InnovAntenna (G0KSC...
InnovAntenna (G0KSC) compra Force 12
#27680  - 22 abril, 2014 10:48
El amigo Justin - G0KSC, propietario de InnovAntennas, ha comprado la marca Force12, la cual pertenecía a Texas Tower desde hacía un tiempo.
Lo que realmente ha comprado es la marca (el nombre) y los diseños.
La fabricación de las antenas Force12 va a hacerse desde InnovAntennas USA para el mercado estadounidense, y para el resto del mundo (UK, Europa, Asia, etc.) desde InnovAntennas UK en Inglaterra.
Force 12 UK
Force 12 have been producing high quality antenna systems for the commerical, defence and Ham world for over 20 years. In 2014, Force 12 was aquired by InnovAntennas on 2013, a company with head quarters in both Colorado, USA and London, UK. InnovAntennas have been able to add a great deal of value to the Force 12 brand, first is the additional buying power and associated cost reduction/quality of materials improvement which comes which such a scenario, then there is the capabilities of Justin Johnson, G0KSC. Justin is a lateral thinker and creative antenna modeller who invented the LFA (Loop Fed Array) Yagi, the OP-DES (Oposing Phase Driven Element System) Yagi and the OWL (Optimised Wideband Low impedance) Yagi.
Justin has been working with the enhancement and improvement of current Force 12 models for the past 4 years and now has the ability to extend his abilities through the Force 12 product range further, the fruits of which can be seen in the brand new XR range which is shorter the the original desgins, provides the same performance as the orignal range yet provides a much wider, flatter SWR.
From a mechanical perspective, each and every Force 12 product is having an overhaul. Kurt Andreas, K7NV author of the Yagi Mechanical design software Yagi Stress have take a look at each model and re-designed the structure to improve and increase wind loading, balance and survivability of the Force 12 range.
In short, be your requirement one of our standard models or should you have a bespoke need requiring design & build, Force 12 is a name to remember and one you can trust for quality of build and perfromance.
The Force 12 Team
