Nota Aclaratoria Co...
[Cerrado] Nota Aclaratoria Conferencia LK2
Página 2 / 4
EA5GVP
#50194  - 13 octubre, 2008 19:27
esta es mi salida las campadas replican donde repican el tiempo es el unico que dara o quitara razones pero como mi ingles es nulo le dejo por si no lo sabe que las normas de obligado cumplimeo del sitema Echolink solo a titulo informativo son estos que podra consultar el la pagina oficil de Echolin pero pego aqui para su informacion si existe o no problemas paral oque hace.
como espera esta salida
The following guidelines are followed for all stations requesting access to the EchoLink® system. These guidelines have been established to help ensure legal, courteous enjoyment of the system by every station. Every effort is made to apply these policies universally and fairly.
Although EchoLink is offered free of charge, please keep in mind that it is a privately-operated system. All EchoLink users are guests on the system, and are being permitted the use of it in exchange for following these guidelines.
1. Access is granted only to licensed Amateur Radio operators holding a CEPT Class 2 license, or equivalent. Each new user must provide proof of license before access is granted, using any of several available Validation methods. Please see Authentication and Validation Documents for more information.
2. No "SWL" (listen-only) access is permitted. EchoLink is a two-way system by design, and there is no mechanism to validate listen-only stations.
3. Sysop validations (i.e. -L/-R suffixes) are granted only to licensees whose class of license permits operation of an Internet voice gateway. However, it is the licensee's responsibility to ensure that any additional permits or authorizations are obtained if required by the governing authorities.
4. Stations operating in Sysop mode may interconnect EchoLink only with equipment operating on Amateur frequencies. EchoLink does not permit use of the system with other services such as GMRS, FRS, or MARS. For security reasons, it is also not permitted to interconnect EchoLink with other VoIP systems that support direct access from a computer.
5. Stations which use the system are expected to abide by common courtesy and generally-accepted operating practices. Access privileges will be withdrawn for stations which operate with malicious intent, blatant disregard for international Amateur Radio regulations, or impersonation of another station.
6. When based upon complaints from several other users, repeated incidents of rude, threatening, or vulgar remarks from a particular station will not be tolerated, and is considered grounds for withdrawal of access privileges. This policy applies to any transmissions from a station, including those received over an RF link. Rude or threatening remarks directed at members of the volunteer support team will also not be tolerated.
7. Once validated, a station must not share or "lend" its password to another station, particularly to an individual who is not licensed. In addition, any user who tries to present forged documents for validation, or documents obtained without permission, will be permanently barred.
8. Please use only your permanent, fixed-station callsign to log in. Avoid using portable designators (e.g., K1RFD/2 or PY2/K1RFD), or temporary, special-event, or commemorative callsigns; these callsigns will not be validated. This helps keep the callsign database to a manageable size.
9. If you hold multiple callsigns, please request validation of only one callsign for EchoLink. As a rule, we will not validate more than one basic callsign per user in Single-User mode. This holds true even if you travel from one country to another and hold callsigns in each country -- please use only one callsign with EchoLink, even while traveling.
10. The "addressing servers" are designed to be accessed by EchoLink software only. For the sake of system security and stability, any other access requires the permission of the server administrator. As a matter of security, in no event should the IP addresses (or Internet hostnames) of logged-in stations be displayed to anyone who is not a validated, logged-in user.
11. Although every effort will be made to apply these policies universally and fairly, the EchoLink Support staff reserves the right to withdraw a station's access privileges at any time, without notice. EchoLink is a privately owned and operated system that has no connection with, and is not governed by, any radio licensing authority.
Please note that the EchoLink software allows additional security policies to be adopted by individual stations. For example, a station not wishing to be joined to a conference can disallow such access. These decisions are made by each individual station and are not under the control of the developers of EchoLink, or the servers with which it operates.
Aplique se el cuanto caballero en cuanto a si si o si no se puede hacer lo que hace si lleva razo perfecto y me alegro por usd
Ex EB4DMQ 1979 -2000
Ex EC4CPH 1981 -2000
Ex EC5
Ex EB5FZU 2000 --2006
EA5GVP por la gracia de pagar 180,75€ a Teleco
EB3TC
#50196  - 13 octubre, 2008 20:15
Perdonad mis pocos conocimientos sobre Echolink, pero viendo la generosa lista de baneados y la poca cantidad de gente que usa estos links, no sería mejor dejar las conferencias en modo "Privado" y autorizar solo a los "amiguetes" ??????????
