IR0ISS pronto opera...
IR0ISS pronto operativa en DATV en la S-Band
EA7FGJ
#25371  - 22 agosto, 2013 11:21
Gracias Franco, I4LCK por la info:
"Ancora un GRAZIE all'astronauta LUCA PALMISANO operatore della IR0ISS la stazione SPAZIALE orbitante, che dopo aver citato in numerose interviste l'emozione dei tanti contatti con gli "amici" RADIOAMATORI e le scolaresche, ha installato nonostante i numerosi mpegni di servizio un sistema operativo video inviato con un cargo da KF5LJG Miki altro astronauta...
Non mi dilungo e,a seguire, l'articolo originale ricevuto da ON4WF - ARISS Europa chairman.
Piacevole lettura !:
de Franco I4LCK
HamTV Bulletin 1
August 21, 2013
Ham Video transmitter onboard Columbus
How a DATV transmitter on S-band is being added to the ARISS equipment onboard the International Space Station has been related in an announcement recently circulated and available at www.ariss-eu.org/HamVideo.pdf
The ARISS Ham Video transmitter is presently onboard Columbus. The transmitter was delivered by Japanese cargo spacecraft HTV-4, which launched August 4 and docked 5 days later.
ESA astronaut Luca Parmitano IR0ISS reported that the bags are stored in Columbus. There are two bags: one for the transmitter, the other for the power, camera and antenna cables.
Installation will be done by US astronaut Michael Hopkins KF5LJG who has been trained for the commissioning of the Ham Video equipment.The commissioning is planned later in the year, possibly end October when there are favourable passes over Italy. Indeed, the tests transmissions for the commissioning of the onboard equipment will be received by the ground station of the “Centro di Geodesia Spaziale” of the Italian Space Agency, located in Matera, Southern Italy.
We will report in due time on the commissioning procedure which will involve a series of tests to be performed during 3 or 4 ISS passes.
Possibly, the Ham Video transmitter will transmit continuously between the commissioning steps offering amateur ground stations the opportunity to test and tune their receiving equipment. The transmissions will be performed in automatic mode, without requiring crew time. The camera, which runs on a battery, will not be used and the ground stations will receive a black image.
Meanwhile, commissioning is being prepared steadily. The kick-off meeting took place November 2012 at ESTEC, the European Space Research and Technology Centre, located in Noordwijk the Netherlands. Detailed procedures are examined and finalized during weekly ESA/ARISS teleconferences. A preliminary EST (Experiment Sequence Test) is planned 28-29 August. The test will involve the ARISS ground station IK1SLD, located in Casale Monferrato in Northern Italy.
IK1SLD, which is an ARISS telebridge station often used for educational ARISS school contacts on VHF, has been upgraded for S-band reception. Ham Video manufacturer Kayser Italia has delivered a 1.2 meter dish, a down converter and precision tracking motors, which are part of the ESA funded equipment. For the EST, the station will receive a DATV signal from a local low power S-band test transmitter. The decoded signal will be webstreamed to the BATC server. The British Amateur Television Club offers ARISS free access to their server. ESA examiners will connect to the BATC server and evaluate the reception. Test transmissions at IK1SLD will cover the different frequencies and symbol rates available on the Ham Video transmitter.
Web streaming will take advantage of the special software developed by Jean Pierre Courjaud, F6DZP. References are available in the HamVideo.pdf.
When the Ham Video transmitter will become operational, it will be used for ARISS educational school contacts. Video will be for downlink only. Uplink will be VHF FM audio. The Ericsson transceiver onboard Columbus will be used for reception onboard. This cross band and double mode operation is called Ham TV. Ham Video is the name of the DATV transmitter.
73,
Gaston Bertels – ON4WF
ARISS-Europe chairman
This Bulletin is available from the frontpage of www.ariss-eu.org
This message has been sent by gaston.bertels@skynet.be for lckbo@libero.it."
EA7FGJ
#231712  - 22 agosto, 2013 11:51
Por si a alguien le interesa el blog de Luca Parmitano:
http://blogs.esa.int/luca-parmitano/category/luca-blog/?lang=it
EA7FGJ
#231718  - 22 agosto, 2013 19:05
Para estar actualizado:
https://www.facebook.com/Hamtvproject
EA7FGJ
#231739  - 29 agosto, 2013 13:05
Una herramienta más:
http://iss.astroviewer.net/index.php
EA7FGJ
#232080  - 5 octubre, 2013 16:44
Por mi parte estoy ultimando la estación receptora.
Esto lo que respecta a la parte de ATV.
Para la la baliza en CW que también estará en los 2400 MHz, (la frecuencia es aproximada), usaré un downconverter y un SDR TV TDT en los 562 MHz aproximadamente.
