¿Nuevo Icom IC-7610...
¿Nuevo Icom IC-7610?
Página 1 / 15
EA7FGJ
#33306  - 13 agosto, 2016 07:27
Se rumorea que Icom presentará un nuevo rtx en la HamFair de Tokyo de este mes.
Las características técnicas dicen que son las siguientes:
Replacement for the 7600, in the ICOM product line.
Direct sampling SDR platform. Projected debut, 2 years+/- 1 yr.
Projected MSRP $3000 USD
A list of likely features and design elements can be found below.
1. Enclosure form factor of the 7600 approx same size.
2. Larger touch screen.
3. 13.8vdc @ 25A input, external PSU.
4. Greater capacity ADC, lower noise. Higher sample rate. (Possibly longer bit string) [16-bit ADC].
5. More powerful DSP. [, faster TI TMS32C6XXX series DSP IC].
6. Built-in web-server for Internet remote, local wired or wifi connectivity. [Can also be RS-BA1 server]
7. Dual-watch, with no signal degradation, and true cross band, cross mode capability. [Dual demod may require 2 DSP chains].
8. Lots of extra RAM space for future software expansion.
9. 100watt out, full duty cycle any mode, 1hr rating, very low distortion HPA design.[Easily done with new LDMS devices].
10. Scope video with audio clip capture. [Feasible If sufficient memory provided].
**11. 100 dB spectrum scope dynamic range & calibrated(S-units & dBm).
Veremos si es cierto, aunque tarde o temprano lo será, de esto no hay dudas. ;)
EA7OC
#299350  - 13 agosto, 2016 17:39
y continua...
12. 48 to 100 volt in built power supply, forget the 12 volt nonsense. They can provide 12 volts out for accessories.
13. CISPR Ave and CISPR RMS calibrations scales for the s-meter with 9khz CISPR 16 bandwidth. We can do our own EMC radiated emission testing on all the Chinese rubbish.
14. RX Phasing noise cancelling unit
15. RX antennas protected and switched on TX along with the ability to apply pre-amp voltages on the RX antenna ports(bias t)
16. Pre-distortion
17. TX monitoring for both the transceiver and external amplifier with couplers. Coupler factor set in the radio. See N8LP LP500!
18. Removable remote panel like the TS480HX
19. 10 inch TFT screen
20. TX linearity monitor like LINRAD TX monitor over 20khz bandwith
21. Ability to do antenna plots
22. VNA capability
23. ability to drive a remote antenna coupler
24. ALE and HF Selcall. Nobody calls CQ these days it would be nice to do a beacon test for propagation with HF Selcall
25. Syllabic squelch
26. Ability to select 2 drive outputs and switch 2 amplifiers. With the drive levels memorized for Linear 1 and 2. Barefoot , Linear 1 and Linear 2 etc with drive power memory
27. Built in SO2R interface that can pair 2 X IC7651
28. I dont mind paying for the above with option license keys! Keysiight R&S Option 0001 to 01000!
29. HP/Agilent/Keysight style bumpers and protectors for the radio so you can stack stuff on top while protecting the paintwork
30. Fan filters for smoke and dust etc
31. A patch panel that mounts to the top of the radio that brings all the connections from the back to the front of the patch panel.
32. Class D 5 watt Audio amp with low inband IMD and distortion
33. A clean headphone driving chain since it will be a direct sampling receiver.
34. 2 tone generator along with white and pink noise sources for TX testing
35. Ability to key amplifier relay system regardless of voltage without a amp buffer.
36 12 hour voice recorder with ability to save recorded files to a SD or USB stick or in the radio
37. Phase coherent receivers
38. Touch/capacitive electronic CW key input
39. Ability to select 2 paddles
40. Give one free to every ham
Máximo, supongo que en el título se te olvidó el "5". En eHam.net hablan del mismo con supuesta referencia IC-7651.
Creará tanta expectación como el IC-7300 ??? Veremos.
EA7OC, Luis
EC5M reaccionó
#299452  - 13 agosto, 2016 17:48
Vendo Flex-6500
Sin estrenar.
:woohoo:
EA5BZ
#299453  - 13 agosto, 2016 18:02
Esta claro que del 12 al 40 es puro humor, sino leer bien....
Ruben Navarro Huedo
EA5BZ
EA1YV
#299351  - 13 agosto, 2016 18:38
Trae 144 Mhz?
Trae 70 Mhz?
EA5BZ
#299352  - 13 agosto, 2016 19:14
EA1YV escribió:
Trae 144 Mhz?
Trae 70 Mhz?
Si ... Y te rasca la espalda en los pile ups ;)
Rubén - EA5BZ
http://somehams.org
Ruben Navarro Huedo
EA5BZ
EA7FGJ
#299457  - 13 agosto, 2016 19:27
Solo 70 MHz.... Agustín.... de 144 MHz no hablan nada.... ;)
EA1YV
#299353  - 13 agosto, 2016 20:37
Pues yo estoy muy contento con el 7600 ,para mi va lo suficientemente bien como para no cambiar sino aporta 144. A esperar.
