Nuevo bibanda Baofe...
Nuevo bibanda Baofeng DM-5R
EA7FGJ
#33471  - 15 septiembre, 2016 05:44
Hola, he visto este walkie y creo que sea el primero bibanda a un precio "humano" en DMR.
¿alguien ya lo tiene y lo está probando?
EA1AL
#300804  - 15 septiembre, 2016 10:51
Hola a todos:
Me da que no es Tier II, lo que impide que sea comparable a las radios que hasta ahora han sido usadas para DMR en entorno HAM. Parece un "añadido", como lo es la recepción de radiodifusión en FM.
En todo caso, seguro que algún buen conocedor de la materia lo aclara más pronto que tarde.
Copio una breve descripción de los 3 tiers posibles en DMR.
73, Manuel
DMR Tier I
DMR Tier I products are for licence-free use in the European 446 MHz band. In the US, the 446 MHz range is primary US Government with the amateur radio service a heavy secondary user. Some DMR radios that make it across the ocean have caused interference issues with licensed amateur operations. ETSI DMR specifies two slot TDMA in 12.5 kHz channels for Tier I, II and III.[3]
This part of the standard provides for consumer applications and low-power commercial applications, using a maximum of 0.5 watt RF power.[4]
DMR Tier II
DMR Tier II covers licensed conventional radio systems, mobiles and hand portables operating in PMR frequency bands from 66–960 MHz. The ETSI DMR Tier II standard is targeted at those users who need spectral efficiency, advanced voice features and integrated IP data services in licensed bands for high-power communications. A number of manufacturers have DMR Tier II compliant products on the market.
DMR Tier III
DMR Tier III covers trunking operation in frequency bands 66–960 MHz. Tier III supports voice and short messaging handling similar to TETRA with built-in 128 character status messaging and short messaging with up to 288 bits of data in a variety of formats. It also supports packet data service in a variety of formats, including support for IPv4 and IPv6. Tier III compliant products were launched in 2012
Fuente:
https://en.wikipedia.org/wiki/Digital_mobile_radio
73 & DX, Manuel
EB1HYS
#300805  - 16 septiembre, 2016 04:08
Da la sensación de FAKE...a simple vista parece un UV5R normal y corriente...me extraña que sea DMR con esa poca info en pantalla.
Abrazos,
EA5373URE
#300806  - 16 septiembre, 2016 05:16
Parece legitimo, nuevo, pero legitimo.
Algo mas de info en este site:
http://qrznow.com/baofeng-dm-5r-dual-band-dmr-digital-radio-new/
D
EA3HZU - Diogo
DMR-ID 2143230
EA7FGJ
#300836  - 16 septiembre, 2016 06:34
Yo creo que no es un fake.
La pregunta es si se puede tener en consideracion, al margen que si es homologable, o menos, pienso que si porque las frecuencias de trabajo son las nuestras.
A lo mejor ya estan manos a la obra con ese tema legal, seguramente.
EA5373URE
#300839  - 16 septiembre, 2016 09:06
La pregunta es si se puede tener en consideración, al margen que si es homologable, o menos, pienso que si porque las frecuencias de trabajo son las nuestras.
Dudo que los fabricantes de PRC se preocupen mucho con los temas legales de los radio-aficionados españoles (o de los otros países)
Homologado o no, la gente se los comprará en Amazon o en Ali Express o lo que sea... Tengan o no indicativo, tengan o no permisos de frecuencias comerciales, etc. Si se venden por 70$ van a caer como churros...
Yo no tengo licencia de radio-aficionado (aún), he comprado mi UV-5R por 25€, lo he programado con CHIRP y lo uso para escuchar los repes locales. Si me da por transmitir... si me pilla la autoridad... bueno, ya veremos.
En Alemania mi pincho RTL-SDR es ilegal...
EA3HZU - Diogo
DMR-ID 2143230
EA7FGJ
#300843  - 16 septiembre, 2016 09:47
No le se, pero la eventual homologacion la tendra que realizar el fabricante a traves de sus distribuidores, cosa mia no es.
70€ no cuesta, mas del doble...pero esto ya es otro cantar...
EA3HKY
#300807  - 16 septiembre, 2016 11:06
Yo entiendo que no es un equipo DMR (Tier II) (radioaficionados)
Entiendo que es un DMR (Tier I) (sin licencia), también conocidos como dPMR o PMR digital, si es el caso, es incompatible con el DMR que usamos en radioafición, ya que el ancho de banda y la modulación utilizadas son diferentes.
En http://www.va3xpr.net/baofeng-dm-5r-dual-band-dmr-radio/ lo entienden cómo yo
EA7FGJ
#300846  - 16 septiembre, 2016 11:12
Fenomenal, bueno saber las cosas, asi, claramente.
EA3HUP
#300808  - 27 septiembre, 2016 05:52
Es un DMR (Tier I) pues con el equipo no trae cable de programacion y aunque indican que daran soporte en brebepara que sea DMR (Tier II) con el coste de 10$ se tendria que modificar tanto la placa como estructurar todo su soft con lo cual el que este interesado le diria que espere y vea acontecimientos pues muy rapido lo sabremos por los foros americanos
el soft que controla el baofen es una mezcla de mandarin y de ingles
EB2DJB
#300809  - 27 septiembre, 2016 19:55
Yo no lo compraría. Hay otras alternativas mejores.
