Los usuarios de este fabuloso programa estamos de enhorabuena, despues de mucho tiempo parados en la version 1.65D, ha salido una nueva version de este programa gracias a Dave AA6YQ.
La lista de cambios y mejoras es bastante notoria, aqui os dejo el mensaje extraido de la lista de correo del MMTTY que envio AA6YQ.
El proceso de actualizacion es muy sencillo, hay bajar el fichero .ZIP del siguiente enlance:
http://www.dxlabsuite.com/MMTTY/mmtty166F.zip
Y sustituir el MMTTY.EXE por la nueva version. Si utilizais el motor del MMTTY (engine MMTTY) en una instalacion aparte para algun programa de concursos tambien debereis cambiar ese fichero.
Escribió:MMTTY version 1.66F release note
2008-08-171. Changes to the "MMTTY Setup" window
======================================A. "TX" tab
- renamed the "PTT" panel to "PTT & FSK" (tnx to Joe W4TV)
- added com8 through com16 to the "PTT & FSK" panel's "Port" selector
- clicking a button in the "Input Button" panel from a non-Japanese
locale displays a window entitled "Edit Button" (tnx to Joe WB. "Misc" tab
- the new "Device Identifiers" panel enables independent selection of
soundcard devices for reception ("RX") and transmission ("TX"); any
of 16 input and output soundcard devices can be selected (tnx to Gil
W0MN and Joe W4TV)- selecting an "RX" or "TX" device identifier in the "Device
Identifiers" panel updates the respective "Reception"
or "Transmission" panels shown on the new "Soundcard" tabC. "Soundcard" tab (new)
- the "Reception" panel shows all installed soundcard input devices;
selecting an input device updates the "RX" selector in the "Misc"
tab's "Device Identifiers" panel- the "Transmission" panel shows all installed soundcard output
devices; selecting an output device updates the "TX" selector in
the "Misc" tab's "Device Identifiers" panel2. Changes to the "Radio Command" window
========================================- added com8 through com16 to the "Port" selector
- added 38400 and 57600 to the "Baud" selector (tnx to Joe W4TV)
- named the selector in the lower-left corner "Group"
- modified the contents of the "Group" selector:
renamed the previous "Yaesu HF? (FT-1000MP,...)" entry to "Yaesu
FT 1000D, 1000MP, 920"renamed the previous "Yaesu VU? (FT-736,FT-847)" entry to "Yaesu
FT 736, 817, 847, 857, 897"added a "Yaesu FT 9000, 2000, 950, 450" entry (tnx to Joe W4TV
and Art W2NRA)renamed the previous "Kenwood" entry to "Kenwood, Elecraft" (tnx
to Joe W4TV)- renamed the "Commands" panel's "VFO Polling" selector to "Model",
and added entries for the Yaesu FT 9000, 2000, 950, and 450 (tnx to
Joe W4TV)3. Other notes
==============A. As before, changes made to settings shown in the "Radio Command"
and "MMTTY Setup" windows do not take effect until the window is
closed by clicking its "OK" button.B. To run MMTTY on Vista, either
- install it in a folder other than one in the "c:program files"
hierarchyor
- log into the account named Administrator before installing or
running MMTTYC. 1.66F is a software-only upgrade, meaning that you must already
have MMTTY installed. Updated online documentation is in progress; I
will develop an installer for use with PCs that don't yet have MMTTY
installed. If you want to install 1.66F on a PC that doesn't yet have
MMTTY installed, first install version 1.65D, and then upgrade as
described below.D. To upgrade an existing MMTTY installation to 1.66F, download the
zip archive fromhttp://www.dxlabsuite.com/MMTTY/mmtty166F.zip
The archive mmtty166F.zip contains two files:
mmtty.exe
and
1.66F.txt
Place mmtty.exe in your MMTTY folder, replacing the existing file,
and then run it.The file 1.66F contains a copy of this release note.
73,
Dave, AA6YQ
Juanjo, EA1CJ - SO1CJ
JN99uw
Joer que bien y veo que sigue de gratis, voy aprobarlo ahora mismo. :woohoo:
73 de Óscar - EA4D
https://ea4d.es
EA4URA, ¡Otra forma de hacer Radio!
