Sube la ROE con llu...
Sube la ROE con lluvia o humedad?
#36655  - 19 junio, 2018 23:35
En la web de K4KIO hay un articulo de Rain on my Hex
¿Alguien a tenido alguna experiencia con su antena que cuando llueve o tiene humedad la ROE se altera y cambia la resonancia de la antena?
How come the SWR on my hex beam goes up when it’s raining?
Good question. Many hex owners discover when it is raining that their SWR is higher than usual, maybe by almost a point. Then when things dry up, the SWR returns to normal. They scratch their heads wondering if water got into the center post or if the cords connecting the wire sections are conducting RF current when wet. Neither is true. The change in SWR during rain is caused by something else.
There has been some research done on this by a radio scientist in Yugoslavia who is also an amateur radio operator (YU1AW). He has published several technical articles on the subject of wet antennas. He shows that antennas generally are affected by rain because the water on the elements is similar to temporarily adding insulation to the wires. This additional “insulation” shifts resonance downward in frequency. As a result the SWR at the normal resonant point is increased temporarily. This effect is greater proportionately on wire antennas than on aluminum tube antennas. The effect is also greater on hex beams than on other wire antennas. But when things dry out, the temporary “insulation” is gone and everything is back to normal.
Does this mean I can’t use the beam when it’s raining? No. Just tune the SWR out and go right ahead. The beam is still working; you just have a temporary de-tuning issue that shouldn’t stop you from working DX or having QSO’s.
- Información relacionada en:
· Diamond W8010 y lluvia=ROE
· R.O.E. EN ANTENA CUANDO LLUEVE
· dipolo mojado= estacionarias
· Trampas hilo coaxial vs condensador/bobina
· Problemas con CUSHCRAFT R6000
73 EA1DVY
Carlos EC1T
Ex. EA1DVY
Soria in81
EA2AF
#324104  - 20 junio, 2018 06:17
Buenas:
En mi vertical, te puedo decir que al llover la ROE baja, por ejemplo, en 40Mts, de tener 1,3 me baja a 1,1.
Me suele bajar en todas las bandas aprox 0,2.
EA2AF
Roberto Sánchez
EA5BRE
#324105  - 20 junio, 2018 06:18
Por Alicante..Desgraciadamente..!! nunca vamos a tener ese problema..
EA1AER
#324109  - 20 junio, 2018 12:30
En un dipolo multibanda W-8010 sí que noto cambios cuando llueve.
Juan Carlos
https://ea1aer.blogspot.com
EA2HB
#324106  - 20 junio, 2018 12:39
El asunto es muy viejo y se suele olvidar.
Cuando llueve, en general no nos cambia la ROE de la antena, sino la medición en nuestro cuarto de radio.
La causa suele ser generalmente la entrada de agua en el coaxial.
Dado que el agua tiene la mala costumbre de circular de arriba hacia abajo, si no se ha tomado la precaución de que nuestro coaxial ataque a la antena en forma de "bastón" para que el agua antes de entrar en el coaxial tenga que "subir un poquito", es fácil que la bajada se empape, modificando la impedancia del coaxial.
Para los que vivimos en clima lluvioso y nos ha tocado la desagradable sorpresa de cortar con un cúter la cubierta de plástico del RG8 en la parte más baja del cuarto de radio y comprobar que el coaxial "nos mea", esto no no suena a nuevo.
Lo peor del tema es que este agua deteriora la malla del coaxial y ya no vuelve ser fiable hasta que se sustituya.
Suerte y que el coaxial no os "mee" como si fuese un perrito maleducado.
EA2AF
#324117  - 20 junio, 2018 13:23
Fede, yo la entrada la tengo en forma de bastón cómo indicas, al margen que la tirada va aguas arriba del tejado para luego bajar, con lo que es practicamente imposible que entre agua en el coaxial, al margen de estar cubierto, y la estacionarias me baja una media de 0,2 cuando llueve. Curioso, no?
EA2AF
Roberto Sánchez
EA2AJO
#324108  - 20 junio, 2018 13:24
EA2AF escribió:
Buenas:
Roberto me imagino que estarás rezando todos los días para que llueva :woohoo: :woohoo:
73's.
EAQRP-122 - - - URE-51622
EGV-40 By EA3GCY =2,5W
Yaesu ft-818 =6W
Pixie 7,023Mhz =0,6w
QRP Labs QCX CW 30m=5W
Howes 40m =2W
EA2AF
#324118  - 20 junio, 2018 13:31
:woohoo: :woohoo: :woohoo: :woohoo: que va, no me preocupa la ROE de no ser que pase cómo mucho de 1,7.
El acoplador CG300 funciona de maravilla y me ajusta dentro de las tolerancias, otra cosa es que queramos lograr la "ideal" de 1,1-1,2
EA2AF
Roberto Sánchez
EA6XD
#324119  - 20 junio, 2018 16:33
Yo tengo una vertical de 80/40m y cuando llueve la ROE aumenta porque se desplaza la frecuencia de resonancia.
Cabe decir que los radiales están sobre las tejas, si estuvieran bastante elevados apenas habría diferencias, cuando llueve aumenta la capacidad de lo que tienes debajo haciendo de condensador y es como si alargara los radiales, la antena se sintoniza unos 100Khz más abajo al llover, y decir que no me entra agua en el coaxial, todo está hermético, ademas, los coaxiales no cambian de capacidad porque estén mojados, tengo una antena que lleva un condensador de coaxial y otra con un Gamma hecho de coaxial y cuando llueve ni se entera.
Guillem - EA6-xD
EA2AJO
#324125  - 20 junio, 2018 17:50
También suele variar debido al cambio de la conductividad del suelo cercano a la antena al estar húmedo, nos hace variar ligeramente la impedancia.
73's.
Yaesu ft-818 =6W
Howes 40m =2W
EA3IO
#324107  - 20 junio, 2018 18:41
Lo del coaxial que "mea", se soluciona, vulcanizando los conectores de antena, así como el conector de la misma. Ya no debería ocurrir, salvo que se tenga un roto en la cubierta.
EA3IO
Manuel Aleu
EA1X
 EA1X
#324128  - 20 junio, 2018 18:42
En bandas mas altas y con antenas muy optimizadas, 2 metros y 432, para zonas muy lluviosas, se diseñan las antenas teniendo en cuenta ese cambio de resonancia con las gotitas de agua sobre los elementos y el ambiente húmedo.
73 y DX, Juan
EA1X (EF1A en Majors)
Ex EA1XT-EC1AGU-EA1BLX-EB1BXW
IN53VK
