SI AQUÍ SE HICIERA ...
SI AQUÍ SE HICIERA LO MISMO.........
EA6R
 EA6R
#15520  - 6 junio, 2011 19:41
On June 6, the FCC issued a Forfeiture Order in the amount of $24,000 against Kevin W. Bondy of Encino, California, for engaging in unlicensed radio operation and intentional interference to licensed radio operations and for refusing to allow an inspection of his radio equipment by FCC personnel. Bondy -- licensee of General Mobile Radio Service (GMRS) Station WQGX75 -- is accused of repeatedly and intentionally jamming four land mobile frequencies assigned to The Oaks Shopping Center in Thousand Oaks, California.
In assessing the $24,000 fine, the FCC noted that it was responsible for making and enforcing regulations to prevent interference and to maintain control over the use of the radio spectrum in a manner that promotes the public interest and convenience. “Bondy’s acts cut at the heart of the Commission’s responsibilities to protect the nation’s airwaves and regulate use of the spectrum,” the Order said. “Bondy operated a radio without a license on the specific frequencies assigned and licensed by the Commission to The Oaks, for the explicit and expressed purpose of prohibiting The Oaks’s use of its licensed frequencies. This type of conduct inhibits the Commission’s ability to effectively regulate and maintain control over the use of the spectrum and will not be tolerated.” Bondy has until July 6 to pay the fine.
El 6 de junio, la FCC emitió una orden de decomiso de 24.000 dólares contra Kevin W. Bondy de Encino, California, por operar una estación de radio sin licencia y la interferencia intencional a las operaciones de radio con licencia y por negarse a permitir la inspección de su equipo de radio por personal de la FCC. Bondy, titular de la licencia de WQGX75 de la estación de servicio General de Radio móvil (GMRS)--es acusado de cuatro frecuencias móviles de tierra de interferencia repetida e intencionalmente asignado a la Oaks Shopping Center en Thousand Oaks, California.
En la imposicion de 24.000 dólares de multa, la FCC señaló que es responsable de cumplir y hacer cumplir regulaciones para evitar interferencias y a mantener el control sobre el uso del espectro radioeléctrico en una forma que promueva el interés público y conveniencia. "Actos como el de Bondy se deben de cortar de raiz y esa es una de las responsabilidades de la Comisión para proteger las ondas de la nación y regular el uso del espectro", dice la orden. "Bondy ha operado una radio sin licencia en las frecuencias específicas asignadas y autorizadas por la Comisión, con el propósito explícito y expresado prohibición uso de robles el de sus frecuencias con licencia. Este tipo de conducta inhibe la capacidad de la Comisión para regular y mantener el control sobre el uso del espectro y no será tolerado." Bondy tiene hasta el 6 de julio para pagar la multa.
Pedro
73'S FROM MENORCA
#151439  - 7 junio, 2011 07:04
Pues ya sólo con el mal uso de los repetidores, se iban a hinchar.
Si sumamos ciclistas, cazadores, etc. a 24000$ cada uno, la cifra sería enorme.
EB2GPF
#151473  - 11 junio, 2011 11:32
No les estaria mal porque encima les dices que estan en frecuencias de radio aficionado y algunos contestan que como
pagan su licencia de federados de caza y les an dado esas frecuencias que no sevan y yo pregunto eso es legal
La paciencia es un don....... que yo no tengo
EA2DR
#151440  - 11 junio, 2011 11:48
En la banda de VHF de radioaficionados, solo pueden salir radioaficionados, que ademas deben cumplir con el reglamento, condicion indispensable, dar el indicativo en sus emisiones.
Ningun radioaficionado, aunque tenga su licencia, puede usar las frecuencias para otro fin que el de ser radioaficionado, lo que deja fuera el empleo para fines comerciales y/o profesionales, tampoco para fines particulares excluyentes del resto de radioaficionados, nadie puede acaparar una frecuencia (salvo quiza las estaciones especiales que asi lo tengan asignado [y seria realizar una interpretacion arriesgada]).
Hipolito Sanchez.
WW-Loc: IN83MB
EA4BGH
#151796  - 12 junio, 2011 08:23
EA2DR escribió:
En la banda de VHF de radioaficionados, solo pueden salir radioaficionados...
Y los inhibidores de frecuencia :angry:
2m 70cm 23cm 3cmRX y 3cm/P
EA5LN
#151441  - 13 junio, 2011 11:17
No os equivoqueis.
La multa no se la han puesto por interferir a radioaficionados, sino por interferir las comunicaciones de un centro comercial.
Si aqui pasa lo mismo, también hay "palo".(a menos que sea al centro comercial, el que tampoco tenga licencia, je je)
En USA tampoco atan los perros con longaniza.
IM99QO - Benaguasil (Valencia)
Visita: http://www.ea5rcl.es/web/
