Nuevo ampli OM Powe...
Nuevo ampli OM Power 144 MHz 1Kw transistorizado
#24272  - 27 abril, 2013 20:13
Acabo de verlo y creo que nadie lo ha comentado por aquí aún.
Los de OM Power acaban de sacar el modelo OM1002 de 1Kw para 144 MHz con el famoso transistor MRFE6VP61K25H.
OM1002
Frequency coverage: VHF amateur bands 144 till 146 MHz
Power output: 1000 W CW, 800 W SSB and 900 W AM, FM and Digital modes
Driver Power: 7 W to 14 W
Input impedance: 50 Ohm VSWR < 1.5 : 1
Output amplification: 17 dB
Maximum output SWR: 2:1
SWR protection: automatic switching to STBY , when reflected power is 150W or higher
Intermodulation distortion: 35 dB below nominal output
Suppression of harmonics: < -60 dBc second
Transistor: MRFE6VP61K25H
Cooler: 3 pc’s axial blower
Power supply: 100 to 240 V - 50/60 Hz
Protection circuits: - SWR too high
- Drain current too high
- Input power too high
- Output power too high
- Gain too low
- Voltage too low
- Temperature too high
Display indications: - 140 x 16 dot graphic display
LED indicators: - OPERATE / STBY
- CW mode
- Preamplifier ON
- FAULT
- ON AIR
Parameters: 270mm x 190mm x 340mm (width x height x depth)
Weight: 12 kg