EA7FGJ
#234569  - 12 octubre, 2013 10:59
Estaba pensando para hacer mas comoda la recepción en usar uno de esos satfinder
Satlink WS-6906.
Es bastante interesante porque esta autoalimentado con batería interna y puede enviar los 13 Vcc por el coaxial para alimentar el conversor, (en mi caso usare un Kuhne MKU 123 LNC), y me ahorro, si quiero, unos cuantos dB de perdida del coaxial.
La única pega que le veo es que el rango de demodulación de este aparato es de 2 a 45 Mbps mientras que la ISS transmitirá con un rango de 1.3 Mbps...
A lo mejor vale lo mismo como los receptores DVB-S normales.
¿Alguien me puede iluminar? :)
EA2CRP
#231713  - 19 diciembre, 2013 18:29
Hola! mira esto que te interesa....
http://www.m0dts.co.uk/index.php?tag=2.3GHz
Ya me comentas?..
EA5FUZ
#231714  - 22 diciembre, 2013 20:48
Hola,estoy bastante interesado en el tema ya que tengo todo el material para la recepción,me falta montar la antena y el conversor,supongo que surgirán dudas cuando finalice el montaje,espero que vayamos compartiendo información,un saludo
https://www.facebook.com/groups/satelitesderadioaficionado/
https://www.facebook.com/CanalTeleco/
EA7FGJ
#240563  - 22 diciembre, 2013 22:21
es una solución, pero lo que vale un conversor de 2.4 a 1.5 GHz usado, no se si vale la pena..
Teniendo conocimientos e instrumental seguramente sí.. caso contrario, lo dudo...
EA7FGJ
#240565  - 24 diciembre, 2013 11:15
Ya está todo el material almacenado en el módulo Columbus.
Un problema burocrático hizo que las primeras transmisiones "en blanco" programadas para octubre no pudieron realizarse, y parece que se harán en enero-febrero.
Tenemos un poco más de tiempo para terminar de preparar todo.
EA7FGJ
#240648  - 4 enero, 2014 11:55
Si resuelven los problemas de papeles, para este mes o el próximo iniciarán las transmisiones. Buena noticia!
EA7FGJ
#241466  - 4 enero, 2014 12:19
Esto es lo que necesitaremos para poder ver la ISS:
“This will allow ground stations to test their equipment and to provide useful information concerning the efficiency of the transmitter.” The commissioning transmissions will be carried out with the Ham TV camera turned off, but Bertels said the “blank” transmissions will provide the necessary digital video broadcasting — satellite (DVB-S) protocol signal.
Receiving the DATV signal will be a greater challenge, Bertels has said, adding that DATV decoding should be possible for a ground station equipped with a 1.2 meter dish, when the ISS is within a range of about 800 to 1000 kilometers.” This would limit the DATV reception window to about 3 or 4 minutes during a favorable pass. Once operational, the Ham Video transmitter will be used for ARISS educational contacts with schools in Europe. There are no immediate plans to deploy downlink video for ARISS contacts with US schools, in part because no North American ground stations have been planned.
ARISS-EU says a “simple station” might consist of a helix-fed parabola dish, a low-noise downconverter (such as a High Sierra Microwave Model 2400 or Kuhne Electronic KU LNC 23 TM, or AliExpress HD LNBF), a DVB-S receiver on a computer card (such as the Techno Trend S2-1600), and the free Tutioune software developed by Jean Pierre Courjaud, F6DZP.
El conversor chino es este:
http://www.aliexpress.com/store/product/satellite-S-band-3650MHz-digital-HD-LNBF-for-project-use-for-USA-market/402505_708948984.html
Son € 60 más gastos de aduana si los hubiere y a esperar un mes.
El High Sierra es este:
http://www.hsmicrowave.com/hamtvconverter.html
Del satfinder tenía unas dudas, pero según lo que he podido ver de la transmisión, el rango de demodulación, será de 1.3 a 2.3 Mbps, el satfinder llega a estos valores. Así que me vale.
De las estimaciones hechas, con la parábola de 1.2 m, no hay que echarse las manos a la cabeza y tirar la toalla de primera....
Hagamos dos cálculos y algo sacaremos en concreto:
Dicen que esta parábola vale para una distancia de 800 a 1000 km, y dice también que con esto tendremos de 3 a 4 minutos de Rx.
Pues si tenemos un pase más favorable, las distancias se reducen a menos de la mitad y la intensidad de señal aumenta en forma inversamente proporcional al cuadrado de la distancia que nos separa, por ende, algo ganamos.
Si nos hacemos el iluminador, pues podemos usar una offset de TVSat, de 85 - 90 cm, con el conversor pegado al iluminador, ganamos más todavía.