:laugh: :laugh: :laugh:
Otra cosa, he visto hoy en la web de linkados que "se dá las gracias entre otros a EA3DXR, hombre pues si teneis contacto con ese señor ( cosa que dudo ), aprovechad para pedirle el material que "mangó" propiedad de DIGIGRUP-EA3 en las instalaciones del Pic de Orri y que tiene en su casa.
Saludos y gracias.
Xavier Pérez, 25T606
EB3TC / EA3DGI
JN01XL / JN01SU
http://www.comunicacio.net/eb3tc
http://www.digigrup.org
http://www.amired.es
Xavi Pérez
EB3TC JN00HX DME 43121
http://www.fcr.cat/eb3tc
https://twitter.com/EB3TC
En solidaridad con EA1YN
d'allà on no n'hi ha no en pot mai rajar
EA2AFF
#50167  - 13 octubre, 2008 21:04
Hola y saludos a todos.
Un simple comentario.
En Zaragoza, y coincidiendo con sus fiestas, se ha instalado una completisima estacion de radioaficionado en la Feria General de Muestras (visitada por miles y miles de personas).
En concreto en el Pabellón de la Ciencia, organizado por la universidad de Zaragoza.
Por el mismo, y en los 8 dias de Feria, han pasado por el pabellon miles de personas, teniendo especial significación las personas jovenes (algunos muy jovenes) que asistían a diversos talleres cientificos.
Muchisimos de ellos han sentido curiosidad por "lo nuestro", por la radio, y con paciencia y amabilidad se les ha dado toda la información que solicitaban, folletos sobre radioafición y revistas de URE.
La pregunta que la mayoría hacían estaba relacionada en cuanto a saber si existiamos tras aparecer internet.
¿Como le explicas a un joven, crecido en la era de los videojuegos y de internet que es la radioafición?. Pues se ha intentado y en muchos casos se ha conseguido.
Y en concreto, a la pregunta de saber que paso con nosotros tras internet, nuestra respuesta es que la radio de aficionados ha ido evolucionando (desde la telegrafia hasta los satelites y modos digitales) y que no arrinconamos los modos antiguos de operación, sino que los ampliamos con nuevas tecnologias e internet era una de ellas, nuestro aliado, una herramienta para la radioafición.
Poníamos el ejemplo (entre otros muchos) del echolink y la conjunción radio-internet.
Me pareció una buena idea y un buen ejemplo.... hasta leer este hilo que, como se ha dicho, está abierto al publico (otra de la información que hemos dado hasta la saciedad es la de nuetra web, que accediensen a ella para la busqueda de información).
Me da verguenza leer lo que estoy leyendo, no por lo que se expresa, cada cual es muy libre, sino porque, como también se ha comentado (y así lo dije en el Congreso de Huesca) estoy reviviendo el tiempo de las BBS de Packet y de verdad, no me apetece que de nuevo, protagonismos y rencores den al traste con lo que podría ser una atractiva modalidad de radio (no la unica, no la mas importante, una mas).
Gracias por leer mi comentario que es una simple reflexión.
Desde Zaragoza un saludo para todos
Julio EA2AFF
EA5GVP
#50208  - 13 octubre, 2008 23:36
Julio me gustaría que no se confundan las cuestiones:
Vaya por delante
Mi felicitación por la labor que según usd y otros colegas estáis realizando en Zaragoza el cual estoy seguro como muchos radioafinados aplaudimos la idea y el desarrollo de tan aceptada idea.
Pero cuando dice :
Me da vergüenza leer lo que estoy leyendo, no por lo que se expresa, cada cual es muy libre, sino porque, como también se ha comentado (y así lo dije en el Congreso de Huesca) estoy reviviendo el tiempo de las BBS de Packet y de verdad, no me apetece que de nuevo, protagonismos y rencores den al traste con lo que podría ser una atractiva modalidad de radio (no la unica, no la mas importante, una mas).
