TS-590 ALC fix
TS-590 ALC fix
Página 1 / 3
EA7GWC
#27613  - 19 abril, 2014 07:04
Hola, Kenwood parece que al fin ha sacado una modificación para corregir
el circuito de ALC.
En el grupo de Yahoo podeis ver fotos.
Alguien a contactado con kenwood ibérica, para ver como toman el tema...?
Here is info I got from one of my Kenwood dealers and I wanted you all to get the word:
Attention all Kenwood Dealers,
We understand that there are TS-590S owners that are still having problems with the ALC spike issue, even after a firmware upgrade lowered the spike. If you have a customer with an amp that is shutting off and going into standby please share this info with them. The radio must be sent to a Kenwood Service center for the modification, it takes approximately 1.5 hours to complete and takes several parts, it is not doable by the end user.
There is no charge for this modification, in or out of warranty.
Kenwood will pay the return shipping from the service center.
The owner pays for shipping to the service center, and we take care of the rest!
The U.S. service centers will be ready to perform the modification in late April.
Serial number range: B09xxxxx to BC3xxxxx
From SN B4100001 the modification has been applied.
Thanks for your support.
Kenwood USA
Here is the Service Centers information for Amateur Radio Products
KENWOOD AUTHORIZED SERVICE CENTER - PACIFIC
19501 East Walnut Drive South
CITY OF INDUSTRY, CA 91748
Phone: 626-333-2443
http://fthgroupinc.com
KENWOOD AUTHORIZED SERVICE CENTER - EAST
829 LYNNHAVEN PARKWAY #130
VIRGINIA BEACH, VA 23452-7224
Phone: 757-340-1702
http://www.avsl.net
Don W6gps
EA4AQQ
#250614  - 19 abril, 2014 15:18
Hola Francisco muchas gracias por la info , que tipo de modificación es y si puedes enviar el enlace, no obstante el lunes se lo comento a Kenwood , como en su día ya se les dijo tanto a ellos como a los japoneses sin respuesta.
Muchas gracias
EA7GWC
#250615  - 19 abril, 2014 15:45
Podeis seguir la info en el grupo del ts-590
https://groups.yahoo.com/neo/groups/KenwoodTS-590/info
https://groups.yahoo.com/neo/groups/KenwoodTS-590/conversations/topics/21077
Al parecer le añaden una plaquita y cambian alguna resistencia.
El cable azul de la foto va a la otra cara de la placa, circuito de alc.
En USA en este mes de Abril los centros de servicio estarán listos para hacer la mod.
Haber que dicen aquí......además los equipos fuera de garantía también entran.
sin coste.
EA7TS
#250616  - 20 abril, 2014 08:38
Yo al principio con este tema del ALC andaba loco perdido ya que se me disparaba y sigue haciendolo, pero en su momento hice bastantes controles y en cuanto me dijeron que salia sin distorsionar decidi poner en en modo SWR y no hacerle caso.
Por cierto con el PROC activado sujeta la señal del ALC .
De todas formas si hay una modificacion es tanto como reconocer que algo no funcionaba correctamente.
Habra que estar al tanto.
Pepe
73s Pepe EA7TS - KH7TS
EA7GWC
#250617  - 20 abril, 2014 09:54
Pepe, tu tienes amplificador....?
EA7TS
#250689  - 20 abril, 2014 13:59
Ya me gustaria, pero no.
EA7H
 EA7H
#250618  - 20 abril, 2014 18:13
Pedro L (EA4AQQ) Te agradeceria que por este medio nos dijese lo que te comunique Kenwood, ya que tambien tengo ese problema.
Muchas gracias.
Manuel (EA7DVY)
EA3CI
#250709  - 20 abril, 2014 18:51
¿Este problema con el alc puede provocar averias importantes en el propio equipo?
EA3CI- Lluis
EA7GWC
#250619  - 20 abril, 2014 19:39
El problema, es un pico de potencia que da al principio, independiente de
la potencia ajustada. No es el único equipo que padece de esto.
puede causar problemas con el uso de amplificador al meter un exceso
de entrada.
