Pues eso amigos alguien sabe si el Kenwood TM733 tiene la funcion de repetidor?:huh:
Y si es así:woohoo: , alguien podría echarme una mano a configurarlo?????
Sólo tengo el manual en Inglés y no encuentro nada al respecto..........Nu sé...:S
Gracias a todos..........
Un "Cantabrón"
EA1GGJ.David.
Adjunto las modificaciones que hay para ese equipo, en donde viene puesta la del repetidor cruzado.
Por si te sirve de algo.
Xavi [file name=tm733_mod.zip size=15025] https://www.ure.es/wp-content/uploads/wpforo/default_attachments/media/kunena/attachments/legacy/files/tm733_mod.zip [/file]
19-07-1998 Cross Band Repeating
Cross band repeat isn't documented but comes ready from the factory.
To enable cross band repeat from the front panel, first select a band by pressing
BAND SELECT. Then, change the control to the other band by hitting [CONT SEL].
Next, press [F] for one second, then the "X" button (far right side). Decimals will
appear between the Kilohertz digits, and the "ON" indicator will light momentarily.
The microphone sequence to enable cross band repeat while in remote control mode is
"DC".
The transmitter hang time can be toggled between 500ms to 0ms by turning on the
radio with [LOW] pressed. They also recommend enabling the Time-out Timer, for
obvious reasons.
Note that the TM-733 can also be used as a "one-way" cross-band repeater.
For example, if you can receive a distant repeater with your HT, but have difficulty
getting into it, you can use the TM-733 to boost your transmitted signal. To set this
up, just omit the part where you "change the control to the other band by pressing
[CONT SEL]." Doing this will setup the TM-733 to repeat your signal to the other
band, but will not retransmit the distant station back to you. If this sounds ambiguous,
play around with it a little and it will begin to make sense.
Este es el documento original de la Kenwood sobre este equipo y tema.
Como te quejes de la info es para darte con un martillo.
Xavi [file name=aan_0009.pdf size=77092] https://www.ure.es/wp-content/uploads/wpforo/default_attachments/media/kunena/attachments/legacy/files/aan_0009.pdf [/file]
Por el momento el TM 733 solo hace en una dirección cros band, si los modelos americanos/canadienses lo pueden realizar yo lo ignoro.
Si hay alguien que lo conozca... muy agradecido.
saludos Juan
Joder Juan, de todo lo que he puesto parece que no has leido nada, mira en el pdf de mi último mensaje porque yo sí le he hecho el repetidor de banda cruzada, tanto en una sola dirección como bidireccional, mira el boletin de kenwood del cual te pongo un extracto de lo primero que se puede leer. Y yo tengo un TM733E modelo europeo, comprado en España.
The TM-733A is capable of operating as a “cross-band repeater.” Two different repeater modes are available: Bidirectional cross-band repeat; and fixed direction repeat mode.
Verificado, y actua, cuanto le odio al 733.
saludos Juan
Hola de nuevo, ante todo muchas gracias Xavi por toda la info:blink: . Lo modifiqué y en efecto funciona como repe en banda cruzada y además bi-direccional:woohoo: , useasé, una pasada, para cacharrear cerquita de casa con el walky y estar con los colegas de siempre en QSO:) . Repito, muchas gracias por todo. Es una pena que no pueda trabajar como repetidor en VHF-VHF, sería ya la leche.......El caso es que haciendo los pasos en VHF-VHF o lo que es lo mismo (V2) si que se activa el repe, pero no funciona:( ........según tu último archivo en pdf sólo se puede hacer trabajar en banda cruzada, aún así todo, está muy bien.
Ah! Juan no lo odies tanto que el "juguete" está muy bien........un poco de botón por aquí.........otro poco por allá...........y ya está....hi.........hi.
Saludos. EA1GGJ-DAVID