Mas vergüenza nos tiene que dar que un Salvador de la tierra erigido a si mismo como el mas Grande -- Dictador y Rey de reyes intenta y ha sido su tónica diaria la decisión de quien puede y no puede salir en modo digital eso si es vergonzoso si se da al traste o no con tan atractiva modalidad será solo por culpa de todos los radioafionados que no alzamos la voz contra la injusticia de quien si es más grave es el vocal de nuevas Tecnologías de URE D. Eduardo Rodiguez EB3GHN
ese el fondo y no otro.
Si en huesca ya expreso la preocupacion de que el tema de las fbb etc etc que tiene que ver desde ese dias a estos ultimos ? en esos dias la cosa iva suave
El señor Eduardo hace de las nuevas TEcnologias en la modalidad Echolink
ES en un partido de futbol -- su equipo --- el equipo contrario -- el arbitro -- el que corta el césped y el que juega se la chuta asi mismo y se mete gol todo a la vez .
Por cierto en uno de los cometarios alguien se refiero a que o que relación tiene linkados y URE dije que no tenía ni idea pero mirando linkados el señor Eduardo firma algunas cosas como Vocal de ure ufff según le baila otras veces firma como administrador de linkados otras como administrador de conferencias como Espana -- espana2 ( ESTAS ya Quisiera el mangunearlas como hace con las siguentes -- dstar -- ea3spain según le da el aire.
En cuanto al cometario de EA3TC jejejej muy bueno muy bueno Dios los junta y ellos se apelotonan.
Otra cuestión para mi amigo EB5FHZ-R
Analizando un poco solo un poco
Supongo que ha visto las normas de obligado cumplimento de ECHOLINK supongo ¿
SE desprende de dichas normas pese a mi nuulo enteder del ingles que
Usuario = Radioafionados con conexión simple los cuales pueden hacer conexiones punto a punto con una o varias estaciones via Internet.
Uruario con link --- pasarela de voz en conexión ip que además de uso punto apunto recibe y emite en modalidad simple --
Usuario R o repetidos -- pasarela de voz con conexión ip y con solo finalidad de emision recepción en distinta frecuencia Funcion repetidor .
Conferencia -- o sala -- Donde se aglutinan tantos usuarios como su capacidad de conexión y de gestión le permita el ancho de banda
En ellas además de estar prohibido por seguridad la multi conferencia de usuarios vease norma 10
Que no tiene ni conoce a Eduardo vale bueno de acuerdo pero a que si conoce a el otro inclito que esta metido de lleno con Eduardo, EB5ADX fundador de la pagina Linkados que le ha promovido para hacer lo que está haciendo y que dio de lata el mismo día que se publico el primer mensaje ? o no es cierto -- que dudo de su imparcial, por intereses ni yo ni muchos que tienen dos dedos de frente la evidencia es la evidencia caballero tome esto como quiera pero a quien le informa y le informa de cómo hacer o decir son Dictadores que niegan el derecho a replica ante sus continuos cambios según les convengas al tiempo el tiempo es juez imparcial de lo que digo.
Ya Esta bien hablemos Claro que esperaba reaciones asi de mi y que no se por donde repican las campanas uff estoy seguro que resuenas por murcia y mucho.
a por cierto como e podido ver y estoy de acuerdo con la persona que lo dice El proyecto linkado está mal parido y está fuera de toda norma y ley de telecomunicaciones en fondo y la publicación de donaciones de equipos profesionales para le uso de link o repetidores sin autorización de legalización de equipo por el titular de la estación es considerado como muy grave Señores EB3GHN vocal de nuevas tecnologías se llena la boca de decir que envía no se que equipo a unos y otros ¿ como vocal de ure esta promoviendo ilegalidades señor Enrrique su proyecto está corrompido por decisiones Dictariales de el señor Eduardo y usd mismo .
A quien corresponda de la junta directia de URE tome nota de lo dicho
Es EB4DMQ 1979 -2000
ES EC4CPH 11983 -2000
ES EB5FZU 2000 --2007
EA5GVP por la gracia de pagar 180,75€ a Telecomunicaciones
Eusebio Flores para lo bueno y lo malo
Ex EC5
EA5GVP
#50247  - 14 octubre, 2008 11:32
jejejeje las mentiras tiene las patitas muy cortas
? Quien te informa que tememos 6 conferencias jajaja ni idea pero eso si te proclamabas independiente se te ve el plumero
No es verdad no disponemos de esa Cantidad de Conferencias no tienes ni idea ni tu ni quien te ha informado de ello es gracioso Señor Independiente .