También la potencia en SSB es baja al parecer por un mal diseño de este
circuito.
http://5tx.de/?p=887
EA7TS
#250620  - 20 abril, 2014 21:10
Por lo que yo se , al pulsar mc durante unos milisegundos alcanzaba una alta potencia lo que hacia saltar las protecciones de los lineales.
Pero bueno de esto ya se hablo largo y tendido en el foro.
El tema del ALC tiene la importancia que tiene, es un freno a la "voz". Pero si como en mi caso la modulacion es correcta , para que preocuparse?
Yo lo tengo hace año y medio y muy contento con el equipo, es mas cuando lo compre ya era consciente de este tema.
Pepe
EA3NR
#250621  - 6 mayo, 2014 18:36
¿Alguien sabe si Kenwood Ibérica va a realizar esta modificación?
En Internet y en la página de G3NRW no hay nada al respecto...
73 de EA3NR, Enric
web: www.qsl.net/ea3nr
e-mail: ea3nr@ure.es
EA7GWC
#250622  - 6 mayo, 2014 20:28
La verdad es que está un poco confuso el tema.
Aquí teneis una foto de la modificación que lleva uno de los nuevos
B4200xxx.
Como se ve, no coincide.
EA4FRR
#251751  - 27 mayo, 2014 17:42
Buenas tardes! se ha pronunciado Kenwood sobre este tema???
Gracias!
Santiago - EA4FRR
IN80EL
ea4frr@gmail.com
EA4AQQ
#253386  - 28 mayo, 2014 18:00
Creo casi con toda seguridad que Kenwood Iberica ya tiene la orden de realizar la modificación que origina el problema con respecto a la autoprotección de los lineales.
EA7GWC
#250623  - 30 mayo, 2014 21:25
Aqui teneis las primeras pruebas de un equipo modificado,
Parece que Kenwood ha acertado en la mod.
http://5tx.de/?p=1350
EA1OD
#250624  - 2 junio, 2014 15:25
hola
el viernes envie un e-mail a Setelco Radio y hoy recibo esto de JVCKENWOOD
Apreciado Sr. Carmelo,
Nuestro servicio oficial Setelco nos remite su comentario sobre la mejora del control ALC en el modelo TS-590S, comentarle que recientemente el departamento COMM QA de JVCKENWOOD Corporation ha emitido un boletín para los casos en que se deba mejorar el control de ALC del modelo TS-590S.
Esta actualización se ofrece por parte de JVCKENWOOD Ibérica sin cargo de mano de obra ni de materiales a sus clientes propietarios del citado modelo.
Para su aplicación, Usted debe hacer llegar su transceptor a uno de los Servicios Técnicos Oficiales que detallamos:
Radio Asistencia (Madrid) 915 262 017
Setelco Radio (Barcelona) 934 494 477
Atención al Cliente.
Al fin ....nos dan la razon Aqui.
EA7GWC
#253700  - 2 junio, 2014 18:55
Muchas gracias por tu info......
EA4FRR
#253733  - 4 junio, 2014 13:01
Me uno a los agradecimientos, muchas gracias!!!
Ahora bien, si no utilizo amplificador merece la pena hacer la modificación?
Si dentro de unos años me da por poner un amplificador, me cubrirá Kenwood el coste de la modificación?
De todas maneras hablaré con el servicio técnico a ver que me dicen...
73!
Santiago - EA4FRR
IN80EL
ea4frr@gmail.com
#253843  - 4 junio, 2014 16:45
El problema pienso que está ahí, con ampli o sin él. La diferencia es que el ampli amplifica todo, incluyendo el problema.
Normalmente hacen esos trabajos durante un tiempo determinado, lo suficiente para modificar la gran mayoría de los equipos vendidos. Puede ser un año, dos, pero no creo que sea para siempre...
EA3AF
#250625  - 5 junio, 2014 05:33
Entonces esta claro que los que tengan un 590 el servicio tecnico les hace la modificacion.
¿Pero los 590 nuevos vienen ya con este tema solucionado de fabrica?
73 / EA3AF
www.ea3af.com
Página 1 / 3
