Nuevo Kit QRSS, WSP...
Nuevo Kit QRSS, WSPR, HELL, CW
Página 5 / 5
EA5DOM
#239397  - 13 enero, 2015 10:34
He leído los planes de Hans, G0UPL, para continuar con la saga de los Ultimate y creo que son muy interesantes, así que copio-pego aquí ;)
Se trata de un Shield para Arduino que permitirá montar un equipo similar a un Ultimate-3 pero con un microprocesador Arduino. La principal ventaja es que el código va a ser abierto y puede desarrollar mas gente. La desventaja es que inicialmente NO VA A TENER todas las prestaciones que actualmente tiene el Ultimate-3
A mi me parece muy interesante y abre la puerta a un montón de nuevos proyectos basados en este hardware. Este es el texto original de Hans
Many new kits are in the QRP Labs pipeline, including a new Arduino shield
kit. This is an Arduino shield version of the U3. It has sockets for a DDS
or Si5351A Synth board, U3 PA, sockets for U3 LPF's and even is compatible
with the relay-switched LPF board.
This new Arduino shield kit should be coming soon, I just have to get the
U3 back in stock first and the OCXO version of the Si5351A Synth too. I had
actually already sent the files to the factory for producing the Arduino
shield kit. But I suspended the manufacture because I want to make sure I
include all the latest minor modifications required to suit the Si5351A
modules. As soon as the U3 is in stock again and v3.07 out (should be this
week I hope!) I will resume the Arduino shield kit production.
Once the new Arduino shield is available I will try to prepare some
sketches for it including WSPR. I'm not going to replicate the whole U3
functionality as an Arduino sketch because I haven't time for that, but I
hope to provide enough pieces that if people want to take it further they
can, and hopefully share their work!
73 Hans G0UPL
73 de Luis
URE BENIDORM
ea5dom@ure.es
Postales no, gracias
EA1CDV
#267323  - 15 enero, 2015 12:06
No se si eso será bueno o malo. Al menos espero que siga comercializando el U3 que es una maravilla.
73`s de Antonio
ea1cdv@gmail.com
http://ea1cdv.blogspot.com/
Página 5 / 5
