HA MUERTO AO51
HA MUERTO AO51
EA3B
 EA3B
#15132  - 9 mayo, 2011 17:13
Reproduzco
Mode V/U (J) FM Voice Repeater (QRP): Semi-Operational
Uplink: 145.8800 MHz FM
Downlink 435.1500 MHz FM
Mode V/U (J) FM Voice Repeater: Non-Operational
Uplink: 145.9200 MHz FM
Downlink 435.3000 MHz FM
Mode V/S FM Voice Repeater: Non-Operational
Downlink 2401.2000 MHz FM
Mode L/U FM Voice Repeater: Non-Operational
Uplink: 1268.7000 MHz FM
Mode L/U PacSat BBS: Non-Operational
Uplink: 1268.7000 MHz AFSK
Downlink 435.1500 MHz AFSK
Mode L/S FM Voice Repeater: Non-Operational
May 6, 2011
We are having a difficult time trying to restore AO-51 to operation. Currently, the satellite will not retain the upload of the flight software across eclipse. The batteries are in very poor condition. We have a few more things to try, but with eclipses peaking around July at ~27 minutes, the long term situation is grim. There is a brief period around November where eclipses are as short as 16 minutes, but past that it is a long climb to 30 minutes or longer eclipses for many years. We have no expected "return to service" date. If you have 9k6 digital capability, you can listen in on our attempts at recovery on 435.150 on many passes over the US.
Please support AMSAT-NA and the other AMSAT groups around the world, and help us get new satellites into orbit. Projects like Fox, FunCube, P3E, and Kiwisat need your financial support to keep our amateur satellite fleet flying.
73, Drew KO4MA
AMSAT-NA VP Operations
Pues nada que se le han cascado las baterias y ha dejado de estar operativo, dudan mucho que vuelva a funcionar aunque lo estan intentando. Es posible que solo funcione como FM Repeater en QRP, aunque lo he probado y ni eso.
EA3B Xavier (ex EA3EYD)
EA5HDX
#148276  - 12 mayo, 2011 21:09
Lo curioso es que dicen que han intentado coger el control del sat usando 435.150. Y digo yo, para eso no se usan los enlaces en 2,4ghz???, para el telecontrol me refiero.
73's
EA5HDX Op: Juan Antonio
IM98CC Cehegín
Murcia (ESPAÑA)
EA1NL
#148277  - 17 mayo, 2011 00:36
esperemos que lo recuperen y que otros rindan lo que el 51 .... despachando taxistas lineales y sabe dios que mas...."no hay oscar que cien años dure"....
DE LA MAR EL MERO Y DE LA RADIO.... EL MAFERO
EA5KGD
#149210  - 17 mayo, 2011 09:12
Qué noticia tan mala. Era la "alegría de la huerta".
Gracias por la info.
73,
Kike
Enrique Gil EA5KGD
Almussafes, Valencia - IM99th
Dénia, Alicante - JM08au
EA5DOM
#148278  - 17 mayo, 2011 11:42
Pues con esto las posibilidades de trabajar satélite se reducen aun mas :(
Y lo que hay en perspectiva tampoco parece que vaya muy encaminado a los transponders o repetidores de FM sino mas bien a experimentos que se puedan vender en el ámbito educacional. Es lo que hay y lo que consigue financiación
Al final solo quedara hacer QSOs por rebote en la ISS !
73 de Luis
URE BENIDORM
ea5dom@ure.es
Postales no, gracias
EA5TT
#148279  - 4 julio, 2011 15:17
Despues de una buena temporada sin subirme a ningun pajarillo, ésta tarde acaba de sorprenderme MUY GRATAMENTE el AO-51, tanto por su excelente vitalidad como por la buena correcion de los usuarios, lo que me ha permitido ralizar 8 comunicados y conseguir 3 cuadricula nuevas (la última eleva mi cifra de trabajadas a 275 en ésta modalidad)
Que siga la mejoría del sat y nos traiga nuevas alegrias.
FECHA HORA ESTACIÓN LOCATOR TX RX MODO COMENT. QRB
04/07/2011 14:49 FØFVK JN18IB 59 59 FM AO-51 1065+-
04/07/2011 14:49 SW2HTI KN1ØLO 59 59 FM AO-51 1991 New # 273
04/07/2011 14:51 EA1JM IN7ØJV 59 59 FM AO-51 433
04/07/2011 14:52 OM3WAN JN99JG 59 59 FM AO-51 1868
04/07/2011 14:53 ES5QA KO38JJ 59 59 FM AO-51 2856
04/07/2011 14:55 ES6DW KO37DV 59 59 FM AO-51 2800 New # 274
04/07/2011 15:02 SP5XSD KOØ3SB 59 59 FM AO-51 2250 New # 275
Número de QSOs listados: 8
El amigo Andy, SP5XSD me acaba de enviar un atento e-mail con la descripcion y fotos de su estacion satelital:
"Hello Dom,
Thanks for nice contact via AO51 July 04, 2011 14:57 UTC (22 degr. elev.) 59/57-IM99sl.
My equipment was portable (Weight: 757g only):
1. Transmitting (Uplink): Wouxun KG-UVD1P 5W + Midland RH-770 93cm telescoping antenna (BNC, 1/2 2m / 2*5/8 70cm),
2. Receiving (Downlink): Yaesu VX-5R + home brew EA4CYQ & EB4DKA "CJU" antenna,
3. Recording: Olympus VN-8700PC 4GB digital voice recorder,
4. Navigation: Meteor compass with 85 mm ruler,
and
5. Prediction: OZ9AEC Gpredict software for preparation of pass prints.
Please send me some details about Your equipment on this pass.
Greetings from Poland
73 de Andy/SP5XSD
QTH: Olszewo-Borki, Loc: KO03sb"
Tambien me ha enviado fotos, le he pedido permiso para publicarlas, y es que como yo digo: hace mas el que quiere que el que puede
73, Manolo
Manuel DOM
IM99sl Manises, Valencia.
ea5tt@yahoo.com
EA7P
 EA7P
#148280  - 6 julio, 2011 16:53
Pues le daba por perdido... habrá que estar atentos pues ya hace mucho que no trabajo el AO-51, GRS, 73. :laugh:
EB3JT
#154601  - 14 julio, 2011 12:48
Hombre Manolo TT te has montado en los pajarillos ? yo hace tiempo que estoy QRT en los sats, me cansé de cada día más de lo mismo, al final de tanto esperar el EAGLE y el P3E se me acabaron las ganas de los sats, mi último qso en AO51 fue el 11-12-209 !! y dejé el DXCC en 83 trabajados y 77 confirmados, no tuve narices de poder trabajar más con el panorama de sats existentes :(
Países como Mónaco, Andorra, Vaticano, etc... que los tenemos dentro de cobertura con el sat más pequeño no estan activos y los que lo están el sat "no llega" jejeje...
En fin habrá que esperar más...
73 de Jordi.
EB3JT
