Nueva Actualizacion...
Nueva Actualizacion para el FT 2000
EA5WP
#7328  - 1 diciembre, 2009 22:07
Link:
http://www.yaesu.com/downloadFile.cfm?FileID=5123&FileCatID=42&FileName=FT%2D2000%5FPEP2000%5F11%2D30%2D09.zip&FileContentType=application%2Fx%2Dzip%2Dcompressed
Ver. 0150 MAIN CPU implements improvements (also includes all previous updates):
• The FH-2 [] keys are made to increment the frequency at 100kHz up or down.
• CW carrier is corrected to change LSB ⇔ USB when the indication is changed on VFO B.
• Correct the CW Auto Mode.
• DMU Band scope Display Signal Peak Frequency is centered.
Ver. 11.53 EDSP implements improvements (also includes all previous updates):
• The DNR algorithm is not reset between TX/RX, to eliminate the increased receive noise after a
transmission.
• Increase the response of the compression level meter in conjunction with the PROC knob. (Max
up to 12dB).
NOTES:
*Rotate the [METER] switch to select “COM” (Compression). We recommend setting the PROC level within the 5dB
to 10dB range.
*When menu settings are saved on the DMU-2000 CF card and transferred to the new version, some previous versions
may not transfer correctly. Please check your menu, update the settings, and then save the new settings to the CF card.
MAIN CPU
This procedure
