Tres nuevos satélit...
Tres nuevos satélites
EA7FGJ
#24239  - 26 abril, 2013 09:05
Información obtenida de Amsat-UK
1) TURKSAT-3USAT is a 3U CubeSat (10x10x30cm) and carries a 145 to 435 MHz linear transponder built by the Turkish TAMSAT / AMSAT-TR group for SSB and CW communications.
- Beacon: 437.225 MHz
- Uplink: 145.940 to 145.990 MHz
- Downlink: 435.200 to 435.250 MHz
Further details at http://amsat-uk.org/satellites/turksat-3usat/
2)The Argentine CubeBug-1 is a 2U CubeSat (10x10x20cm) and has an AX.25 packet radio digipeater.
It operates on 437.445 MHz running 1200 bps AX.25 AFSK FM packet radio, callsign LU1VZ-11. Depending on the mode of the satellite the beacons will be transmitted every 10 to 30 seconds.
Further details at http://amsat-uk.org/satellites/cubebug-1/
3) NEE-01 Pegasus a 1U CubeSat (10x10x10cm) built in Ecuador that operates on 910 MHz (an amateur band in some countries). It will operate either a 0.9 watt output 720p HD TV transmitter or a beacon which will send a Morse Code ID, a SSTV image and Ecuador’s national anthem. EarthCam – SpaceCam http://www.earthcam.com/world/ecuador/ecsa/
Further details at
http://amsat-uk.org/2013/04/25/nee-01-pegaus-hd-tv-cubesat/
Esperemos que hoy confirmen los keplerianos y ver si podemos comenzar a utilizarlos. :)
EA6RF
#221861  - 26 abril, 2013 14:00
buena noticia Maximo a ver si los podemos trabajar ya que estamos un poco faltos de sat de fonia
144/432/1'2/2'3/10Ghz
EB1AO
#221862  - 26 abril, 2013 16:55
Hola en la pagina de Mike DK3WN figuran estos datos que me coinciden con los de TLE-NEW 2013-018A 2013-018B y supongo que 2013-018C
TURKSAT
1 12345U 12345A 13116.18500615 .00000000 00000-0 10000-4 0 6
2 12345 98.0372 191.7767 0017397 251.4298 279.4470 14.76467545 04
CUBEBUG
1 12347U 12347A 13116.18500615 .00000000 00000-0 10000-4 0 0
2 12347 98.0563 191.7735 0017556 248.2772 282.5989 14.76251447 03
Salu2 a todos
EA5TT
#221863  - 26 abril, 2013 17:05
Todos los detallesdel TURKSAT, a priori MUY INTERESANTES :laugh:
http://www.tamsat.org.tr/tr/turk-telsiz-ve-radyo-amatorlerine-yeni-bir-ufuk-aciliyor/
A ver si consigo meterle los keps al WXTRACK
Manuel DOM
IM99sl Manises, Valencia.
ea5tt@yahoo.com
EB1AO
#221864  - 26 abril, 2013 22:14
TURKSAT-3USAT Pase de las 23:40 recibido perfectamente desde IN52PE la baliza de 437.225 CW
EA5TT
#221865  - 27 abril, 2013 09:49
Pues ésta mañana en el pase de las 9:33/9:43 UTC... NADA
Y creo que los keps los tengo bien
73,Manolo
Manuel DOM
ea5tt@yahoo.com
EA7FGJ
#221915  - 27 abril, 2013 17:15
esta noche, cerca de medianoche hay un buen pase, con unos 70º de elevación por Sevilla.
Por ende, es una buena oportunidad para intentar escucharlos.
El beacon del TurkSat está en 437.225 MHz y el del CubeBug-1 la bajada está en 437.445 MHz.
Buena escucha.
EA2CDG
#221936  - 27 abril, 2013 19:21
Por si os interesa, tengo datos de los Keps del Turksat3USAT, pasados por alguien de su grupo:
y un enlace donde se pueden obtener/pasar reports: http://www.pa3weg.nl/?id=news
Tiene grabaciones de las balizas.
