FLEX-1500 el QRP-SD...
FLEX-1500 el QRP-SDR
Página 4 / 10
EA4AON
#114307  - 29 julio, 2010 11:43
Segun un OM que lo ha comprado tiene estas características:
FA-SDR-Transceiver' updated 02-June-2010
I/Q-based low-power and low-cost HF SDR transceiver kit published and provided
by the German 'Funkamateur' ham radio magazine
The German ham radio magazine 'Funkamateur' in it's editions October to December 2009 published
an I/Q HF allband transceiver design which, after some delays due to parts availability, is available as
a kit now (June 2010).
The design and kit looks quite 'inspiring' especially for those ham radio fellows who have never touched the
SDR grounds so far, however do have expertise in assembling kits and add-on building blocks themselves
and also can cope with the possible challenges of an SDR as far as PC/Software etc. know-how is concerned.
The kit and add-on blocks are provided at quite reasonable cost.
Click here in order to see more details/pictures of the kit's components.
Brief technical description:
In short, the kit consists of a 'mother' PCB where all SMD parts have been populated already by 'the factory'.
THT (through hole) devices still need to be soldered to the PCB.
The local oscillator is based on the Si570 chip (no AD DDS chip!), is a separate module and needs to be ordered
specifically ('FA-SY 1'). This oscillator as well as other functions of the TRX are controlled via USB from the
associated PC/Notebook.
The mixer architecture is based on the Tayloe Zero IF QSD principle which is quite popular e.g. from the
Flex-Radio SDR-1000 transceiver times.
On RX, the antenna signal goes through a manually tuned pre-selector. The pre-selector sports a post-amplifier
in the form of an SGA5289 chip. There are means of inserting a 0, 6 or 12db attenuator pad on RX.
On TX, the TX mixer signal goes through the same pre-selector and amplifier stages as on RX, with the exception
of the attenuator circuitry.
The TX signal then goes either directly to the RX/TX switch-over relay (some 10 mW of driver power), or goes to
the 1 watt linear amplifier module (if included). For this purpose 2 jumpers need to be set appropriately.
There are no additional Low Pass Filters included for the TX signal. Therefore appropriate LPF's may need to be
added by the user, certainly if an outboard amplifier is driven by the little SDR TRX.
The TRX motherboard has a row of interconnections for the optional plug-in 1 watt TX amplifier board.
The linear amplifier uses 2x RD00HHS1 MosFET devices in push-pull. BIAS voltage for the final transistors can be
adjusted individually.
Connecting lines to the PC/Notebook are done via USB and for the I/Q signals via line-in and line-out
of the sound card.
Software:
In order to get the little SDR TRX running, appropriate Software needs to be installed on the PC or Notebook.
The FA-SDR-TRX construction manual recommends "Rocky" or "PowerSDR" and gives examples for installation
and settings.
Language support of the docu:
To my knowledge, at present (June 2010) there is only a German language assembly manual available.
However, if there's some noticeable demand by foreign, non-German speaking users, I'd assume that the vendor may
possibly come up with an English language version of the assy manual. But please: don't take that as guaranteed!
It's just my guess!
Claimed performance data:
The claimed performance data look quite promising (source: 'Funkamateur' 10/2009):
Frequency range: 1.7 to 30 MHz
Additional ranges: 6m and 2m, if appropriate RF pre-selection and amplification is added by the user
MDS 80m: -123 dbm (@ 500 Hz BW)
MDS 10m: -127 dbm (@ 500 Hz BW)
IP3: > +15 dbm
IMDR3: > 90db
Pout (with plugged-in optional amp): <= 1 watt
TX IMD(3) at 1 watt: -35 dbc
TX IMD(3) at 10 mW: -50 dbc
Spurious emissions at 1 watt CW output:
image: -60 dbc
carrier: -65 dbc
other spurious: -50 dbc
sideband surpression:
w/o software optimization: - 35 db
with software optimization: - 70 db
Summary: (update 13-Jan-2010)
As per it's specs this little kit plus add-ons is not going to be a "killer" Contest radio
or competitive alternative to e.g. a Flex5k or HPSDR etc.
That doesn't seem to be the target at all, as far as my understanding goes.
IMHO, the target is to provide a simple to build, low-cost (very affordable) basic I/Q SDR
transceiver platform in order to take the first steps (and more) in SDR-based technology
on all HF bands.