Que has trasladado a linkados tu inquietud sobre le tema jejeje desde el dia 10 que dio de lata su indicativo como -R causalidades de la vida jejeje
En cuanto a la contestación de Eholink TEAM
Le dice claramente pero que muy claro que a su solitud de crear una conferencia NADA DE NADA
Que con su indicativo use las ya existentes si lo desea con las normas que hay para ello
es lo que dicen pero que usd interpreta como quiere usd. pero lea la norma 10 del sistema echolink
Ellos que dictan las normas a las que te refieres así me lo han sugerido, y yo he obrado a sugerencia suya...
Imitando tu técnica copy/paste del mensaje:
"""A large number of EchoLink conference servers with excess capacity are already online.
Therefore, at this time, we are no longer routinely approving new conference server
requests. If possible, please try to make use of existing conference servers, or make
use of the Conferencing feature in the EchoLink software under your existing callsign.
73,
EchoLink Validation Team"""
Ni más ni menos ni blanco ni negro
La mano negra Eduardo Rodriguez y tu compañero de asociacion EB5ADX te han cojido de cabeza de turco
El tiempo da y quita razones
cuando dice:
He trasladado a linkados mis inquietudes sobre el tema, hay mucho de que hablar, yo no tengo historial de indicativos, me dieron este en el año ... eso que importa ... no tengo experiencia, y he llegado a esto del echolink tarde, mi indicativo EB5FHZ-L esta registrado en echolink en el año .... eso que importa miralo tu si tienes interes ... pero creo que es un proyecto interesante y se puede hablar mucho sobre el, pero este no es el sitio adecuado, ni esas son las formas correctas. Si Eduardo obra mal, tu no es que lo mejores precisamente...
? que es linkados una pagina que pregona a los cuatro vientos e incita a la inlegalidad pagina mal parida y con interses comeciales .
Su inquietud al respecto de el uso inadecuado de su inditativo con la extension -R que significa Estacion repetidora que aquellos que se descuelguen de su estacion lo esta reciviendo por una frecuencia y lo esta emitiendo por otra ufffffff buena interpretacion buena si señor.
Mucha insistencia tiene usd y otros a la desaparicion de este foro ???
no nos podemos Expresar libremente ? insultos digame donde insulto yo a alguien .
Si acaso a las medallas que ya se pusieron algunos como el Vocal de Nuevas Tecnologias -- le llamo Dictador Rey de reyes y alguna otra cosa asi pero los mensajes que recibo de este Dictador sus insultos son de peso en cuanto a la gravedad de los mismos pa que los voy a clasificar
En cuanto a usd :blink: afirmo que esta siendo dirigido como cabeza de turco de estos dos señores Afirmo con todas las consecuencias
Las normas no las ponemos nadie en cuanto al sistema Echolink las normas estan editadas pero la interpretacion es libre segun afirma
Como es posible y afirmo que usd este con su indicativo con extenxion -R
y descuelgue de su sistema multiconferencia es un error contemplado en la norma 9 y 10 de echolink
pero en fin interprete las normas de los que es una estacion en -r repetidora - o en l o el modo simple
España es asi
EA5GVP por la gracia de dios y decretazo y pago de 180.75€
hoy no firmo como anoche jijiji
Ex EC5
EA5GVP
#50261  - 14 octubre, 2008 12:10
muy bueno muy bueno
Nota aclaratoria y verdaredera se puede comprobar.
La asociacion ERA España dispone solo y exclusimante de una conferencia y desde el dia diez de dos.
La segunda gracias a El vocal de nuevas tecnologias y se llama LK2 que por cierto nos exige la devolucion del nombre
En cuanto a acusaciones aplique tambien a usd al acusar de posesiones falsas
mucho mucho interes tiene del cierre de este foro mucho
Ex EC5
Anónimo
#50209  - 14 octubre, 2008 14:06
Julio EA2AFF
Hola Julio:
Ya veo que no soy el unico que ve las similitudes de esta situacion con la del extinto packet radio.
