Como resetear Exper...
Como resetear Expert 1K-FA Amplificador Lineal
#27526  - 5 abril, 2014 17:24
Alguien sabe que botones hay que tocar para el reset en el Amplificador Lineal SPE Expert 1K-FA
Para restablecer todo y empezando de nuevo como si se tratara de una nueva puesta en marcha.
Carlos EC1T
Ex. EA1DVY
Soria in81
EB5AGV
#249660  - 5 abril, 2014 22:51
Extraído del foro del Expert en Yahoo, un comentario del gurú de estos equipos, Bob W5UQ:
There is not a factory reset "per se". You can, however, reset the ATU memories.
Sometimes our ATU settings may not be what we want and we want to start over. Resetting them gets them back to where they were when shipped from the factory.
This is all in the 1K FA manual:
Just go into "SET/ANTENNA" and in this menu, set all numbers to "NO". To where there are no numbers, just all NO's. Then save it.(highlight SAVE and push SET) The ATU is now reset.
First of all, before changing to a "NO", it might be a good idea to record the numbers on a sheet of paper so you can put the ANTENNA numbers back. However, you probably know the numbers of the antenna output connectors by heart anyway.
You can also reset only one band or one antenna setting. Which ever "number" you SET to NO and save, will be reset. Then you go back in and put the number back in for the antenna you chose to be there.
Of course, now you will need to go through the SWR settings on each sub band setting that you may use on the air, for it to memorize the settings again.
Bob Hardie
W5UQ
Como ves, RESET completo no existe.
73 JOSE EB5AGV
73 JOSE - EB5AGV
http://agvradio.com
http://jvgavila.com
#249667  - 6 abril, 2014 07:57
Pues vaya olvido.
Yo creo que todo aparato con microprocesador y memoria, debe tener un reset de reinicio mínimo y a mayores un reset para ponerlo como cuando viene de fabrica.
Deberían ir mirando la idea de ponerlo. Además, si no me equivoco, todos los procesadores tienen una pata de reset. No se si yendo al procesador se podría provocar en este caso.
Una anécdota.
Hace cosa de una semana mi hija pequeña estuvo tocando los sensores de la tele. Me pasé un buen rato luego intentando sacar lo que ella puso en pantalla... nada, lo sacaba, grababa la configuración, pero volvía.
Tuve que buscar en internet como entrar en el modo oculto de programación y hacer un reset de fábrica, no el normal.
