Ailunce H2S
Ailunce H2S
EA3AZL
#347887  - 18 mayo, 2020 05:24
He visto imágenes del Ailunce H2S con dos salidas de antena y otras imágenes con una sola salida de antena.
Me puse en contacto con Ailunce y me confirmaron que la última versión sólo tiene una salida de antena y no dos.
Deberíamos aclararlo por si alguien decide comprar el equipo y se lleve una sorpresa.
Juan EA3AZL
Ailunce H2S
Este tema fue modificado hace 5 años por EA3AZL
73, Juan, EA3AZL
EA3AZL
#347965  - 19 mayo, 2020 21:12
Ailunce HS2
Ailunce HS2 HF VHF UHF SDR Transceiver
HS2 is an ultra-portable full-frequency full-mode SDR radio. Receive frequency coverage 300K~1.6GHZ. The built-in network port can realize remote operation and remote firmware upgrade. The HAM-BOX mobile app we developed allows the mobile phone to easily control and play radio stations(the app is still under development, any progress we will post on ailunce website). HS2 adopts a full keyboard design, built-in Bluetooth module, sound card module and serial communication port module. Full support for currently popular radio control software and logging software. We are working hard to give you more playable space.
Function Feature:
1. Real-time spectrum.
2. Waterfall chart.
3. Doppler frequency tracking(under development).
4. Using software-defined radio technology (SDR), full-band support SSB, CW, RTTY, AM, FM.
5. Double frequency conversion circuit structure.
6. IF width and IF shift hardware and software can be modified to provide powerful IF interference suppression.
7. DSP digital noise reduction.
8. Built-in 160-6m high-speed automatic antenna tuner.
9. Built-in electronic key controller, all parameters can be set flexibly.
10. Built-in sound card with IQ and audio output.
11. Built-in FLASH memory(under development).
12. USB TYPEC3.1 interface for power supply and computer connection.
13. High accuracy TXCO ± 0.5ppm (-10-60 ℃).
14. Ultra-wide working voltage range: 5-32VDC.
15.Power Reversed Polarity Connection Protection
16. Built-in GPS / Beidou, GSM, electronic compass (acceleration, angle sensor) (optional)
17. GPS time (requires optional GPS module).
18. Built-in UTC clock.
19. Voltage display.
20. Unique LORA data transmission (requires optional LORA module).
21. Ultra-light weight: ≤1KG
22. Built-in network port, support remote firmware upgrade(under development).
Configuration
HS2 Technical Data
Transmitter Parameters
Transmitter Architecture SDR
Transmission Mode SSB, CW, RTTY, AM, FM
Frequency Resolution 1Hz
Transmit Frequency Range*1 1.800-2.000,3.500-3.900,5.351.5-5.366.5, 7.000-7.200, 10.100-10.150, 14.000-14.350, 18.068-18.168,21-21.450,24.890-24.990, 28-29.7,50-54, 144-146, 430-440MHz
Output Power HF+6m:SSB(1~30W),CW(0.1~30W), FM(0.1~30W), AM(1~5W), VHF: SSB/CW/FM(0.5~5W) UHF:SSB/CW/FM(0.5~5W)
Power Consumption TX:13.8V~5A RX:13.8V~0.25A(Normal),0.35A(Max brightness&Highest audio)
Carrier Suppression <50db
Spurious Suppression 1.8—54MHZ: ≥50db 144—146MHZ: ≥60db 430—440MHZ: ≥60db
Memory Channel 999
Receiver Parameters
Receiver Architecture SDR
Receiver Mode SSB, CW, RTTY, AM, FM
Receive Frequency Range 300KHz-1.6GHz*2
IF Bandwidth 20KHz
IF 12KHz
Sensitivity*3 SSB/CW:(BW: 2.4kHz @ 10dB S/N) 0.18uV(1.8—54MHZ), 0.25uV(144—146MHZ), 0.25uV(430—440MHZ) AM:( BW: 6kHz @ 10dB S/N) 15uV(0.3—1.8MHZ),
Standard Configuration Option Configuration
FM module GPS module
Bluetooth module LORA module
Bluetooth microphone Electronic compass module
Built-in sound card Wired microphone
Built-in automatic antenna tuner Shortwave balcony antenna
Built-in memory External frequency wheel(under development)
2uV(1.8—54MHZ), 2uV(144—146MHZ), 2uV(430—440MHZ) FM:(BW: 15kHz @ 12dB S/N) 0.5uV(28.0—29.7MHZ), 0.25uV(50—54MHZ), 0.3uV(144—500MHZ), 0.5uV(430—440MHZ)
IF Suppression ≥70db
Image Suppression ≥80db
Audio Output Power 2W (10% distortion rate, 8Ω load, 3KHZ)
Antenna tuner parameters
Tuning frequency range 1.8-54MHZ
Tuning impedance range 16.7Ω--150Ω unbalanced (SWR is better than 1: 3)
Tuning accuracy VSWR: 1: 1.5 or less
Tuning time 2-5S (full segment 10S)
Tuning method Automatic / Manual
Spectrum parameters
Spectrum bandwidth 48K
RF Spectrum FFT
Structural parameters
Size 170X120X45mm (excluding protrusions)
Weight <1KG
Working voltage parameters
Voltage range 5—32V receiving range, 5-12V transmit power limit, 12-18V full power output, 18-32V transmit power limit.
Antenna interface
Antenna interface TNC/BNT/M/N (optional)
Working environment parameters
Working temperature -10 ℃ to 60 ℃
Working humidity 10% -- 90%
Note *1: Frequency range is different according to different countries or areas, the actual frequency
by local legal provisions.
Note *2: Data retention.
Note *3: to be calibrated, the final interpretation of all manufacturers.
73, Juan, EA3AZL
EA3AZL
#347980  - 20 mayo, 2020 04:27
He preguntado en Ailunce y me responden que el equipo no tiene la función Scaner.
Sorry, we don't have the scanner.
73, Juan, EA3AZL