EA7FGJ
#299459  - 14 agosto, 2016 04:58
Agustin, tú tienes equipos excelentes! claro que toca esperar, seguramente esto es un globo... pero no tengo dudas que tarde o temprano saldrá el sucesor del 7600.
Si valdrá la pena cambiarlo o no, no lo se, siempre que haya un poco de propa estaremos ahí con el equipo que sea.. de esto no tengo dudas. ;)
EA1YV
#299354  - 14 agosto, 2016 07:06
No sé, francamente Máximo, me he llevado una ligera desilusión con el 7300.
Creí que iba a ser un salto espectacular en recepción sobre lo que ya tenía y la verdad....
Hoy en día parece que nos están inculcando la idea de que si no es SDR lo anterior ya no sirve.
#299465  - 14 agosto, 2016 07:21
Agustín, yo ya lo dije hace tiempo, que sea SDR no quiere decir que sea mejor.
Hay colegas que al leer "SDR" piensan que ya es mejor a todo lo que tienen, y no, no es así.
Si no me equivoco, tu tienes un K3, creo que lo habías comentado.
El K3S es el mejor equipo que hay en el mercado (junto con el IC-7851, Hilberling, y poco más).
Tienes que irte a un Flex-6500/6700, un Anan o similares para encontrar un SDR a la altura del K3S y del IC-7851.
Todo lo demás estará por debajo.
Lo del IC-7300, era de esperar, por eso algunos teníamos (y tenemos) la curiosidad de saber cual es el ADC, ya que eso marcará hasta donde puede llegar.
Es un magnífico equipo, hace muchas cosas, recibe bien, pero es lo que es, nada más.
EA7FGJ
#299466  - 14 agosto, 2016 11:39
Ínclito Agustín, tu desilusión es algo obviamente muy subjetiva. Te dicen que es el sucesor del IC-7200 y te esperas un salto espectacular..... No lo sé, de verdad que creo que es muy complicado ser fabricante. La clientela es muy difícil. ;)
EA7FGJ
#299471  - 14 agosto, 2016 14:02
En el FB de Icom, dicen que faltan unos días para presentar su nuevo equipo.... No solo el walkie....
EA7AAF
#299355  - 14 agosto, 2016 16:08
Fran, EA7AAF
EA5XA
#299356  - 16 agosto, 2016 07:25
No pone nada de que se pueda sacar la señal de vídeo ¿verdad?...
73 EA5XAmadeo
EA7FGJ
#299523  - 16 agosto, 2016 10:26
No lo sé, Amadeo, en la wish list se mezcla la realidad con la burla. Pero seguramente tendrá muchas cosas que el 7300 no trae.... Faltan sólo 4 días para saberlo. Un pelin de paciencia que ya veremos lo que nos quieren vender . :laugh:
EA5XA
#299357  - 16 agosto, 2016 10:40
Sí sí, no hay "ansia", ya veremos en unos días lo que trae, pero vengo observando, que las salidas para un monitor externo, se van a los tope gama con independencia de la marca...¿tanto costará hacerle una "salidita" para tener las cosas grandes en un monitor?, aquello del IC-7000 debió ser un experimento...
73 EA5XAmadeo
EA5S
 EA5S
#299535  - 16 agosto, 2016 11:15
Es posible que me pase por la Ham Fair el sábado, si al final puedo y hay algo de verdad en esto, os iré informando.
Duncan JA/EA5ON
minima maxima sunt
http://ea5on.blogspot.com.es/
www.facebook.com/EA5ON
EA5XA
#299358  - 16 agosto, 2016 11:30
Estaremos atentos a lo que nos cuentas Duncan.
73 EA5XAmadeo
EA2J
 EA2J
#299359  - 16 agosto, 2016 13:27
Es evidente que el futuro de la radio está en la tecnología SDR de muestreo directo. Lo importante es valorar qué es lo que aporta para tomar decisiones y no sufrir decepciones como la de esperar que un IC-7300 pueda superar a un K3S. Las falsas expectativas se manifiestan con humor.
Desde un punto de visto de la eficiencia prestaciones::costo, está claro hacia dónde vamos:
- En el primer nivel en torno a los 1.500 euros se ha colocado un equipo (el IC-7300) que tiene una serie de prestaciones que en su conjunto son muy superiores a los equipos híbridos (superheterodinos + SDR) de su mismo precio.
- Es lógico que ahora se cubra el segundo escalón y es de esperar que ese segundo escalón se sitúe entre los equipos que tienen un costo de 3.000 euros (que creo que es poco más o menos el precio de IC-7600) y como el listón que ha puesto el IC-7300 está muy alto el salto tiene que ser significativo.
Vendrán detrás, sin duda, los restantes escalones en el futuro, bien sea de la marca que ha lanzado el IC-7300 o de la competencia japonesa o Yanky, pero EMHO el principal avance es el de reducir los costos de producción en igualdad de calidad y prestaciones que lo deseable será que se traslade al precio final de los equipos.
73, Enio
EC5M reaccionó
Página 1 / 15