Iñaki
EA2CDG
EA5TT
#221866  - 27 abril, 2013 20:48
Tampoco nada, ni baliza ni trafico alguno, en el pase de las 20:27 a las 20:37 UTC, y los keps actualizados con los facilitados por el propio TAMSAT :(
O no me entero o .....
73, Manolo
Manuel DOM
ea5tt@yahoo.com
EA7FGJ
#221950  - 28 abril, 2013 06:50
en el pase de medianoche, por mi parte no escuché nada... seguro tengo mal los keplerianos...
En lo de mediodía voy a intentar poner un previo... a ver que pasa....
Buena escucha a todos..
EA7FGJ
#221955  - 28 abril, 2013 09:01
Por las dudas, ¿alguien me puede pasar los keps del TAMSAT?
No tengo las cosas claras con los keps que tengo y quiero tener todo atadito para los pases de mediodía...
EA3B
 EA3B
#221867  - 28 abril, 2013 10:02
Tampoco lo he escuchado
EA3B Xavier (ex EA3EYD)
EA5TT
#221868  - 28 abril, 2013 10:25
éstos son los últimos keps publicados por el propio TAMSAT AMSAT-TR en su pagina de Facebook:
TURKSAT
Son los que tengo en el WXtrack y los he contrastado con la peticion de reportes desde sudamerica ayer... y me coinciden....
"Attention to Argentine Brazil, Venezuela, Peru, Bolivia and Chile Ham Radio Operators: Satellite pass (35 - 51,1) degree. You can track it. The early contact details are appreceated. Thanks... tamsat3usat@tamsat.org.tr"
Un frio escalofrío me recorre la espalda....
Manuel DOM
ea5tt@yahoo.com
EA7FGJ
#221967  - 28 abril, 2013 10:32
hola Manolo,
muchas gracias, pero el orbitron no me lee estos keplerianos... no se el porque.. una sola pregunta, me puedes decir el AOS, por favor? que ando mas perdido que perro de turco en Londres... :P
estoy en el chat de EA7DFH.
EA7FGJ
#221968  - 28 abril, 2013 21:06
en el pase de hoy a las 13:30 Hora Local, no lo escuché, esta noche pasará casi a 90º de elevación, quiere decir, que casi a 700 km de distancia. Si no lo escucho esta noche...... apaga y vámonos :(
EA5TT
#221869  - 29 abril, 2013 13:24
Anoche en el último pase tampoco lo escuché...
Parece que los propios turcos tampoco....
Mala cosa
73, Manolo
Manuel DOM
ea5tt@yahoo.com
EA7FGJ
#221956  - 29 abril, 2013 13:39
Estaba viendo un poco y a lo mejor la baliza está en digital 9600 Baud AFSK... y aquí la cosa se pone un poco más difícil.
Alguien sabe qué potencia tiene la baliza??
EB1AO
#221870  - 29 abril, 2013 16:54
Yo lo recibi el dia 26 en un pase de la noche... en cw perfectamente... desde entonces le sigo los pases que puedo y nada de nada...
Por lo que veo en la pagina de DK3WN en el satblog no tiene nada de el tampoco desde el dia 26.....
:-(, De momento esperando a que haya suerte.... y pueda empezar a utilizarse.
Salu2
EA5TT
#221871  - 30 abril, 2013 17:18
Tienen más moral que El Alcoyano:
Publicado en su página de Facebook
Dear Radio Amateurs,
To save energy in the batteries of TURKSAT-3USAT satellite, unless announced otherwise, we kindly request you to;
1. When following the satellite, especially during daylight passings, concentrate on listening to the beacon signal at 437.225 MHz (with an open squelch, using preamp) only and send the info you have recorded to turksat3usat@tamsat.org.tr , together with time and location information.
2. Do not use the calling frequencies of the transponders (Uplink 145.940 - 145.990 MHz) and do not make any calls (TX) at these frequencies during this time.
3. Continue using existing TLE (Kepler) data in tracking the satellite, unless announced otherwise.
4. We thank all radio amateurs for their kind interest and help in this.
Les ha faltado... KYFC
Keep Your Fingers Crossed ;)
73, Manolo
Manuel DOM
ea5tt@yahoo.com
