Nuevo SDR: ANAN-100...
Nuevo SDR: ANAN-100B
EB5AGV
#28248  - 29 junio, 2014 18:46
Acabo de recibir este mensaje de Apache Labs. Parece un equipo interesante a un precio muy razonable:
We are pleased to introduce the ANAN-100B 100W all mode HF & 6M SDR Transceiver, the introductory pricing of $1849 is available immediately, the ANAN-100B is expected to ship by early September 2014,
The ANAN-100B (Base Model) provides an entry level 100W rig for SDR enthusiasts, receive and transmit performance levels achieved are best in class,
Differences with the ANAN-100:
- Supports Dual receivers on a single ADC
- ADC Rx input is broadband
- Uses Hermes onboard SMPS
- 1 Year Warranty against manufacturing defects
The ANAN-100B is compatible with PowerSDR, cuSDR and other PC applications that the ANAN series uses, PureSignal can be used with the ANAN-100B.
Specifications:
· Rugged Extruded Aluminum Housing, Weight: 4.5Kgs approx, Dimensions: 265.5mm (W) x 220mm (D) x 80mm (H)
· RD100HHF1 Mosfet 100W Linear amplifier (160M-6M)
· All cables, Hardware and instructions to make a complete transceiver with Hermes
· Continuous, uninterrupted, receive coverage from 10KHz to 55MHz. .
· Supports Real-Time display of entire spectrum from 0-55mHz (with suitable PC software)
· Supports 2 fully independent receivers (sharing the same antenna - and with suitable PC software)
· Each receiver can display 48/96/192/384/1152kHz of spectrum
· Blocking Dynamic Range (ARRL Method) no detectable gain compression
below ADC overload
· Transmit and receiver image rejection > 90dB
· Transmitter two-tone 3rd order IMD of -31dBc on 20m @ 100W PEP output
· 100W RF output on 160 – 6m amateur bands
· Built-in high performance preamp, with a noise floor typically -135dBm in a 500Hz Bandwidth
· Software-selectable 31dB input attenuator in 1dB steps
· High performance receiver – same specifications as the HPSDR Mercury receiver (ie Dynamic Range typically 125dB)
· FPGA code can be updated via the Industry Standard TCP/IP network Ethernet connection
· Seven user-configurable open-collector outputs, independently selectable per band and Tx/Rx (for relay control, etc - with
sequencing via PC code)
· Separate open-collector PTT connection for amplifier control, etc, with sequencer
· Microphone PTT jumper-selectable from tip or ring connection
· Bias for electret microphones via jumper
· Four user-configurable 12 bit analogue inputs (for ALC, SWR etc)
· Three user-configurable digital inputs (for linear amplifier over temperature, etc)
· I2C bus connector for control of external equipment
· Full QSK operation (performance dependant on associated PC and control software)
· Low-level transmitter output for transverter use via user-selectable output attenuator
· Stereo audio outputs at line and headphone levels
· In-built 1W stereo audio amplifier for directly driving speakers
· Direct, de-bounced connections for a Morse key (straight or iambic) and PTT
· Low phase noise (-137dBc/Hz @ 1kHz) 122.88MHz master clock, which can be phase-locked to an internal 10MHz TCXO or
external fequency reference
· Industry Standard TCP/IP network Ethernet interface supports static, APIPA or DHCP IP address
Hermes responds to ping and ARP requests and auto senses network connection speed
Eight (8) Layer PCB design for the most professional, state-of-the-art, design available.
Regards,
Abhi
73 JOSE EB5AGV
#255459  - 29 junio, 2014 19:19
Yo acabo de leerlo. Supongo que querrán reducir el número de variantes en cuanto a caja, y por la diferencia de precio, el de 10w ya no vale la pena. Luego supongo que lo dejarán de hacer.
Es curioso que al principio cuando salió el Hermes, se tenía como "inferior" o hermano pequeño del HPSDR por placas independientes, y con el tiempo mira... parece que el formato todo en uno, más compacto, tiene más salida comercial que el formato original por tarjetas.
Ahora todos salen en ese formato, Hermes, Angelia y Orion.
Por cierto, he visto que tiene un documento PDF donde se relacionan todos los modelos, características, etc;
Familia ANAN en PDF
#255464  - 29 junio, 2014 19:34
Mirar, acabo de encontrar este vídeo en YouTube.
Aunque es un Flex, da igual, es un SDR.
[strike]Si esto es el futuro de la radioafición... no es para mí[/strike];
EB5AGV
#255465  - 30 junio, 2014 07:48
Si esto es el futuro de la radioafición... no es para mí;
¡Ja, ja, qué bueno :laugh: !
Da para un chiste... ¿cuántas pantallas son necesarias para hacer un simple QSO con un SDR? ;)
Hombre, es algo exagerado, sobre todo el pantallón de 40"... Algo más moderado, con una pantalla o, como mucho, dos, es suficiente. Y un interface amigable, o sea, botones y mandos. Vamos, que lo que a mí me gustaría es un SDR con mandos convencionales, que ya va habiendo algo por ahí.
Pero que acabamos con equipos con base SDR en todas las marcas importantes, es cuestión de tiempo.
73 JOSE EB5AGV
#255466  - 30 junio, 2014 08:13
Lo acabo de meditar...
Voy a retirar lo dicho. Y me lo pensaré.
Puede que ponga algo similar, para determinadas ocasiones.
#255460  - 30 junio, 2014 17:54
No seais tan radicales, yo tengo pendiente poner a mi HPSDR una consola Hercules, pero destripada y puesta en el frontal para darle un toque tradicional.
Estos dias estoy haciendo mucho 50 MHz y suelo usar la ICOM 706MKIIGm que tiene 100W y el HPSDR solo me da 6w y no veais como añoro el panadapter y la sintonia a golpe de ratón.
El otro dia cambie la direccional para 50MHz de 5 El al HPSD y daba gusto ver la banda moverse en un periodo de mucha propa y saltar de QSO en QSO a "ratonazo".