For more Details on the "FA-SDR-TRX":
Please see DH1TW's webpage here.
Y aquí unas fotos del contenido del kit:
http://www.dk3qn.com/wfsdr01_FA_SDR.htm
Le faltaría los 6m del Flex1500 y un lineal pero por 225€ (todo incluido) está bastante bien.
Javier EA4AON.
Javier - EA4AON
EA4IS
#115121  - 29 julio, 2010 12:16
¿Este último kit de 225 eur es posible comprarlo montado?¿Solo es soldar o requiere ajustes?(supongo que tendrá ajustes aunque sean básicos)
Es un precio muy interesante
http://ea4is.ure.es
EA5WO
#115122  - 29 julio, 2010 13:10
Con la tecnología actual SMD. se tiene que ser muy hábil, con cierta experiencia e instrumentos adecuados para aventurarse en este tipo de montajes. Que a buen seguro también requieren de cierto nivel en la electrónica. Siempre que da lo grato de haberlo montado uno mismo. Pero si no se tiene el tema demasiado claro hay que valorar si merece o no la pena el desembolso. Atrás quedaron los entrañables Saleskit de montar sirenitas, rogerbeeps y emisores de FM..
Suerte y saludos. EA5WO
European ROS Club (ERC)
(AWARD Manager)
EA7EE
#115124  - 29 julio, 2010 13:29
Hola!
Respecto a kit SDR hay la tira.. solo tienes que buscar con el google, yo si tengo tiempo montaré este monobanda australiano, todo componentes normales y bastante asequible: http://www.genesisradio.com.au/G40/
Incluso hay equipos comerciales con salida IQ, como el Alinco DX-R8, pero solo vas a ver unos 48KHz de ancho de banda con una tarjeta de sonido "normal".
También hay modificaciones para RX practicamente para todos los transceptores. Yo tengo modificado el TS2000 y apenas puedo ver unos 20KHz de ancho de banda. Colocando la "toma" antes de los filtros roofing puedes ver algo más pero no es la mejor solución.
EA7EE
EA4FSD
#114308  - 29 julio, 2010 13:57
Hola a todos. KB9YIG, el creador del SoftRock40 tiene unos kits de un RX todo band HF, con la opcion de poder construirlo para recibir desde 180 KHz hasta los 3 MHz. Es el SoftRock RX Ensemble II, por 56 dolares y un TX/RX para 160, 80 y 40, o 30, 20 y 17, o 15, 12 y 10 metros con salida 1W por unos 75 dolares.
Yo ayer pedi un kit de receptor, para probar y adentrarme en el mundillo de los SDR.
La pagina donde se pueden pedir los kits es:
http://www.kb9yig.com
Y en esta otra, estan detallados los montajes, esquemas, ajustes etc.
http://www.wb5rvz.com/sdr/
Ya os contare, estoy impaciente por recibirlo y empezar el montaje.
Javier
EA4FSD
EA1856URE
Javier
EA4FSD / EA1856URE
72, 73 y buen DX!
#114309  - 30 julio, 2010 09:09
El Ensemble II puede RX desde 180KHz a 3MHz o desde 1.8-30 MHz, que sólo has puesto el rango de LF
#114310  - 30 julio, 2010 09:51
Hola, bueno a mi me gustaria que fuese multibanda, y que se pudiese ver una buena porcion de la banda que se este trabajando, si no el SDR pierde una parte importante de sus ventajas, que aparte de el tratamiento digital de la señal, en cuanto a filtros y demas, pues es el hecho de poder visualizar la banda, ya lo comentabamos al principio. Es la posibilidad de no solo oir sino de ver.
Por otro lado el saber que tipo de software puede correr con el es importante, ya que se trata de eso radio definida por software, en este aspecto ando algo confuso, ya que veo que a diferentes SDR les "aplican" diferentes softwares, p.e. el PowerSDR de flex radio, que por lo poco que he visto es junto al de perseus el que mas me gusta, este ultimo mas aun, aunque solo para RX.
El tipo de conexion al PC creo que tambien es importante ya que esto determinara que tenga mas o menos prestaciones, la conexion por audio a una targeta de sonido, lo veo un poco de compromiso.
Asi que si alguien esta puesto si me gustaria que me orientase en este sentido y que incluso se huciese una tabla, con los campos de:
Bandas cubiertas, software que puede usar, tipo de conexion al PC, etc.
