SAQ 2019
EA2HB
#335471  - 16 junio, 2019 13:25
SAQ Grimeton Transmission on June 30th, 2019.
The annual transmission on "Alexanderson Day" with the Alexanderson alternator on VLF 17.2 kHz with the call SAQ will take place Sunday, June 30th, 2019.
Two transmissions are scheduled as follows:
  1. Startup of tuning at 10:30 (08:30 UTC) with a transmission of a message at 11:00 (09:00 UTC).
  2. Startup of tuning at 13:30 (11:30 UTC) with a transmission of a message at 14:00 (12:00 UTC)
    Both transmission events will be broadcasted live on our YouTube Channel.
NEW ! ONLINE RECEPTION REPORT FORM TO REPLACE E-MAIL REPORTS
We are introducing a new online SAQ reception report form to be used by listeners to report reception of any SAQ transmissions. We are kindly asking listeners not to send SAQ reception reports via E-mail.
QSL-reports to SAQ are kindly received via:
- Reception report form at alexander.n.se/receptionreport
- or via: SM bureau
- or direct by postal mail to:
Alexander Association
Radiostationen
Grimeton 72
SE-432 98 GRIMETON
S W E D E N
The Amateur Radio Station with the call “SK6SAQ” will be QRV on the following frequencies:
- 7.035 kHz CW or
- 14.035 kHz CW or
- 3.755 kHz SSB
QSL-reports to SK6SAQ are kindly received via:
- Email to info@alexander.n.se
- or via: SM bureau
- or direct by postal mail (see address above)
Two stations will be on the air most of the time.
The station will be open to visitors between 10.00 am to 4.00 pm.
WELCOME!
World Heritage Grimeton Radio station and The Alexander Association
For further details, se grimeton.org or alexander.n.se
  Ánimo y suerte.
Federico  EA2HB
EA7HHS
#335942  - 1 julio, 2019 09:01
Muchas gracias por la información facilitada en su día.  Pude captar las dos emisiones con los equipos SDR Perseus, JRC-NRD 545 e Icom IC-R8600. He subido vídeos a mi canal de YouTube  "juanlucordobadx".
En cuando a antenas, la mejor en este caso y por la frecuencia, 17,2 Khz, la Eprobe miniwhip, que me fabricó EA7OC.  Con la Gap Titan, que se comporta como la mejor en ondas media y larga, ni rastro de la SAQ.  No pude probar el último modelo de la Wellbrock.  Saludos.
EA7HHS
#339236  - 15 octubre, 2019 10:33
Próxima emisión de la SAQ, el jueves 24, a las 17:00 UTC
EA3WX
#341224  - 24 diciembre, 2019 00:02
Este jueves, 24, es de Diciembre, o sea mañana?
Luis, EA3WX
ALPICAT
DME 25023
CW, the way to happiness
QRP, ¿what else do you need?
EA3WX
#341225  - 24 diciembre, 2019 00:21
Nada, nada, que el 24 de Diciembre no es jueves sino miércoles.
Pues no sé a qué hora es mañana la TX
Luis, EA3WX
ALPICAT
DME 25023
#341234  - 24 diciembre, 2019 09:55
La transmisión es en la Víspera de Navidad. Según SAQ:
HOY 24 comienzan a las 0730, y el mensaje se transmite a las 0800 UTC, así que ya podéis correr a sintonizar 17.2 kHz.
Hay una retransmisión en vivo aquí: https://www.youtube.com/channel/UC-83S-l9JKD1iuhsXx3XQ3g?
Suerte con la escucha. Y, si no, pinchad en donde pone "En directo" en youtube... Solo se escucha el ruido enorme del generador pero al menos te haces la ilusión de que estás en VLF y no se oye un pijo... 🙂
EA5ZL
#341237  - 24 diciembre, 2019 10:39
Recibido el SAQ desde el monte con un Airspy HF+ y lo que queda de una K9AY que destrozó el viento del domingo pasado. Peor SNR que otras veces.
Adjunto el fichero de audio y por si quereis jugar, el enlace para la descarga del fichero IQ grabado con el SDR Sharp: http://www.equilogic.es/intercambio/SDRSharp_20191224_080004Z_17200Hz_IQ.wav
También recibido en casa por primera vez usando una Loop Wellbrook Ala 1530+ imperium y el flex 6500. Me ha sorprendido el buen comportamiento que tiene la antena en LF, VLF. Sin la capacidad de anular QRM de vecinos, imposible.
Os deseo unas felices fiestas y un buen año 2020
73 de Niceto
Esta publicación fue modificada hace 5 años 4 veces por EA5ZL
EA5C
 EA5C
#341240  - 24 diciembre, 2019 12:03
Bds.
RX: Siemens 745E
Antena W3DZZ 40/80m
599
QTH: Burriana IM99XV
Bon Nadal
Fer, EA5FX
EA5ZL
#341241  - 24 diciembre, 2019 14:31
@ea5fx
Fantástico Fernando. Gracias por compartir.
73 Niceto
EA3WX
#341242  - 24 diciembre, 2019 15:46
Gracias Jon, al final lo he podido oír, aunque...ejem 🙄... a través del SDR de Twente. Bueno...como dijo alguien “lo que importa no e si er gato e blanco o negro , sino que case ratone”. 😀😀
Luis, EA3WX
ALPICAT
DME 25023
#342066  - 16 enero, 2020 08:53
No me he dedicado en serio a recibir la MF, aunque de vez en cuando me gusta escuchar los radiofaros en los 300 kHz, que por la mala propa/QRM cada vez oigo menos de ellos, o quizá van desapareciendo. Sólo uso el receptor y antena Carolina Windom 77m long. ¿Hace falta algún otro artilugio para recibir mejorar la recepción?.  73 José Luis