Pero estoy en desacuerdo contigo en que el futuro de la radioaficion sea el echolink, ni tan siquiera que sea simplemente otra modalidad de radio mas.
El echolink es, mientras no se me demuestre lo contrario, un simple chat voip sobre internet en el que sa ha sustituido el microfono y el altavoz del PC por una emisora, y no en todos los casos, ya que tambien permite el uso SIN EMISORA.
Lo mas lamentable de este caso es que, ademas, se permite la creacion de corralitos particulales en los que los iluminados de turno imponen normas dictatoriales a sus usuarios y banean a diestro y siniestro por el simple hecho de no "caer simpatico".
Pero es que aun hay mas.... TODOS LOS LINK Y REPETIDORES de este sistema estan instalados de forma ILEGAL ya que ninguno de ellos tiene la licencia correspondiente.
Y aun mas, gran parte de ellos, los patrocinados por LINKADOS, estan montados sobre equipos cedidos por empresas particulares que evidentemente pediran algo a cambio, ¿alguien sabe que es lo que piden? y no solo eso, esos equipos NO ESTAN HOMOLOGADOS PARA SU USO POR RADIOAFICIONADOS, son equipos comerciales destinados a otros menesteres, ¿sera por eso que no se pueden legalizar?.
Mira lo que pone en las NORMAS que rigen a los LINKADOS:
Las empresas y entidades colaboradoras podrán tener un control sobre el material donado, pudiendo solicitarlo de vuelta en cualquier momento o cuando estimen que desean dejar de colaborar con el proyecto.
Pero es que aun hay mas.... esa ¿asociacion? llamada LINKADOS se atreve a publicar unas normas de uso que ni Franco en sus mejores tiempos se atrevio a poner negro sobre blanco, si teneis tiempo y ganas os adjunto el link de estas normas, todo un ejercicio de democracia, http://www.linkados.net/content/view/74/72/ repito, ni siquiera Franco se atrevio a poner POR ESCRITO semejantes restricciones y mas teniendo en cuenta que el primero que se las pone por montera es NUESTRO VOCAL DE NUEVAS TECNOLOGIAS, segun se ha dicho en este foro por parte de alguien que ha grabado algunas apariciones de este sujeto.
Y ya por ultimo, pero no por ello menos importante, ¿QUE RALACCION EXISTE ENTE LA URE Y LINKADOS? nadie sabe darme razon de ello, pero nuestro inclito vocal de nuevas tecnologias, EB3GNH, D. Eduardo, escribe en la pagina de LINKADOS y firma como VOCAL DE NUEVAS TECNOLOGIAS DE URE, luego me atrevo a pensar que la relaccion URELINKADOS es muy estrecha y no solo eso, en la misma web aparece REPETIDAMENTE el logo de URE y como muestra esta imagen que cuelga de la pagina principal de la web de LINKADOS. new%20lkn2%20copiar-l.jpg
Los LINKADOS dicen en su web que su fin es fomentar las comunicaciones digitales entre los RADIOAFICIONADOS, si es ese su fin ¿que narices pinta entre sus filas gente que ni siquiera tiene indicativo? por ejemplo un tal Casanova.
Resumiendo, efectivamente el camino que sigue el echolink es exactamente el mismo que siguieron las bbs y nodos de packet, entonces el "iluminatti" era EA3CIW, el doctor Sam, ahora el iluminado es D.Eduardo, solo una pequeña diferencia..... a este ultimo, la URE le ha dado un pito y una gorra (le ha dado poder), hace y deshace a su antojo con unas manera y formas que recuerdan mas a otros tiempos no muy lejanos.
EA5GVP
#50272  - 14 octubre, 2008 14:53
Al respecto de este post o hilo a las cuestiones publicas que aquí se están vertiendo.
La Asociación ERASPAIN solo y exclusivamente pretendía dar a conocer la Actitud Dictatorial
que D.Eduardo Rodriguez EB3GHN - Vocal de nuevas tecnologías de URE tenia en una conferencias en partículas la ya famosa llamada LK2 .
En diferentes acusaciones contra la asociación que presido y en mi nombre se cruzan un monton .
He intentado con pruebas fehacientes de la manipulación del Vocal en cuestión su malas artes y prepotencia de este señor , Si bien entre a contestar una por una las cuestiones que se vierten en el foro , en alguna ocasión avisando si se me permitía del mal uso que a mi juicio se hace del sistema Echolink .