Respecto al tema de la potencia, a mi personalmente, no me importa que sea poca, ya que soy aficionado al QRP y ademas me interesa principalmente por la Rx, pues estoy estudiando sacar la señal de Rx de mi TS140s y asi darle una nueva vida. Ademaas un equipito pequeño para acompañar a mi portatil en los desplazamientos seria ideal.
El montaje en SMD en particular para mi no es problema, ya que estoy acostumbrado a el y tengo utillaje.
Bueno disculpad el LP, a ver si entre todos sacamos en claro cual es el que mas nos conviene.
EA5WO
#115218  - 30 julio, 2010 09:59
Todo el potencial del SDR radica en su software y toda la I+D que hay detras de cada equipo SDR.
Si no existe software para el circuito o es muy básico de poco o nada te sirve ese bonito circuito. Ya sabemos lo de lo he montado yo y tal.. esta muy bien.. pero son sobre 200 euros. y el tema del software con equipos SDR es un tema fundamental.
He visto funcionar el FlexRadio 1500 va de maravilla. Utiliza todo el potencial del PowerSDR. El mismo software que sus hermanos mayores. Su precio lo veo muy razonable. Es una excelente opción para entrar con buen pie en el mundo del SDR.
Descarta que el circuito de kit te funcione con el software del FlexRadio o del Perseus. Ni te molestes en probarlo. Aunque asi de memoria. No estoy seguro pero creo que los softrock antes mencionados si son compatibles con el powersdr.
Saludos. EA5WO
(AWARD Manager)
EA4FSD
#115216  - 30 julio, 2010 11:16
El SoftRock RX Ensemble II, puede recibir todas las bandas de HF, desde los 160 hasta los 10 metros. Pero se puede construir para el rango de LF en lugar de HF, sustituyendo los valos de los componentes de los filtros y reprogramando el oscilador local mediante software.
Javier
EA4FSD / EA1856URE
72, 73 y buen DX!
EC1DLH
#114311  - 2 agosto, 2010 14:42
hola a todos
Quiero comentar un par de cosas sobre el tranceptor FA-SDR-Transceiver que cita ea4aon
todos los componentes SMD ya vienen soldados de fabrica
el software a utilizar es el powersdr o tambien el rocky
mencionar tambien, que este tranceptor trae un preselector variable muy parecido al que utiliza la casa
Hilberling en su tranceptor pt8000
con respecto al tranceptor flex 1500
si bien es cierto que utiliza el mismo software que sus hermanos mayores flex-3000 y 5000
en ultima instancia es el hardware lo que predomina
un saludo
juan
https://ec1dlh.blogspot.com/
EA5WO
#115487  - 2 agosto, 2010 16:54
Gracias por la información. Muy interesante.
Me doy cuenta que he ido de pardillo y me han timado los americanos con más de 3500 euros comprando el Flex-5000. Cuando con 200 euritos tenia lo mismo, más y mejor.
De los errores se aprende. Voy a ponerlo en subasta en Ebay a partir de 1 euro y me quito el trasto este de encima.
Saludos. EA5WO
(AWARD Manager)
EA1S
 EA1S
#115004  - 2 agosto, 2010 19:15
EA5DOM escribió:
2) Todos tenemos ya un Tx/Rx para HF convencional. Lo mas económico es usarlo combinado con un receptor SDR. Para hacer esto ni siquiera hace falta poner un conmutador externo de antenas ya que dentro del transceptor ya tenemos un conmutador de antenas. Solo hay que sacar la señal de Rx hacia el receptor SDR con una pequeña modificación
Hola, me he hecho con un receptor SDR y queria combinarlo con un ICOM 756PRO3, me interesaria saber cual es esa pequeña modificacion o que otra posibilidad tengo para utilizar el receptor SDR a la vez que el PRO3 con la misma antena y que no sea el conmutador exterior, tambien me vale si conoceis mas conmutadores que el Woodradio del que ya se ha hablado ...73
🅴🅰1🆂▁ ▂ ▃ ▄ +𝟲𝟬𝗱𝗕
𝗠𝗮𝗿𝗰𝗼 𝗘𝗔𝟭𝗦 - 𝗘𝗔𝟭𝗦𝗕 📡
EC1DLH
#114312  - 2 agosto, 2010 22:45
hola a todos
pascual
si lo pones en Ebay ponlo en la opcion de COMPRALO YA 1 EURO
hi hi
para quien no puede o no tiene 600 euros en el flex 1500
hay otros tranceptores que estan a buen precio como el FA-SDR-Transceiver que cita ea4aon (200 euros)
y que estan muy bien diseñados, el preselector es mucho mejor que cualquier filtro pasabanda,
eso si, hay que ir sintonizandolo cada pocos kilociclos como el drake r4c
y si aun por encima trabaja con el software powersdr pues mejor
los detalles del preselector son estos
http://openhpsdr.org/wiki/index.php?title=ANICETUS
venga un saludo
juan
EA4ERZ
#114313  - 2 agosto, 2010 22:57
a ver que es eso que hay que sintonizarlo cada pocos kilociclos, esplicamelo porque ando detras de un sdr y no quiero meter la pata despues de que voy a comprar la IF 2000 para el yaesu ft 950.