Por esto, no se vayan a creer que si no se tiene 1.2 m no se podrá recibir nada..
Otra cosa, el conversor de Kuhne gana unos 47- 49 dB, el High Sierra gana unos 40 dB y el chino declara 50 dB por el suyo, que es una burrada! :ohmy:
Creo que lo ideal será hacer algo portable, así sea en la terraza de casa, por eso comentaba lo del satfinder, viene como anillo al dedo.
Recordemos que no solo en economía la primer ganancia es el ahorro, en esto también, cuantas menos pérdidas tenemos, mejor que mejor y como son señales débiles, mejor perder después del conversor que antes, me explico, mejor poner el conversor pegado al iluminador y de ahí cable tipo TVSat al receptor DVB-S a colocar el conversor abajo.
En el artículo dicen que se puede usar una placa para el ordenador, un viejo conversor de los que se usan para los sats de banda X es suficiente, obvio que los analógicos no valen, solo los de DVB-S.
Son muy económicos, alrededor de 20 o 30 €, recuerdo que una vez en el Leroy los vendían por 12 € y compré todos los que había que eran 3... (locuras de cada uno, :unsure: )
En estos caso, está demás decir que un buen sistema de seguimiento es bueno tenerlo a punto.
EA5FUZ
#241468  - 4 enero, 2014 15:05
Hola,tengo casi todo listo,sólo me falta poner la parábola en el mástil,¿se sabe la fecha exacta de transmisión?
EA7FGJ
#241510  - 4 enero, 2014 15:31
no, parece que dentro de los siguientes dos meses....
Los que tengan las cosas, suban fotos de lo que usarán, siempre da ideas nuevas... :cheer:
EA5FUZ
#241512  - 4 enero, 2014 16:22
Bueno voy a postear mis condiciones de trabajo para la recepción,Antena parabólica de 1 metro, http://www.rfhamdesign.com/products/parabolicdishkit/1meterdishkit/index.php
LHCP HELIX dish feed 2.2 - 2.6GHz http://www.rfhamdesign.com/products/parabolicdishkit/dishfeeds/index.php
conversor Spectra http://www.spectra-bv.nl/downconverter.html
Tarjeta receptora PC Technotrend Sl-1600 http://www.technotrend.eu/2959/PC_Products.html
Orbitron para el seguimiento tracking
Y programa para visualización http://www.vivadatv.org/viewtopic.php?f=60&t=214
es en este programa donde tengo mas dudas de configuración.
pongo una foto detalle de la parábola mas el diss feed LCHP.(todavía falta subirla al mástil)
Uploaded with ImageShack.us
EA7FGJ
#241516  - 4 enero, 2014 17:07
El conversor Spectra lo puedes alimentar por coaxial, lo que no se es si lo puedes alimentar por la tarjeta del ordenador.
Menuda instalación! me ha gustado...
Tengo el conversor de Kuhne 23 LNC con FI en 1500 MHz y de ahí al satfinder WS 6906.
Como antena tengo una parábola de 60 cm de G3RUH o bien la Offset TVSat de 90 cm.
Vamos, que no me complicaré la vida, esperaré los pases buenos y a probar.
Todo sobre un trípode, porque intentaré suplir las carencias limitando las pérdidas.
Dispongo de previos, pero creo que en estos casos solo empeorarán las cosas.... será cuestión de probar.
Soy consciente que esto es totalmente diferente, pero recuerdo bien como entraban las señales del finado AO-51 y era una pasada total, entraba hasta con un palo de escoba por antena en 2.4 GHz. :laugh:
Ya subiré fotos de como pondré las cosas.
EA5FUZ
#241520  - 4 enero, 2014 17:21
¿y como ves el tema del software? ya iré haciendo pruebas sobre la alimentación, ¿vas a utilizar el mismo software o utilizas un receptor standard de recepción?
EA7FGJ
#241522  - 4 enero, 2014 17:26
Como Rx en 1500 MHz usare el Satfinder WS6906, es lo más barato que encontré, más que nada para hacer la estación portable.
Esto, lo que tiene de bueno es que también manda tensión por el coaxial...
EA5FUZ
#241526  - 4 enero, 2014 19:31
Me temo que me estoy complicando mucho la vida con el soft en fin es demasiado pronto para todavía,estamos en contacto y vamos exponiendo nuestras experiencias,feliz fin de semana,un saludo :-)
EA7FGJ
#241531  - 4 enero, 2014 22:15
Bueno, no te preocupes, poco a poco, estoy mirando lo de la placa y SW y me está gustando... a lo mejor me animo... :cheer:
Te dejo mi mail porque dentro de poco no podré postear nada por aquí:
ea7fgj@yahoo.es
Seguimos en contacto.
