Ayuda con torre tel...
Ayuda con torre telescópica...
EA1HLH
#2218  - 17 noviembre, 2008 16:03
Hola,poseo una torre telescópica de 14 metros de altura pero no tengo las características de la misma.Por eso,si alguien tiene una similar,le agradecería que me envíe una copia del papelito con las características.
email: et054@hotmail.com
Doy las gracias de antemano,saludos cordiales.
https://ea1hlh.es
EA1HLH
#53102  - 18 noviembre, 2008 10:32
:whistle: :whistle: :whistle:
https://ea1hlh.es
EA6Y
 EA6Y
#53183  - 18 noviembre, 2008 23:40
En la pagina web de US tower tienes el PDF de cada tipo , seguro que alguna sera muy similar,
The TMM-433SS has a maximum height of 33' without mast and a minimum nested height of 11' 4." This tower consists of 4 sections, the top one being 10" and the bottom one being 18." For rotor information, the inside diameter of the top section is 5 9/16." This tower weighs 315 lbs. It comes standard with a hand winch, hinged base, anchor bolts (1" x 27" long), a rotor plate (approx. down 4' inside the tower) and an 8' mast.
The average wind load ratings for the TMM-433SS are as follows:
70 MPH Winds -- 8 sq. feet; 75 lbs.
50 MPH Winds -- 20 sq feet; 150 lbs.
To see the diagram for the foundation for this tower, please click here.
The TMM-433SS retails for $2,358.00
We do have several accessories that can be used with this tower:
CX-4 Coax Arms
IV-16 Inverted Vee
TRX-80 Raising Fixture
MRF Mast Raising Fixture
MD-75 Motor Drive
MDP-750 Motor Drive, if installed at the factory (the MDP-750 requires the purchase of either the MCL-100 Limit switch Package or the RMC-1000 Remote Control)
There are a variety of masts that can be used if you prefer something other than the standard M-8:
M-5 -- 5 ft. Mast
M-10 -- 10 ft. Mast
M-15 -- 15 ft. Mast
M-15R -- 15 ft. Reinforced Mast
The TMM-433HD is a heavy duty version of the TMM-433SS. It has the same minimum and maximum heights with 4 sections. The sections are bigger, though. The top section is 12 1/2" and the bottom section is 21 1/2", giving an inside diameter for your rotor of 7 1/8" in the top section. This tower weighs 400 lbs. It also comes standard with a hand winch, hinged base, anchor bolts (1 1/8" x 27" long), a rotor plate (approx. down 4' inside the tower) and an 8' mast.
The average wind load ratings for the TMM-433HD are as follows:
70 MPH Winds -- 21 sq. feet; 150 lbs.
50 MPH Winds -- 51 sq feet; 250 lbs.
The TMM-433HD retails for $2,856.00
The same accessory list applies to this tower, as well:
CX-4 Coax Arms
IV-16 Inverted Vee
MD-75 Motor Drive
M-5 -- 5 ft. Mast
M-10 -- 10 ft. Mast
M-15 -- 15 ft. Mast
The TMM-541SS has a maximum height of 41' without mast and a minimum nested height of 12.' This tower consists of 5 sections, the top one being 10" and the bottom one being 21 5/8." For rotor information, the inside diameter of the top section is 5 9/16." This tower weighs 430 lbs. It comes standard with a hand winch, hinged base, anchor bolts (1 1/8" x 27" long), a rotor plate (approx. down 4' inside the tower) and an 8' mast.
The average wind load ratings for the TMM-541SS are as follows:
70 MPH Winds -- 12 sq. feet; 50 lbs.
50 MPH Winds -- 35 sq feet; 150 lbs.
The TMM-541SS retails for $3,096.00
These accessories can be used with the TMM-541SS:
CX-5 Coax Arms
IV-16 Inverted Vee
MD-75 Motor Drive
M-5 -- 5 ft. Mast
M-10 -- 10 ft. Mast
M-15 -- 15 ft. Mast
LOCATION, LOCATION, LOCATION,
´73 de EA6Y
EA1HLH
#53247  - 19 noviembre, 2008 00:30
Muchisimas gracias,creí que nadie me respondería...
Me ha servido de mucho la información,ahora,espero que le sirva a Teleco...
saludos cordiales y muchas gracias.
https://ea1hlh.es
EA6Y
 EA6Y
#53249  - 24 noviembre, 2008 19:31
De nada ! Espero que te sirva ;)
´73 de EA6Y
EA3GOA
#53654  - 25 noviembre, 2008 22:21
Te he enviado correo electrónico.
73's cordiales
EA3GOA
MANUEL JOVER CONDE
VILAFANT (Girona)
EA1HLH
#53743  - 26 noviembre, 2008 13:51
EA3GOA recibido el email,te respondo por la misma via.
Muchas Gracias,73'sss
https://ea1hlh.es
