Microham USB device...
Microham USB device router
EA8RM
#391446  - 2 febrero, 2024 12:46
Llevo usando diferentes dispositivos de Microham desde +- 2010.  He tenido que desinstalar y volver a instalar el Microham USB device router y ahora no hay manera de que reconozca el MK2R al conectar el USB al ordenador y en el programa se queda el texto "Please connect a microHam interface to your computer now" en borrado y vuelto instalar todo decena de veces y nada, sigue igual.
Sigo estos pasos cuidadosamente y tampoco consigo que al volverlo a instalar reconozca el MK2R.
1) Configure Router so it does not start automatically (Router ->
Options -> General)
2) Disconnect *ALL* USB devices except keyboard and mouse
3) Uninstall all microHAM Devices (Router -> Device -> Delete)
4) Close Router
5) Uninstall Router using the uninstall option in the microHAM
folder (Windows Start Menu)
6) *RESTART* Windows (do not power off or use "reboot")
7) Download a fresh copy of the Router installer from the download
link at www.microHAM.com
8) *RIGHT CLICK* on the installer and select "run as Administrator"
(for the installer only)
9) when the installer completes, *DO NOT* start Router
10) after the installer completes, *RESTART* Windows again (as a
precaution to force all drivers to be loaded fresh)
11) Connect any *non-microHAM* USB devices *one at a time* and
allow Windows to enumerate/initialize them
12) Start Router
13) Connect any microHAM devices *ONE AT A TIME* and configure
the radio connections (CAT -> SET) *BEFORE* defining or
assigning any virtual ports.
14) When the frequency/mode of the radio is shown in the CAT -> Set
dialog or on the Ports tab in Router, save the radio configuration
to the interface EPROM (Device -> Store as Power-up Settings)
15) Create/Define the necessary virtual ports
16) Assign the virtual port(s) to their functions.
17) Save your Preset
18) Repeat 16/17 for each interface and application that needs a
separate configuration/preset
19) Re-enable automatic start for Router (if you use it).
Si lo pruebo en el portatil me va perfecto, pero en el PC no hay manera, entiendo que los drivers se habran quedado pillados en algun lugar, pero no consigo que funcione.
¿A alguien le ha pasado esto y lo ha podido solucionar?
Gracias por adelantado.
73 de Juan EA8RM / EF8R
EA4AC
#391448  - 2 febrero, 2024 14:12
Hola Juan,
Prueba a volver a un un punto de restauración anterior al actual, por supuesto creando un punto de restauración antes de regresar a uno anterior.
Suerte.
EA8RM reaccionó
EA8RM
#391463  - 2 febrero, 2024 22:35
Muchas gracias por la idea Cedric.
He conseguido volver atras una semana y que me reconozca el MK2R, pero luego no habia manera de que los puertos funcionaran perfectamente y hacia cosas muy raras, despues de pelearme toda la tarde con el, ya va como la seda nuevamente.
Agradecido, saludos.
Esta publicación fue modificada hace 1 año por EA8RM
EA4AC
#391464  - 2 febrero, 2024 22:53
Un placer.
Saludos Juan.
EA3NY
#393643  - 7 mayo, 2024 00:14
Pues molaría saber como lo has conseguido Juan, por que estoy igual que tu ...... Help
Eduardo EA3NY
www.ea3ny.com
www.siemprenavegando.com
www.internetyvoz.com
EA3NY
#393644  - 7 mayo, 2024 00:15
No tengo punto de restauración
Eduardo EA3NY
www.ea3ny.com
EA4AC
#393645  - 7 mayo, 2024 02:19
Publicado por: EA3NY
No puedo creer que no tengas puntos de restauración, Windows crea alguno que otro de manera automática.
07 05 2024 02 18 45
EA8RM
#393656  - 7 mayo, 2024 13:22
Hola Eduardo y Cedric
https://www.adslzone.net/esenciales/windows-10/restaurar-sistema/
Suerte
EA3NY
#393659  - 7 mayo, 2024 13:37
El problema es que no quiero reinstalar un sistema de varios días atrás. En caso de fuerza mayor pues no hay más, pero no quiero perder todo lo instalado, configurado, "logueado" o lo que sea. Espero haberme explicado 😉
Culpa mía por no escribir la frase correcta
Esta publicación fue modificada hace 12 meses por EA3NY
Eduardo EA3NY
www.ea3ny.com
EA8RM reaccionó
EA3NY
#393660  - 7 mayo, 2024 13:59
En resumen. Y para cualquier persona que tenga este problema, el de reinstalar el software que gestiona los MicroHam y que no le funcione. Suele ocurrir en una reinstalación.
1.-Ir a administrador de Dispositivos
2.-Buscar una carpeta que se llame "Otros Dispositivos"
3.-En dicha carpeta, me ha salido "u2R" (Que es mi interface de Microham) con un interrogante
4.-Con el botón derecho darle en "actualizar driver"
5.-Se actualiza y "voila", tema solucionado. Una vez funcionando la carpeta "Otros dispositivos" ya no está
En Ingles por si algún "giri" busca como yo hice con "Please connect a microHam interface to your computer now" y la única búsqueda en todo internet fue la pregunta de Juan.
1.-Open "Device manager" on your computer
2.-Look for a "Other devices" folder
3.-I found "u2R" with a little questionmark on the side.
4.-Right click on your Microham device (in my case is u2R) and select "Update Driver"
5.-I did it and all was ok as before. Once is working again as normal, the folder "Other devices" is not there anymore
As simple as that
Hope that´s help
Esta publicación fue modificada hace 12 meses 2 veces por EA3NY
Eduardo EA3NY
www.ea3ny.com
EA8RM reaccionó
