Para el que sea amante de los DX espaciales extremos y pueda, las frecuencias de las Voyager 1 y 2 son:
Spacecraft Coherent Downlink Frequency (MHz) Channel Non-Coherent Downlink Frequency (MHz) Channel
Voyager 1 2296.481481 18 2295.000000 14
Voyager 2 2295.000000 14 2296.481481 18
Voyager 1 8420.432097 18 8415.000000 14
Voyager 2 8415.000000 14 8420.432097 18
Link Polarization
S-band Right circular
X-band TWTA-1 Left circular
X-band TWTA-2 Right circular
Telemetry Modulation
The telemetry comes to the telemetry modulation unit (TMU) separately as a “low-rate”
channel and a “high-rate” channel. Low rate is 40 bps only and its routing through the TMU is
such that it can only be downlinked as uncoded bits. High rate, one of a set of rates between 10
bps and 115.2 kbps, is downlinked as coded symbols. The TMU encodes the high rate data
stream with a convolutional code having constraint length of 7 and a symbol rate equal to twice
the bit rate (k=7, r=1/2).
Either modulator can bi-phase-modulate the telemetry symbols onto either a 22.5-kHz or a
360-kHz subcarrier. A subcarrier is a symmetrical square wave signal derived from a TMU
crystal oscillator that has a nominal frequency of 2.88 MHz. The 360-kHz subcarrier is required
for bit rates greater than 7.2 kbps. The TMU has one modulator for the S-band downlink and
another for X-band downlink. The modulated subcarrier goes to the S- or X-band exciter.7
7 DSN telemetry data bit, symbol, and subcarrier waveform requirements are defined in [10], module 207, 34-m
and 70-m Telemetry Reception.
Para los no versados en inglés:
Modulación de telemetría:
La telemetría llega a la unidad de modulación de telemetría (TMU) por separado por un canal de "baja velocidad"
y un canal de "alta velocidad". La baja velocidad es de 40 bps solamente y su enrutamiento a través de la TMU es
de modo que solo se puede enviar al downlink como bits no codificados.
La alta velocidad, es un conjunto de velocidades entre 10bps y 115.2 kbps, se pueden enviar al downlink como símbolos
codificados. La TMU codifica las secuencias de datos de alta velocidad con un código convolucional que tiene una longitud
de restricción de 7 y una tasa de símbolos igual a dos veces la velocidad de bits (k = 7, r = 1/2).
Cualquiera de los moduladores puede modular bi-fase los símbolos de telemetría ya sea a 22.5 kHz o a una
subportadora de 360 kHz. La subportadora es una señal de onda cuadrada simétrica derivada del oscilador de cristalde la TMU
que tiene una frecuencia nominal de 2,88 MHz. Se requiere la subportadora de 360 kHz para velocidades de bit superiores a 7.2 kbps.
La TMU tiene un modulador para el enlace descendente de la banda S y otro para el enlace descendente de banda X.
La subportadora modulada va al excitador de banda S o X.
Y para aquellos que quieran saber más, las sondas Voyager tienen dos transmisores uno en banda S y otro en banda X. Dos amplificadores,
uno de estado sólido SSA, y otro con un tubo de Ondas Progresivas (TWTA)en la Banda S, y Dos TWTA en banda X un o principal y otro de backup.
El SSA de banda S entrega 6W en Low power y 15W en high power, el TWTA entrega 6.5W en high power y 19W en high power.
El TWTA de banda X entrega 12w en low power y 18W en high power. De las dos unidades TWTA, sólo puede funcionar una a la vez.
Dispone de dos antenas una de alta ganancia de tres metros y otra de baja ganancia.
La de Baja ganancia en Banda S tiene 7dBi y un haz de 60º
La de Alta ganancia en Banda S tiene 36dBi y 2.3º
La Banda X trabaja sólo en alta ganancia con una ganancia de 48dBi y un ancho de haz de 0.5º
Lo cual si hacemos unos cálculos rápidos nos dan que si el TX en banda S y alta potencia entrega 15W y la antena tiene 36dBi
estará radiando 60kW pire.
Y en Banda X si está entregando el amplificador TWTA 19W estará radiando casi 1MW pire.
Cosas...
EA3IO
Manuel Aleu
Gracias por la interesante información.
Añado esto sacado de la Wikipedia.
El 31 de marzo de 2006, operadores de radio amateur del AMSAT en Alemaniarastrearon y recibieron ondas de radio provenientes del Voyager 1 usando una antena parabólica de 20 m (66 pies) en la ciudad de Bochum, con una técnica de integración larga. Los datos fueron comparados y verificados contra los datos de la estación en Madrid, España de la Red del espacio profundo. Se cree que este es el primer intento exitoso de localización del Voyager 1 por aficionados.
https://es.wikipedia.org/wiki/Voyager_1
Nada seguiremos con mas curiosidades...
EA3IO
Manuel Aleu