sabes algo de este kit en concreto el fa sdr trx.
dependiendode tu respuesta asi tendre que hacer.
yo creia que estos kit enchufabas y listo a recibir en todas las bandas de HF
o sea tipo LP PANADAPTOR que vale poco mas
EC1DLH
#114314  - 3 agosto, 2010 00:13
hola
este tranceptor utiliza un preselector variable
en vez de utilizar un filtro pasabanda por ejemplo de 7.0 mhz a 7.2 mhz fijo
utiliza uno variable que solamente tiene unos pocos kilociclos de ancho de banda
por ejemplo 25 khz en comparacion a loa 200 khz de un filtro pasabanda
el que trae este sdr esta formado por dos transformadores de relacion 1:9 50/5.5 ohms mas el correspondiente circuito L-C
(cuanta mayor sea la transformacion mas selectivo es pero tambien aumenta la perdida de insercion)
por lo tanto si tu estas en 20 metros en 14.318 mhz escuchando un dx
en 14.175 mhz ya tienes una atenuacion de 6.8db y en 14.080 mhz tienes una atenuacion de 10 db
imaginate este tipo de filtro en un contest
aqui te dejo un link http://www.bavarian-contest-club.de/projects/presel/presel.pdf
este es el unico sdr que trae este preselector variable
los demas traen filtros pasabanda
por un precio de 200 euros tener un tranceptor sdr con esta caracteristica esta muy bien
eso si no es un equipo para competir con los flex 5000 ni tampoco icom 7800
pero para empezar con los sdr esta bien
el IF 2000 para el yaesu ft 950 lo desconozco
se que es adactador panoramico con visualizacion de 190 khz
pero poco mas
un saludo
juan
EA5DOM
#115500  - 3 agosto, 2010 01:27
Vaya tela como se esta poniendo este hilo de los SDR !!
Un par de dias sin conectarme y esta al rojo vivo
Para EA1SB. El tema de la modificación para utilizar un SDR como receptor y un equipo convencional como TX, en tu caso el ICOM 756
Se trata de sacar fuera del ICOM la señal de antena DESPUES del conmutador interno de antenas y filtros paso-banda. Hechale un vistazo al manual de servicio del ICOM y busca en el diagrama de bloques el punto en el que la señal de la antena se aplica al receptor antes del primer paso de amplificador de entrada o mezclador. Una vez localizado busca en los circuitos el punto mas adecuado para "interceptar" esta señal.
En mi caso un Yaesu FT-897 la señal de antena viene de la placa que contiene los pasos finales y conmutadores de antena. De ahi sale un cable coaxial hacia la placa del receptor y otro independiente al transmisor. He conectado el Perseus al coaxial del receptor y funciona perfectamente recibiendo mientras que cuando aprieto PTT el Yaesu transmite normalmente.
Hay un problema con el audio y es que el receptor SDR sigue estando activo mientras se transmite, por lo que te puedes monitorizar. El problema es que todos los SDR tienen un retardo bastante acusado comparado con los receptores convencionales. Es como escucharse a traves de satélite con retardo. Resulta incómodo y en CW ni te cuento. El Perseus lo soluciona con un squelch de máximos. El squelch se configura para que una señal a partir de S+ active el squelch y bloquee el audio. Con otros SDR habria que bloquear el audio del PC a partir de la señal de PTT
Y por ultimo. Para poder seguir utilizando el receptor del ICOM se pueden hacer dos cosas. En el punto donde sacamos la señal de antena RX podemos poner un rele controlado desde fuera que nos sirva para derivar la señal al SDR o dejarla hacia el ICOM. Otra opción es un splitter que divida la señal y la mande simultaneamente hacia el SDR y el ICOM.
