Nuevo Interface USB...
Nuevo Interface USB-CAT-Digitales Yaesu SCU-17
#24776  - 13 junio, 2013 09:04
Yaesu acaba de sacar al mercado un nuevo accesorio.
Se trata de un interface USB que controla CAT del equipo así como interface de sonido, todo por USB.
Manual Yaesu SCU-17
The SCU-17 interface unit may be used for CAT control of the transceiver with
a computer via a USB connection; and for communications using SSTV, RTTY
and PSK digital modes.
.- The SCU-17 provides CAT communication through the USB terminal when a
PC does not have an RS-232C connection.
.- The SCU-17 is equipped with a USB audio system device, so the TX and RX
audio system signals are accessible to the SCU-17 through the USB cable.
Therefore, the supplied USB cable is the only connection needed between
the SCU-17 and PC.
.- The SCU-17 is equipped with a two-channel USB serial device and enables
the various transmission modes and the CAT communication simultaneously.
.- The SCU-17 operates from the USB bus power; you do not need to prepare
an external power supply.
.- For RF isolation, the SCU-17 is designed with photo relays for the PTT/FSK
terminals. AF transformers are used in the AUDIO IN/OUT lines to provide
excellent ground isolation.
.- The SCU-17 is equipped with the TX and RX audio controls on the front panel, for convenient level adjustment.
.- LED indicators on the SCU-17 front panel monitor the PTT and FSK control.
The operating conditions may be quickly confirmed.
EA1RT
#226381  - 13 junio, 2013 11:33
Hola Maximo, se sabe el precio EA land?
J.R.
DX,DX,DX Y MAS DX
Si algun dia,la tristeza te hace una invitacion, dile que ya tienes compromiso con la alegria.
#226392  - 13 junio, 2013 12:49
Yo conseguí la noticia, los precios... hay que preguntar en los distribuidores de Yaesu nacionales, a ver cuando lo tendrán disponible y a cuanto se venderán.
Lo bueno del cacharro es que envía todo por el USB, tanto el CAT como el audio de Tx y Rx. Tiene dentro su propia tarjeta de sonido, convertidor serie-USB, etc.
Es interesante. A ver a que precio sale.
Es de esperar que en los nuevos Yaesu de gama alta, lleven ya eso dentro, como algún Icom y Kenwood.
EA1NK
#226393  - 13 junio, 2013 13:52
J.R.
Al cambio típico 1$=1€ 190$ cuesta en USA, miedo me da el precio aquí...
www.ea1nk.com
#226382  - 13 junio, 2013 13:54
Te doy toda la razón, debido al uso creciente de digitales, creo que todas las marcas debieran empezar a incluir un interface único USB para digitales/cat.
Para ahorrar dinero yo los tengo por separado, con convertidores serie/USB, tarjeta de sonido externa por USB, etc., por lo que al final tengo un "chorro" de cables enorme.
#226399  - 13 junio, 2013 14:54
Mínimo eso pero incluso así ya sería anticuado ya que lo que todos deberían actualmente llevar sería toma de red (Ethernet), por lo menos de gama alta o media-alta.
Que aún haya equipos sin USB y sin LAN... ya lo considero anacrónico.
EA7YN
#226401  - 13 junio, 2013 19:07
y por que no hacer el del amigo Juan Antonio EA4AXG radio interface 1.4 yo lo tengo hecho una maravilla de proyecto
73,de EA7YN
#226431  - 13 junio, 2013 19:43
¿Donde se puede ver eso?
EA4BNQ
#226383  - 14 junio, 2013 01:29
Hola Máximo, aquí se puede ver, pero parece que la página no está de momento activa. Saludos Enrique ea4bnq. http://www.ea4axg.com.es/radio_interfaces.htm
Y en esta página está el manual.
http://ea4dei.jimdo.com/fotos-la-estacion-y-enlaces-de-interes/
Enrique (ea4bnq)
Talavera de la Reina
ea4bnq@gmail.com
#226440  - 14 junio, 2013 14:23
Hola Máximo, aquí se puede ver, pero parece que la página no está de momento activa. Saludos Enrique ea4bnq. www.ea4axg.com.es/radio_interfaces.htm
Enrique, efectivamente no funciona esa página.
Muchas gracias de todas formas.
EA1YV
#226384  - 14 junio, 2013 15:57
Aprovechando este hilo ya abierto, comento que yo estoy a la espera de que salga "algo" para hacer digitales con varios equipos sin tener que utilizar para cada uno ,un interface diferente , cada uno conectado a un puerto serie o usb diferente, y mediante un montón de cables....
Yo uso un Ts2000,un Ft847 y un Ic7600 cada uno en una banda.
Lo más parecido que veo es este SCU-17 ya que incorpora su propia tarjeta de sonido , lo malo es que solo sirve para un equipo por lo que deduzco.
#226491  - 14 junio, 2013 18:35
Agustín, eso lo puedes hacer si cada radio tiene un USB incorporado y los conectas todos al ordenador. Pero si la radio no tiene salida USB... necesita su propio interface.
Sería la solución más sencilla, algo así como un SCU-17 por radio y solo tres USB al ordenador.
Otro cantar es que el ordenador pueda correr tres equipos simultáneos.
