HPSDR
Página 9 / 26
EC5APB
#148602  - 12 mayo, 2011 20:06
En cuanto al regulador de 5 V, está la variante 78T05CT en encapsulado TO220 de 3A
#148642  - 14 mayo, 2011 08:40
Lo de lo reguladores de 5v, no se los precios pero creo que sale más barato comprar tres 7805 que uno solo de esos de 3A.
Pero bueno, cada uno va mirando la solución que más se le adapte.
A todo esto, para el que no lo haya visto.
Ya ha salido el firmware v1.3 para la Metis.
Metis V1.3 will be available for download from 12:00z.
I have added a sequence number to the wide bandscope data and Joe, K5SO, has
modified the Atlas bus connections that interface to multiple Mercury board.
Up to four, phase locked, Mercury boards can be used which will enable some
interesting experiments with phased receiving arrays etc.
You can use V1.3 with a single Mercury board or multiple receives within the
same board. If you are using multiple Mercury boards then please wait for an
annoucement regarding updated Mercury code from Joe before loading V1.3.
I've updated the 'Metis- how it works' documentation and the Verilog source
code is also available.
Feedback as usual via the reflector please.
También salió esta semana el PowerSDR 1.19.3.4 en versión definitiva, no beta. Ya se puede descargar del SVN.
Everyone,
PowerSDR/OpenHPSDR 1.19.3.4 has been moved to released status today. You can
find it on the svn server at:
svn://svn.openhpsdr.org/svn/repos_sdr_hpsdr/trunk/W5WC/PowerSDR_HPSDR_1.19.3
/bin/Release
A Big Thanks goes out to the many users who shared their ideas, feedback,
and time testing the modifications made to this version. I would like to
especially thank Hans, DL2MDQ for not only all his countless hours of
testing and feedback but also being the focal point for our many friends in
Germany. And Roland, F8CHK for sharing his modifications with everyone.
Below is a list of the bigger changes made. The svn log for the beta release
contains a more detailed list.
-Added a S-Meter reading to the multimeter. This was written by Roland,
F8CHK.
-Added controls to the transmit display.
-Added the collapsible display "ported from PowerSDR IF-Stage". This has a
larger display and minimal controls on the screen.
-"Auto Mode Switch" is functional.
-ALC can be disabled for testing purposes.
-ALC overshoot problem resolved.
-Space Bar Control added with 4 selectable functions.
-Level adjustments, Frequency readout, and Pulse generator added to the
"Tests" tab.
-Added VOX capability to VAC.
-Able to tune down to 1Hz.
-Separated 60 meters channel display between the US & UK regions.
73, Doug W5WC
#141741  - 14 mayo, 2011 14:17
TNX, Maximo, lo acababa de ver en la lista de correo, una cosa cuando bajo los archivos como en este caso del PowerSDR con el SVN, me salen una serie de carpetas, pero no me sale el ejecutable, bueno imagino que habra que copmilarlas con el Visual Studio .NET 2003, segun pone en el "Readme" que acompaña a los archivos pero ni idea de como hacer esto. El software no es mi fuerte.
He intentado calibrar la "Penelope" pero no puedo me da un error, y no se a que puede deberse, y no encuentro donde ponga la manera de hacerse, al igual que en el manual de la "Metis" o de la "Mercury" si que esta explicado el proceso de calibracion en esta no lo esta. Bueno aparte de esto, si nos fiamos del medidor interno de la tarjeta, esta entrega un maximo de 392mW en SSB, que yo le haya visto, esprimiendo mucho el micro, es decir sibando y con la ganacia de micro y el procesador, bueno tambien es cierto que es un electrec de PC, pero que no tendria por que no valer. En FM uno 50 mW.
En teoria debia de dar 500mW, imagino que en SSB, en FM tambien imagino que menos, pero no tan poco.
Por cierto que el paso final de la tarjeta son dos operacionales de para alta frecuencia, y por lo que he visto quitando la FPGA lo demas es simple entre comillas de reparar.
