... Esto está muy bien.
yo creo que el territorio natural de estos transverters son los concursos. Para EME y MS soy de la opinión de que unos previos buenos, con bajo NF, junto a unos relés decentes y buen cable pueden suplir las "malas" características de un equipo convencional.
Por ejemplo, si ya desde el monte los TS2000 e IC746 lo pasan justito (o mal) por no poder soportar intermodulaciones y splatters de 3 estaciones en 100 kms en portable...imaginaos lo que es un concurso en DL, OK, G o F.
Creo que, al igual que en HF, donde todo vale para transmitir y recibir, en los concursos, con una estación de 1 KW a 5 KHz, es donde se hacen valer las características de los equipos buenos. Salvo error, creo que ningún equipo de 144 MHz llega a los niveles de rechazo de señales cercanas de un equipo TOP de HF+transverter.
Además, se da una ventaja que para algunos concurseros no pasará despercibida: Tener un equipo con 2 vfos simultaneos (tipo FT1000, FT2000, K3..) + transverter, permite llamar en una frecuencia fija mientras buscas con el otro VFO. Que yo sepa, ningun equipo standard con 144 MHz te permite tener eso.
Si me preguntaras por el equipo de mis sueños para concursos a día de hoy diría que Elecraft K3S + tr de Kuhne.
73 de Iñaki, EB1RL
Iñaki, y un 7300 con un transverter? a lo mejor, tener una "panorámica" de la parte de contests, en tiempo real, no viene nada mal.
Totalmente, las señales que se manejan en el centro de EULand, durante un concurso, son tremendas.
De todas formas, los que hacen concursos para obtener un buen resultado, tienen una instalación coherente, desde las antenas hasta el Rx, pasando por los cables, relés, conectores... y todo material involucrado en la misma.
Escribió:Si me preguntaras por el equipo de mis sueños para concursos a día de hoy diría que Elecraft K3S + tr de Kuhne
Estoy de acuerdo.
Así que pongámonos a ahorrar :dry:
Lo bueno es que el K3S serviría también para concursos de HF.
Y quiero pensar que para hacer Luna, MS, etc tampoco será malo...
(Para rizar el rizo, habría que añadir lo necesario para recibir con ambas polaridades simultáneas, para el MAP65).
Lo de la panorámica... para eso le pusieron una segunda salida al transverter.
PD. Aproximadamente, es como lo tiene HB9Q.
A mi personalmente, esas pantallitas pequeñas y sin posibilidad de poner otra.... no me convencen.
Que dejen un simple conector de vídeo (HDMI, Display Port, etc) y ya cada uno conectaremos lo que queramos.
Además, pensando... en esa foto queda muy bonita la línea, pero en la práctica, para manejar bien la radio debe estar situada a la altura de las manos, pero esa pantallita colocada tal como se ve en la foto, queda muy baja para una buena visión, tendría que estar más alta.
Te obliga a "romper" la línea, dejar el equipo abajo y colocar la pantallita más arriba, en algún estante, y aún así es muy pequeña.
Total, que queda muy bien en la foto, pero en la práctica, una simple pantalla LCD aunque sea pequeña, de 15, 17, 19 pulgadas, hará mucho mejor su función.
73, Máximo
Escribió:Ya está! Flex6700 + TR144Pro y todos de acuerdo!
Así, sí.
No tengo otra foto, pero mira que bien recibe, y que bien se ve, con uno de esos transverter de Kuhne, en este caso de 1296 a 28 MHz, un K3 y un SDR;
http://www.hb9q.ch/hb9q/index.php?option=com_content&view=article&id=34&Itemid=151
73, Máximo
Sí, se ve muy ni bien, pero con 10 m de parábola se ve así también con el pincho...
:laugh: :laugh: :laugh:
