Nuevo Rotor UB-One ...
Nuevo Rotor UB-One de UltraBeam - Green Heron
#25090  - 18 julio, 2013 10:49
Acabo de ver que la gente de UltraBeam no solo hace antenas... ahora también acaban de sacar un rotor con muy buen aspecto, similar a los Prosistel, y con el mando de Green Heron, estupendo. Le llaman UB-One.
Lo hay en dos versiones según su potencia.
Los precios rondan los 1.500 € para el menos potente, y los 2.000 € para el grande.
Tienen varias características especiales como son que un solo mando puede manejar varios rotores "enfasados", tiene la opción de conexión vía Wi-Fi (Green Heron EveryWhere) y el control via LAN (además de RS232 y USB).
Features :
- Precision ramp control for smooth starts and stops
- Manual control using CCW and CW buttons
- Point and Shoot knob for set and forget operation to 1º precision
- The ability to correct for mast slippage using OFFSET
- Computer control via RS-232 or USB to 1/10º accuracy
- Precision heading accuracy up to 1/10thº
- Master/Slave links 2 or more controller for stacked arrays or turning multiple systems to same heading.
- Counter-Rotation for single mast systems with rotator above a rotator
- Fully programmable settings for speed, ramps, brake delay, limits and more
- Two alternate OFFSETs for offset antenna directions on the same mast
- Limits rotation for side mounts, and allows up to 720º total rotation for supporting rotators
- Breathtaking VFD display with 4 brightness levels and auto-dim
- Many built-in safeguards to protect your system from over-rotation due to internal or external failures
- Rugged .080 aluminum chassis houses CCS rated power components and 5 lb transformer
- Special advanced options for custom applications
- Supports "Shortest Route" for rotators with more than 360º rotation capability
- Comprehensive SETUP Utility software included
- Free application software for satellite tracking, and remote control and rotator sharing using TCP/IP
- Wi-Fi option
