KENWOOD TM-D710E Y ...
KENWOOD TM-D710E Y TS-2000
EA3IN
#6576  - 13 octubre, 2009 05:27
¿Es posible utilizar el frontal del KENWOOD TM-D710E con un TS-2000?
Parece como si el del TM-D700 y el RC2000 fueran compatibles.
EA7EE
#81869  - 13 octubre, 2009 09:42
Hola!
"Owners of the Kenwood TS-2000 series radio may want to acquire the optional RC-2000 detachable face for mobile operation. The Kenwood TM-D700A transceiver detachable front face is compatible with radio models mentioned above. TM-D700A radios with serial numbers 212XXXXX or above will work as a remote display with the TS-2000 series without modification. TM-D700A radios with serial numbers 211XXXXX and below will require modification.
Due to the required parts and service cables needed, modifications can only be performed at one of our factory service centers. The cost will be $65.00 plus return shipping costs.The RC-2000 kit comes with RF chokes that are attached on each end of the control cable. If you use the TM-D700A detachable front face to control the TS-2000, with a standard control cable PLEASE use optional RF Choke/Toroid Cores. Wrap it around the control cable on each end to eliminate any stray RF interference to the control panel.
You can obtain RF Chokes/Toroid Cores from MFJ or Radio Shack."
Encontrado con el google en 5 segundos.. Viene a decir que si, pero solo a partir del numero de serie 212XXXXX. Te recuerdo que si tienes Internet y no entiendes ni papa de Inglés te estas perdiendo el 90% de nuestro hobby..
EA7EE
EA3IN
#81868  - 13 octubre, 2009 18:12
Hi Manolo,
Thanks for your effort but you can notice that this Kenwood service note talks about the TM-D700, not the D710E. Any further help will be appreciated.
73's and thanks again.
BTW: This post was published via my internet connection.
EA7EE
#81925  - 13 octubre, 2009 18:54
I'm sorry.. Si es verdad, un pequeño numero de diferencia.
He buscado como seguramente habrás hecho y no he encontrado nada. El Panel frontal de la TM-D710 se vende suelto como RC-D710 para que se lo pongas a casi cualquier transceptor de la marca y lo conviertas en APRS "compatible", eso significa que el modem está en el panel y no en el transceptor, luego se puede pensar que el panel es un diseño nuevo y no es compatible con el RC-2000.
Sin embargo, habrá que preguntar a KENWOOD para confirmarlo.
EA7EE
EA7QQ
#81870  - 14 octubre, 2009 23:22
Hola Marcel yo tego el ts 2000x ,y 710E y lo eprobado y funcina y hace todas las funcines como canbiar de frcuecia .tener una sola frecuecia o las dos tambien puedes hacer aprs. almeno todas la las funciones.
Bueno ya mediras algo .Amigo Marcel un saludo 73 :cheer: :cheer:
EA3IN
#82003  - 15 octubre, 2009 10:16
Pues gran notícia.
¿Hablamos del 710E, el nuevo verdad, que se puede comprar actualmente?
¿Conectas el frontal del 710E al TS-2000 con el cable RJ a ambos lados y aparece los mismo que con el RC-2000, puede mover el dial, encender y apagar, etc....?
La idea que es que el RC-2000 cuesta más de 300 EUR y por un poco más ya tendría el frontal y un equipo APRS.
Ya me dirás
EA7QQ
#82031  - 15 octubre, 2009 11:01
hola buenos días perdona me equivocado me refiero TM-700E . NOSE QUE ESTAVA PENSANDO pero va bien con el 700 hace todo como dije antes, yo creo que el 710 sera lo mismo. a demás el ts 2000 ya tiene la tnc , el frontal creo que no lo lleva perdonar amigos pero repito con el 700E, por lo que se el 700E y el 710E son casi lo mismo lo que tiene algunas funciones mas. por lo que e visto y oído por lo que dice la gente, bueno por mi parte va muy bien hace todo lo que dices ct.
bueno un saludos
