Me ofrecen un acoploador Sailor AT-2110, pero no estoy seguro de que se pueda adaptar para hacerlo funcionar con una antena "látigo" de HF...
¿Alguien tiene algo parecido?
¿Cómo se realiza la alimentación?
-Demócrito (460 AC)-
Miguel Ángel "MrDJ"
Hola Miguel
El acoplador si trabaja con antena de latigo
pero creo que necesitas el receptor - transmisor
un saludo
juan
https://ec1dlh.blogspot.com/
Hola Miguel,
Coincido con EC1DLH, no es precisamente Plug&Play. En su día intenté aprovechar alguna otra referencia de Sailor y van comandadas desde el TX asociado. Para que te hagas una idea, cut&paste del manual del que comentas, AT-2110:
5.1 MAIN BOARD (MODULE 1) PART NO. 625651
This board contains all circuits necessary to make match between the aerial impedance and the transmitter output impedance.
In receive mode the signal is fed direct to the aerial via RE18, RE17, and RE16 for frequencies above 4MHz. For frequencies below 4 MHz, RE17 is activated so that the aerial is fed through TR03 to the receiver.
TR03 is transforming the aerial impedance down to give better match to the receiver.
In transmit mode the signal from the transmitter is fed to TR01, which transforms the impedance down to
12.5 ohm. From TR01 the signal is fed to L01 and L02. The value of the coils is set by the relays RE01 and
RE10. The relays are controlled from the TX processor in T2130. From the coils the signal is fed to C01,
a variable capacitor which is driven by the motor MO01. MO01 is controlled from the TX processor in T2130.
The optocoupler OC01 gives a pulse for every 180o rotation of the capacitor C01. This pulse is fed to the
TX processor in T2130. From the variable capacitor C01 the signal is fed to a shunt capacitor bank. The
value is selected by RE11 to RE15, which is controlled from the TX processor in T2130. From the capacitor
bank the signal is fed through TR02, which is a current transformer. The output from TR02 is rectified in
D01 and the DC output is fed to the TX processor in T2130.
From TR02 the signal is fed to the aerial relay RE16. GL01 is protecting the aerial coupler against small
lightnings. R02 is decharging the aerial.
Saludos!
73&DX de Zalo 9M2/EB1IVY
Lo que me temía.
Gracias, aclarado también por si en el futuro alguien más se lo plantea.
Miguel Ángel "MrDJ"