#148840  - 14 mayo, 2011 18:27
Dentro del SVN hay una carpeta llamada bin y luego release, o algo así. Allí está todo lo que necesitas copiar a tu carpeta destino, y listo.
No hay nada que compilar, ni instalar ni nada. Solo copiar y pegar.
En esos archivos que copias ya está el ".exe".
#148864  - 14 mayo, 2011 18:29
Se me olvidaba, asegúrate de que el firmware es el corercto para esa placa.
Lo digo por que no vaya a ser que pase como con la Mercury y que sea Penelope-EU, y necesite firmware de Gerd...
Máximo
#141742  - 15 mayo, 2011 10:30
TNX, Maximo, pues si no se como me he podido liar tanto con esta chorrada. Bueno ya esta instalado, aunque no se instala, y configurado a mi gusto, difiere algo con el anterior y para mi gusto va mejor, mas fluido, no sabria explicarlo pero sin duda me gusta mas este, lo he probado esta mañana en 15 mts recibiendo un concurso y para mi gusto va de cine.
Respecto a los reguladores de tension, yo personalmente prefiero poner uno de 3A a hacer combinaciones, imagina que los tres no dan la misma salida y tienes que meter diodos en serie con las tres salidas, la tension ya no son 5v es menos, bueno pones en los terminales de masa del regulador unos diodos iguales a los anteriores y sube la tension, pero ya empezamos a complicar, por el precio que tienen tampoco en un proyecto de estos merece la pena, ademas son integrados mas modernos. Tambien he pensado en poner un circuito que supervise la tension de las salidas y en caso de no ser correcta corte la alimentacion y genere un aviso, no vaya a ser que la liemos si se va un regulador.
#148931  - 15 mayo, 2011 15:25
Yo también voy a poner un "supervisor"...
Este;
[img] [/img]
En el hueco del CD de la caja nueva MicroATX.
#141743  - 15 mayo, 2011 19:16
HI HI HI, bueno he pensado que como parece ser que las tensiones negativas no nos hacen falta, al menos para el uso normal, por que parece ser que los los -12 son para las comunicaciones 232, solo voy a poner +3v3, +5v y +12v, si algun dia hacen falta los -12 para algun tema de carga de software por rs232, pues se conecta temporalmente la fuente del PC y punto.
Asi de este modo se puede eliminar el uso del transformador y generar las tensiones partiendo de los 13,8v que tenemos en los cuartos de radio, eso si para generar los 12v a partir de 13,8 se hace imperativo el uso de reguladores LDO, es posible que con 13,8 en lugar de 12 tambien funcione bien pues me parece que las placas llevan sus propios reguladores pero no quiero arriesgarme, ademas no lo he comprovado en los esquemas al 100%.
EA3GUG
#148497  - 16 mayo, 2011 14:25
EA1DDO escribió:
A todo esto, acabo de pedir una caja para meter todo y que quede más curioso.
He pedido la siguiente caja, a ver si os gusta;
Buenas,
Ya lo tengo funcionando gracias a una fuente que me han dejado, que soporta 5A a 5V.
Lo siguiente es buscar una caja.
He visto esta integración que aúna PC + Hpsdr en la misma caja, no parece que haya que mecanizar nada.
http://openhpsdr.org/wiki/index.php?title=A_complete_HPSDR_transceiver
La caja es esta:
http://mihtpc.blogspot.com/2008/05/la-caja-antec-nsk-2480.html
http://www.mashardware.com/index.php?/Articulos/Review-de-la-caja-Antec-NSK2480.html
Es posible comprarla p.ej. aquí:
http://www.modpc.com/index.php?pageid=pagtienda&op=vart&ref=CB87#verart
EA3GUG - David - Mataró
EA3GUG
#141744  - 16 mayo, 2011 22:06
Hmmmm,
Creo que voy a pasar de integrar un ordenador con el SDR, aunque sería interesante para tener un SDR "portátil", me voy a decantar por tenerlo separado.