En el caso del Yaesu la entrada de señal al receptor no es solo para HF sino también para V y UHF asi que la opción del splitter no la veo muy viable. De momento lo he conectado directamente dejando el Rx del Yaesu inoperativo.
Otro asunto es la sincronización via CAT del SDR y del Tx convencional. Eso ya es "pa nota" ;)
73 de Luis
URE BENIDORM
ea5dom@ure.es
Postales no, gracias
#115525  - 3 agosto, 2010 09:25
Como ya comenté anteriormente, estoy preparando un artículo sobre este tema ya que aunque todos sabemos lo principal, hay muchas otras cosas que está bien conocer.
Por otro lado, el que quiera un SDR de última generación y máximo rendimiento... le aconsejo el siguiente.
Yo voy a pedirme uno para mi.
Es lo más potente que hay y más barato que la gran mayoría.
Es un proyecto abierto en el que está participando gente de todo el mundo. Es lo máximo que hay hoy en día en prestaciones y además es modular, por lo que cuando salgan mejoras no hay que tirar con todo, solo la parte que uno quiera.
Otra cosa, también transmite. Incluso va a salir ahora una versión comprimida llamada Hermes.
Para comprarlo se hace en http://www.tapr.org/
Además hay muchas placas para añadir prestaciones pero con sólo dos placas, las Mercury y la Magister, y la base llamada Atlas, con esas tres ya funciona (en Rx) y luego uno le añade todo lo que quiera.
Otro detalle, funciona con el PowerSDR de Flex, aunque hay otros programas disponibles, incluso en Linux y Mac.
EC1DLH
#114315  - 3 agosto, 2010 10:12
Hola Maximo
me parece que tienes que añadirle la placa HPSDR - LPU power supply
es un magnifico receptor, con unas caracteristicas muy buenas
hace poco estuve a punto de comprarlo, tenia en mente entre este y el flex
al final me compre el flex, pues la placa de tx llamada penelope no estaba a la venta
y al parecer tampoco esta ahora
sabes algo de esta placa maximo ?????
un saludo
juan
#115560  - 3 agosto, 2010 10:32
Hola Juan,
La placa de Tx la pondrá a la venta pronto Gerd, DJ8AY en su página y en la de E-Bay;
http://www.hpsdr.eu/Baugruppen/Penelope.htm
http://shop.ebay.com/red_ella/m.html?_nkw=&_armrs=1&_from=&_ipg=&_trksid=p4340
Creo que enviándole un correo-e ya te informa.
Ya tiene a la venta alguna cosa para el HPSDR.
Un detalle es que este HPSDR, no es un producto comercial listo para enchufar y usar. Es un proyecto abierto de experimentación SDR. De todas formas, si uno compra esas dos placas y la base, con eso ya puede empezar a funcionar, se baja el PowerSDR y listo. Luego en el foro de HPSDR se puede participar en la mejora del equipo.
Se me olvidó el tema del precio;
Hacerse miembro de TAPR....20 €
Atlas......................26 €
Mercury...................250 €
Magister..................110 €
LPU (opcional).............30 €
Total.....................436 €
(Más gastos de envío).
EA1GFY
#114316  - 3 agosto, 2010 12:22
Hola, para los que les interese, esta mañana he mirado la página de venta del softrock y estan disponibles unidades del softrock tanto del RX como del RXTX.
http://www.kb9yig.com/
Y para los que necesitan un poco más de potencia para este montaje, que en el artículo de la revista de URE de este mes no aparece esta también este kit que da 10w.
http://www.qrp-shop.de/200/cgi-bin/shop.dll?SESSIONID=0626067966455594&AnbieterID=1
Y una página de un colega frances, F6EHP, que utiliza la configuración softrock(la versión 6.3) + QRP-PA 2008
http://www.lbp.fr/ham/sdr.htm
Un saludo cordial, 73´s de Antonio, EA1GFY.
http://ea1gfy.blogspot.com/
ea1gfy@gmail.com
Logroño(La Rioja) DME:26089
Página 4 / 10
