Nuevo amplificador ...
Nuevo amplificador de SSB.de para 144 - Blueline
#23404  - 4 marzo, 2013 13:15
Acabo de ver el nuevo amplificador que los de la casa SSB de Alemania van a sacar al mercado.
Solo entrega 750w pero es muy eficiente y de cuidado diseño;
Hay disponible un PDF;
Blueline ECO750
Specifications
blueline ECO750
Features:
Microprocessor operated final amplifier, integrated programmable
Sequenzer, PTT control selectable, positive or negative, Input over-
voltage protection, USB CAT interface
Frequency range/MHz:
144 -148 MHz incl. USA band
Output power: 750 Watt PEP at 50 Ohm, at 45 Volt DC
Drive power: 5 Watt PEP (QRP Transceiver)
Harmocic suppression: -80 dB
Amplification: >17 dB
IM to PEP: ca. -35 dB
Power suppy requirements:
DC 45-48 Volt, Minus pole to housing
Power consumption: ca. 23 Amp. for 750 Watt PEP SSB
Efficiency: Peak 70 %
6dB Back off: >40 %
HF Input: N socket, 50 Ohm, VSWR < 1,3 : 1
HF Output: N socket, 50 Ohm
Cooling by temperature-controlled fan
Display: TFT active touch, operation voltage,
excessive temperature (-shut down),
drive power, output power, forward and
reflecting power
Power Supply: External 120-240V / 48 V / 1,3 kW switching-mode PS