Creo que me voy a pedir esta caja, que tiene 4 slots traseros para sacar tarjetas:
Comparada con Pandora:
pandora
31 x 22 x 13,4
ancho profundo alto
Maxinpower
28,5 x 38 x 23
Aquí la venden:
http://tiendaactual.com/torre-b289ca0000-alimentacion-480w-p-3653.html
#141745  - 17 mayo, 2011 07:28
Hola, Maximo, a ver si te vale este spliter para conectar las dos radios:
http://www.lz2gl.com/data/antenna/schematics/Antenna_Splitter_1_60mHz_20091127.pdf
#149215  - 17 mayo, 2011 09:45
David, a mi me llegó ayer la caja "MicroATX" pero por mucho que es "micro" resulta que es un cajón del carajo. Me caben dentro dos o tres HPSDR.
No se si quedarme con ella y mirar más adelante si aprovechar el espacio para meter una placa de PC, o que hacer.
David, te vendo mi caja nueva...
Pedro, el splitter, supongo que cualquiera sirve, el tema es el aislamiento entre bocas y la atenuación.
Como sabes, donde me encuentro no tengo facilidad de cacharreo por lo que necesito las cosas lo más listas para usar posible.
Ahí el Mini-Circuits es el mejor.
Más adelante me haré con uno. Primero voy a acabar lo de la caja.
#141746  - 17 mayo, 2011 14:49
Buenas, detectado un fallo en la tarjeta "Penelope", como sabeis me llego hace unas semanas y despues de jugar con ella y probarla un poco he visto que no da la potencia que debe, en la lista de correo tambien han salido comentarios al respecto, bien tras el correspondiente mosqueo he empezado a investigar sobre T2, incluso hay un comentario en el manual de la PennyWhistle, que hace referencia a este trafo en el que se comenta que los sintomas son una falta de potencia en concreto una salida de 250mW max, bueno, pues como las placas de Gerd no traen serigarfia, con el esquema en una mano y la PCB en la otra, he verificado que el componente esta girado, con lo que el primario esta en el lugar del secundario y viceversa.
La reparacion ya esta hecha, pero aun no he tenido tiempo de probarla cuando lo haga os comento, tambien he sacado unas fotos que colgare.
#149263  - 17 mayo, 2011 19:16
Pedro, por fin encontraste el fallo. Ya nos enseñarás las fotos a ver como es eso.
Habrá que avisar a Gerd de que tiene un robot zurdo :woohoo:
Yo empecé presentar y ver como voy a colocar todo en la caja nueva.
Primero necesito hacer un taladro y hacer unos agujeritos nuevos a medida de la Atlas. Supongo que para la fuente también.
Como la caja es de esas que tiene como dos pisos y se abre a la mitad, estaba pensando en usar solo la parte de abajo, sacar la de arriba y hacerle una tapa nueva más pequeña. Pero lo haré mas adelante.
A ver si mañana consigo un taladro y empiezo a sujetar todo.
EA3GUG
#149291  - 17 mayo, 2011 20:30
[OFF TOPIC ON]
Máximo, te veo haciendo el equivalente a esto con el HPSDR (o como montar y desmontar una radio operativa en 1 minuto) 😆
[OFF TOPIC OFF]
Disculpad el off topic :whistle:
#149306  - 18 mayo, 2011 08:54
Muy bueno !!
No lo conocía.
EA3GUG
#149346  - 19 mayo, 2011 18:19
Argggghhhh!!!! :blink:
El Vsp Manager, es incompatible con el el Microham Microkeyer II :( .
Si instalo el VSP, me deja de funcionar el urouter.exe (prog. de gestión del Microham), y si reinstalo el Microham, deja de funcionar el VSP.
El tema es que los dos crean puertos virtuales, el VSP para mapear entre 2 puertos, y el Microham, para poder tener varios puertos con los que atacar la radio (ICOM 7400).
Seguro que ambos modifican alguna parte del sistema operativo (dll) y uno machaca la del otro.
No se si esto va a tener solución, porque necesito ambos, uno para el mapeo de puertos, y el otro para que el Ham Radio se conecte a la radio Icom y/o al HPSDR, así podré hacer una comparativa de filtrado en señales PSK (justo lo que iba a hacer ahora).