EA1N
 EA1N
#226498  - 14 junio, 2013 19:27
Respecto a lo que comenta Agustin (EA1YV) de conectar dos equipos con un interface solo pues si que lo hay y se llama USB MK2R+ fabricado por microham.
http://www.microham.com/contents/en-us/d50_MK2R.html
Otro tema es el precio....ufffff...como muchas cosas en esta afición.
Mas asequible tienes de la misma casa el Micro2R.
http://www.microham.com/contents/en-us/p321.html
Si eres un poco manitas con el soldador y tiras de internet te lo puedes fabricar...yo lo hice y soy un muñon. Todo es cuestion de meter en una caja un hub usb, dos tarjetas de sonido usb, dos interfaces optoaislados, un par de conversores usb a serie, ademas le metí un accu keyer (K1EL), un interface SO2R, una tarjeta de memoria,..... y muchos cables por dentro jijjijijiji.
Pero es mas sencillo que todo eso, es meter las dos tarjetas de sonido usb, dos conversores de usb a serie y dos interfaces de los que hay a cientos por internet (optoacoplados) y listo, ya no se ve la marabunta de cables.
EA1EVR - Javi-
EA1YV
#226385  - 14 junio, 2013 20:05
EA1EVR solo te faltó una toma usb para un mp3... :dry:
Pues la verdad que un montaje como el tuyo merece que lo publiques por aqui.No sé que opinarán los demás.
Yo el tema de los ptts lo resolví añadiendo al ordenador de base una tarjeta PCI con dos puertos serie adicionales, que cuesta 16 euros.Es más fiable que los conversores serial-usb.
No hace mucho salió a la venta en el mercadillo una caja de conexiones llamada EB-2001 que al final no compré más que nada por no encontrar información por internet ni datos del colega que la lanzó.Pero parecía algo muy completo.Adjunto el manual en pdf por si le puede dar ideas a alguien.
EA1YV
#226386  - 14 junio, 2013 20:13
EA1EVR solo te faltó una toma para un MP3... :)
Un montaje como el tuyo-no sé que pensarán los demás-pero a míi me parece que debería ser publicado aqui con más detalle y alguna foto.
Yo el tema de los puertos lo resolví añadiendo al PC una tarjeta con dos puertos serie adicionales, coste 16 euros.Siempre son más fiables que los convertidores usb/serie.
No hace mucho salió a la venta en el mercadillo un interface llamado EB-2001 fabricado en España. Muy completo, hasta para 4 equipos.Al final no lo compré porque no encontré por internet info alguna ni forma de comunicarme con el colega que lo había fabricado. Pero como me pareció un montaje muy interesante que seguramente no tuvo continuidad porque salió al mercado antes de tiempo, demasiado avanxzado para las necesidades de la época, he subido a este link el manual en pdf que me pasó el vendedor.Siempre puede dar ideas a los actuales montadores y manitas.
Está comprimido y son unos 6 Mb.
http://www.filedropper.com/eb2001
EA1N
 EA1N
#226387  - 15 junio, 2013 21:42
Respecto a lo de publicarlo, pues la verdad es que no me lo planteé, ya que el hacerlo tiene que ser de una forma mas o menos seria y la verdad es que el montaje funciona perfectamente y aunque tengo el diseño de las placas, sobre ellas he realizado modificaciones que no he actualizado en los diseños y por lo tanto no son validos para montar y que funcione. Por otro lado fue diseñado a trozos, por lo que son añadidos sobre añadidos y eso complica la realización, en las placas están mezclados componentes de montaje superficial y componentes estándar, y aunque soldar smd no tiene ninguna complicación, hay gente que no se anima a empezar con ellos y para rematar, esta el tema de los costes....cuando realizo cosas de estas no miro el precio, porque si hecho cuentas de lo que gaste en el montaje, seguro que no lo hubiese hecho y lo hubiese comprado comercial, ya que solo la caja donde esta montado costos 40/50 euros, por lo que económicamente no renta, aunque si emocionalmente....que es lo que busco.
No obstante si alguien esta interesado en el tema puede contar conmigo para consultas o para intentar ayudar en lo que pueda.
Estas son las fotos del montaje.
EA4NR
#226402  - 15 junio, 2013 22:09
Aún hay fabricantes que están ensamblando equipos con tecnología de 20 ó 30 años. Hace varios años, se consumó el matrimonio entre la informática y las comunicaciones de forma imparable. Algunos siguen sin enterarse a pesar de que un equipo básico de SDR con cuatro componentes y a precios de crisis les da cuarenta vueltas a toda ésa tecnología obsoleta que se empeñan en mantener.
Luis
ea4nr@ure.es
EA1YV
#226388  - 18 junio, 2013 10:32
EA1EVR te felicito por el diseño ,casi comercial.
Por dentro a falta de foto interior, me imagino que estará tan bonito como por fuera.
No tienes un diagrama de bloques al menos?.
EA1N
 EA1N
#226819  - 19 junio, 2013 12:34
Pues por dentro no tiene nada que ver con lo de fuera..... como ya te comenté esta hecho un poco a remiendos unos encima de otros y mucho cableado entre placas, por lo que estéticamente es mejor ni mirarlo jiijijiji.
El diagrama de bloques viene a ser este
Como ves es meter en una caja lo que tendríamos por encima de la mesa.
Un saludo y perdón por desviar el tema original del hilo.
EA1EVR - Javi -