Algunos se levantaron de la silla cuando hice publica la lista de baneados del sistema sin poder dejar expresar su opinión libremente con decisiones unilaterales y Dictatirlaes del Vocal de nuevas Tecnologías de ure.
Que por cierto públicamente admitió el señor Eduardo
En cuanto al uso del sistema por quien y quienes protestan las pruebas de defensa son las que el tiempo darán.
Se me acusa en un monento determinado de
Según escribe el señor Jose Victor -- EB5FHZ nombrado por quien no se Administrador de las conferencia afines a linkados y controladas por Eduardo Rodriguez y EB5ADX que también pertenece a su mismo club véase nota de linkados
Me dice publicarte:
Esta usted atentando al descalificarme publicante a un derecho fundamental que me reconoce la constitucion y esta en el art. 18.1, creo que seria suficiente para que un foro respetable cerrara el hilo.
¿Ha alguien mas le parece que hay un "interes oculto" en cerrar este hilo o cualquier otro en el mismo tono, como hemos tenido antes?
Solo puedo defender mi postura con los email descalificatorios insultaste y de las notas publicas que la pagina linkados hace .
En la discusión o cambio de impresiones de que no esta usando adecuándome su indicativo me reafirmo en lo dicho NO ESTA USANDO SU INDICATIVO CON EXTENSION R ADECUAMENTE
Si le acuso de ser la voz de su amo véase la nota de Linkados donde esta usd integrado como administrador de conferencias como dstar-es-ea3spain y la seudo conferencia de su indicativo .
El fondo de todo esto es no la libre expresión que se ha intentado por parte del grupo al cual usd reconoce estar pues se nos elimino el derecho a replica de la pagina linkados y optamos por dar a conocer públicamente los desmanes que el vocal de nuevas tecnologías en compañía de otros ,en algunos caso con nocturnidad y alevosía estaba y esta realizando en el echolink
Nocturnidad cuando se crean normas de noche y se intenta confundir al personal que esta siguiendo con atención lo que aquí se pone---
Todo lo demás opiniones pareceres y otras cuestión son pues lo que son ( la libre exposición de los pareceres a la situación algunas afines otras no tanto pero libres )
Que la asociación que presido está informada de lo que estoy haciendo que no quepa la menor duda que si se nos acusa con que estábamos informados del los baneos LO NEGAMOS que aporten las pruebas que publicarte se jartan de publicar y reconociendo que na la asociación nos tenían engañandos pero nuca es tarde para rectificar.
Es cuando detectamos dicha lista el la conferencia cedida por la Asociación cuando pretendemos que se regule la conferencia y se pone muy muy nervioso el Señor Eduardo Rodriguez que se nombra asi mismo Administrador de las conferencias Espana-Espana2-DSTar-es –EA3Sspain y la seudo conferencia eb5FHZ-R y reconociendo y diciendo que esa lista estaba ne todas las conferencias que según el administraba seguro que algunos de los que están en la lista han podido comprobar que no es cierto pues aunque a pedido el control administrador de espana y espana2 es incierto que tenga ese control intentado involucrar a estas conferencias
En Cuanto a lk2 si le dimos la confianza en un principio como administrador el cual dio a quien le pareció bien sin contar con nadie el control de administrador no criticando esta asociación la entrega de claves Sysop ni mucho menos
Su único interés es seguir siendo el manda todo
La verdad sale por su propio peso
Ex EC5
EA5GVP
#50284  - 14 octubre, 2008 19:46
Señor mio ..
que lamenta ? que El señor Alex Casanova no pueda acceder a pubicar mesajes en este foro pues como usd hace alusiones a otros que hay en el foro de linkados que diga lo que quiera en el .
Que tiene un gran interes no lo dudo efectivamte ,que este for es un corralito para los Radioafionados claro que si, el resto de esa frase de su cosecha claro esta que no se examine etc etc
Que le apasiona las posturas justo despues de que fuera acusado Eduardo de Fascista coolaboro en esa afirmacion
1897 entradas aconsultar pero no veo nadie que le apoye caballero de momento
uno dde los significado de fascista:
El fascismo crea la premisas para incorporar a sectores muy extensos de las masas a la lucha a causa de la privación absoluta de derechos, poniendo de manifiesto la identidad de intereses Apliquese a linkados .
