LANZAMIENTO SATÉLIT...
LANZAMIENTO SATÉLITE 4M EL 23 DE OCTUBRE
EA1YV
#262908  - 29 octubre, 2014 19:23
Esta tarde me entraba ,unos 415.000 kms.,con -23 hasta que la perdí cuando estaba a unos 15 grados de elevación ,supongo que me la tapaba una montaña.
Es una pena que no podamos seguirla estos días que estará a la máxima distancia.
Lo que me despista es el Dopler positivo si continua alejándose de la Tierra....
EA5DOM
#262909  - 4 noviembre, 2014 12:16
Esto sigue en marcha ! B)
Hello All,
We have a good copy of 4M here in LX.
Steady signals with positive Doppler, 400Hz.
Energy level is good.
73 Ghislain LX2RG
After some days of incertitude, we now have sevral things for certain:
We had a perigee in the night of Saturday to Sunday
We have strong signals in Europe
4M has energy left for another 2-3 days
It appears that the injection during the flyby was much closer to the one of Chang’e 5T1 than the estimated elements after passivation. This led to a return to Earth quicker than expected. Although we had some inkling since Thursday, which show a higher than expected Doppler, it was difficult to sort it out.
We have now (3Nov 1340UTC) a negative Doppler and a quasi stationnary pointing (Az 290°, El 80°), along with strong signals, that lead to the conclusion that 4M is somewehere around 40000km, in an orbit with a inclination of 50°, and with a negative radial speed showing it has not reached its apogee.
Apparently, the Dosimter experiment has stopped functioning. But this may also be normal due to its technological nature, and it may restart.
Sat tuned, and keep on uploading your reports using the 4M data client.
We’ll try to provide TLE as soon as possible using all observations and Doppler.
Thanks to Viljo, ES5PC, Geroge VK4AMG, Rein W6SZ for their help.
Ghislain
EA5FUZ
#263668  - 14 noviembre, 2014 18:28
La carga útil JT65B que completó con éxito un sobrevuelo lunar, ha quedado en silencio después de la transmisión de 438 horas.
Durante la tarde del 10 de noviembre, el voltaje de la batería se redujo de 13.1V a 12,1V y continuó cayendo. La última señal fue recibida por W6SZ Rein a las 01:35 UT el 11 de noviembre cuando el voltaje de la batería se había reducido a 8,4 voltios.
Ghislain LX2RG publicó lo siguiente a la lista de Net Luna:
Aquí en LuxSpace, tenemos que agradecerles a todos por los informes, para el seguimiento, y también esperamos que les hayamos proporcionado los retos que esperaba.
4M, posiblemente, puede despertar de vez en cuando si la iluminación es mejor.
Ahora nos esforzaremos para preparar la siguiente misión.
Manfred Memorial Misión Luna (4M) LX0OHB-4M http://moon.luxspace.lu/blog/