Si a alguien se le enciende la bombilla que me lo diga, pero me temo aquí va a haber "tomate", es decir, tendré que reinstalar sw según quiera una cosa u otra (lo cual limita la comparativa en tiempo real)
#149550  - 19 mayo, 2011 18:56
David, no entiendo bien esto;
El HRD ya tiene incorporado una utilidad para hacer puertos virtuales. Incluso puedes abrir dos HRD y conectar cada uno a radios distintas (Icom y PowerSDR por ejemplo).
También hay una utilidad para que sin hacer puertos virtuales, varios programas puedan conectarse al mismo dispositivo. Por ejemplo varios HRD a un solo PowerSDR.
La utilidad se llama Omni-Rig;
http://www.dxatlas.com/OmniRig/
Mira el DDUtil también;
http://k5fr.com/DDUtil.htm
Yo no los he llegado a probar, pero otros si.
#141747  - 20 mayo, 2011 07:11
Buenos dias, Maximo puedes explicar como conectar el HRD al PowerSDR sin utilizar un progarma exterior sin VSP. Me parece muy interesante.
Por cierto la modificacion que le hice a la Penelope no ha funcionado ahora da menos potencia aun (125-150 mW), y la cosa es curiosa, por que si uno cje el esquema de la mencionada placa ve que el pin Nº 1 va a la antena a traves de un condensador y los Nº 4 y 6 van al operacional de salida, y segun me la mando Gerd venian al reves, es decir los 4 y 6 iban al conector de antena y los 1 y 3 iban al operacional de salida, esto sumado a que la placa no daba los 500 mW indicados sino unos 250 en las mejores condiciones y en ssB y unos 9 en FM, me hizo pensar en un error de montaje, de hecho si nos fijamos en la foto del manual de la penelope el famoso transformador este montado al reves de como me lo envio Gerd y como yo lo deje pero esta claro que asi va peor, aunque como dije no va bien del todo de la otra forma. voy a seguir con el ampli de 15 w, si con esa potencia me da plena salida de momento no me preocupare mas del tema, si no habrá que ver que esta pasando de inmediato. Habrá que mirar los niveles de entrada en el ampli final.
Ya os cuento, 73.
EA3GUG
#149702  - 20 mayo, 2011 09:57
Igual me equivoco, pero cuando defines que PowerSDR use un puerto, éste se queda abierto y no es posible engancharse a él, desde otro programa. Entiendo que necesitas un mapeador para hacer que puedas enganchar el puerto del PowerSDR con el del HRD, me explico con un ejemplo:
- Creo dos puertos virtuales, COM20 y COM19, le digo al VSP que los interconecte.
- Conecto el PowerSDR y le digo que use el COM20
- Conecto el HRD y le digo que use el COM19
Al estar mapeados, lo que se envía por el 19 llega al 20 y viceversa.
El problema que tengo es que el Microham, también me crea puertos virtuales para acceder a la radio (ICOM), p.ej. un puerto de CAT (Com2), un puerto de PTT (Com5),... Por lo visto los dos no coexisten, el urouter (microham) y el VSP Manager, entiendo porque parchean el sistema operativo de la misma manera.
Lo he solucionado temporalmente sin el VSP Manager, abriendo 2 dm780, y haciendo que uno ataque la tarjeta de sonido del Microham, y el otro ataque la entrada de línea, que he cortocircuitado con la salida de altavoces, no he encontrado la manera de que el PowerSDR con el VAC, saque la salida por la entrada de línea, por tanto la he hecho sacar por los altavoces, y a partir de ahí la recirculo por la entrada de línea.
Ahora sólo me falta calcular el offset entre la frecuencia del VFO de la Icom, y la que figura en el SDR, no estoy seguro de si este offset cambia al cambiar LSB/USB, ayer estuve buscando al mismo corresponsal en PSK en el powersdr+VAC y en la ICOM, y me salían alrededor de 2,2khz de desplazamiento, pero tengo que mirarlo mejor, no se si es normal, o podría corregirlo calibrando el powersdr de alguna manera (o el HRD), se que en la FT-897 se puede hacer.
Página 9 / 26