Enviado desde mi Aquaris M5 mediante Tapatalk
73's Rafa EB2DJB
Bilbao
Twitter: @eb2djb
EA4DL
#301225  - 28 septiembre, 2016 18:31
. . . . -- DMR -- For those following the status of the Baofeng DM-5R, one of our members received this email regarding his purchase.
The status of this radio has changed several times over the past weeks. This is strictly an FYI for those interested in the radios status.
Dear Customer,
We have an update for you on the status of the BaoFeng DM-5R.
Your DM-5R is ready to be shipped. We are confident you will enjoy the crisp, clear sound of the DM-5R. The DM-5R comes out of the box supporting only MOTOTRBO Tier I.
Thanks to the help of our Radioddity Review Team, we have found a bug in the software that makes updating the radio to Tier II inherently risky. If upgraded incorrectly, the user faces the possibility of disabling the radio, which would then need to be sent back to the manufacturer for repair. Radioddity does not suggest that you upgrade your DM-5R to Tier II manually. Manual upgrading should be done only by professionals.
We are working to fix this. We will re-release the DM-5R in one month’s time with a system update. This re-release will have Tier II standard.
Here are your options:
- Maintain your order status, receive the DM-5R with the current software in the next 5-10 days.
- Transfer your order to a DM-5R with upgraded software, for no additional price. Receive your radio October 20-30th.
- Cancel your order, receive a full refund.
We are working to provide detailed documentation to assist in the Tier II upgrading process, to support those who wish to upgrade their DM-5R.
Please respond to this email and let us know which option you would like to take going forward.
Sincerely,
Radioddity
Es decir (si mi ingles no me falla):
de momento este nuevo baofeng solo es TIER I, no valido para radioaficionados. Si lo quieres hacer upgrade, lo tienen que hacer técnicos de baofeng, porque si te equivocas, puedes tener un bonito pisapapeles.
Tienen previsto sacar a finales de octubre una nueva versión, esta vez con TIER II de serie.
En lo que pongo arriba, le dan al comprador la opcion de esperar, devolver el bicho y recuperar pasta, o seguir con el pedido con el soft "chungo"......
En romano palatino... el que quiera el nuevo baofeng DMR, a esperar.... por si acaso.
73 de Javier, EA4DL
EA7JXV
#300810  - 29 septiembre, 2016 09:27
lo vi la semana pasada y lo primero que se me ocurrió fue la compatibilidad tier2, pero se puede actualizar online a TierII, por 10$, aunque en la web oficial de Baofeng todavía no se ve nada al respecto.
Rumor 1: The BaoFeng DM-5R is not compatible with MOTOTRBO TIER 2.
FALSE. While the BaoFeng DM-5R comes out of the box only supporting Tier 1, it can be easily upgraded to support Tier 2 online. The upgrade will be available at Radioddity.com as well as BaoFeng’s official website (under construction). This upgrade costs less than $10. https://goo.gl/0aqz1G
parece que serán sobre 70$ (dólares USA), que con la conversión a €uros tan peculiar que se hace por aquí, no me extrañaría que llegara a los 100€, o los que lo pongan en promoción por 98,95€ ... seguro ;-)
Saludos!
Edu EA7JXV
EA7FGJ
#301337  - 29 septiembre, 2016 09:37
Al margen de todo, lo del precio es normal, porque por ejemplo, los precios que ves en las revistas americanas son netos, falta agregarle el IVA (Taxes que le dicen).
Si a los 70 U$s le agregas los impuestos aduaneros y a eso le agregas el IVA nuestro, verás que no sale muy lejos de los 100 € que puedan llegar a pedir.
EA7JXV
#300811  - 29 septiembre, 2016 10:01
así es Máximo,
no obstante, todavía no lo he visto en ningún sitio a la venta, y aunque se puede hacer un pre-order en http://www.radioddity.com, la actualización online a TierII no parece estar preparada, y se supone que salió a la venta el pasado día 26/9.
en fin, ya lo veremos, a mi me parece una opción interesante pero como comentan más arriba, si ese es el modelo real, la pantalla no parece que pueda ofrecer mucha información... lo dicho, ya lo veremos.
Saludos!
Edu EA7JXV
EC4C
 EC4C
#301338  - 1 noviembre, 2016 04:43
Acabo de recibir uno de radiooddity, pero estoy buscando como instalarle el Tier II. Es igual que el UV-5R, pero con mas opciones en el menú.
73 EA4SV Roberto
EA1GLY
#300812  - 1 noviembre, 2016 09:36
Ya nos comentaras como sale el tema
Gracias de antemano Ea1gly J.Galo :)
EA7JXV
#302997  - 1 noviembre, 2016 15:29
EA4SV escribió:
...pero estoy buscando como instalarle el Tier II...
hola Roberto, acabo de ver que en la misma web puedes adquirir la actualización ( http://www.radioddity.com/us/baofeng-dm-5r-dual-band-dmr-upgrade.html).
Comentan que es arriesgado y podría bloquear el equipo. Parece que a finales de año saldrá una nueva versión ya actualizada, supongo que será 10-15$ más caro al estar ya actualizado a TierII.
Ponte en contacto con ellos para información y ayuda, en support @ radioddity.com
Saludos!
Edu EA7JXV