Y usted pertence a ese proyecto .
citemos a Ein Volk, ein Reich, ein Führer! («¡Un Pueblo, un Imperio, un Guía!»)
o otra definicoin de Fascismo :
El fascismo es un movimiento totalitario en la medida en que aspira a intervenir en la totalidad de los aspectos de la vida del individuo. Hannah Arendt entendía que la masificación de la sociedad contemporánea llevaba al individuo a la soledad, el terreno propio del terro
rEl guia Eduardo Vocal de nuevas tecnologias de ure y hermano mayor y prpulsor de inlegalidades de linkados.
a ver con cual articulo de la constitucion me responde ?? estoy acongojao y aco..nado
Ex EC5
Anónimo
#49821  - 14 octubre, 2008 20:06
foto7: momento la charla sobre el sistema D-STAR por parte de Alex Casanova, explicando como funciona el sistema y sus posibilidades
Esto esta sacado de la web de LINKADOS, el del pelo blanco es D. Eduardo, EB3GHN, vocal de nuevas tecnologias de la URE.
¿Como puede ser que un señor que NO TIENE INDICATIVO imparta conferencias sobre D-STAR?, se supone que solo ICOM a puesto esta tecnologia en sus equipos de RADIOAFICIONADO y para manejar un equipo de de RADIOAFICIONADO de la marca ICOM hace falta LICENCIA DE RADIOAFICIONADO o ¿es que como la conferencia la organiza URE tiene bula papal?.
Ademas, este Sr, esta en todas las salsas de comunicaciones digitales de RADIOAFICIONADO, solo hay que buscar en san google lo siguiente "alex casanova echolink", veras como aparece en todas, como el perejil, si no tiene LICENCIA ¿como puede ser eso?.
Esto quiere decir que este Sr. lleva bastante tiempo metido en esta historia y si tanto le interesa la radioaficion, le ha sobrado tiempo para examinarse y sacarse su correspondiente licencia.
En cuanto a lo del foro MODERADO.... ¿quieres decir que alguien como EB3GNH debe de poner las normas para escribir en este foro?, si es eso lo que quieres decir, a estas alturas ya estabamos casi todos BANEADOS y EXPEDIENTADOS y RECRIMINADOS PUBLICAMENTE, tal y como este Sr. dicta en las normas de otros foros.
EA5GVP
#50311  - 14 octubre, 2008 20:45
FOROLINK
ForosVista jerarquizada El Señor Eduardo y su banda EB5adx que por cierto tengo entendido que fue expulsado de URE que dos se han juntado eliminan la libre expresion de algunos radioafionados el forolink esta corrompido el forolink y todo ese entramado comercial
Ex EC5
EA5GVP
#50331  - 14 octubre, 2008 23:07
Cotilleado por internet me llevo la sorpresa esta del Señor Alex
dice en un foro :
3Alex Casanova
Menuda sorpresa me he llevado, no sabia que también te apasionaba el mundo de la radio, yo tambien soy radioaficionado. Dispongo de varios equipos….lo que más me apasiona últimamente son los modos digitales. Es todo un mundo aparte. Y sinceramente no creo que Internet pueda matar a la radio. En HF todavía quedan comunicaciones de “backup” que se hacen por si algún dia falla Internet.
Alex
REtrato de un Pirata no pongo foto a ver si me denuncian que estoy acojonao con el grupo Linkados acojonao estoy lo juro
Ex EC5
EA2AGV
#49822  - 15 octubre, 2008 12:08
Lo siento Señores.
No lo soporto más. Entre lo rematadamente mal que se intentan expresar unos, las faltas de ortografía, las acusaciones de otros, los dimes y diretes abundantísimos... mi cabeza ha dicho !!!Basta¡¡¡
Este hilo del echolink, más parece un lío entre chavales en el patio de un colegio que de CABALLEROS RADIOAFICIONADOS.
Sin entrar a dilucidar quien tiene o deja de tener la razón, pienso que las diferencias personales, porque en este caso lo único que hay son diferencias personales, se solventan hablando entre las partes implicadas y no haciendo de un foro de radioaficionados un GALLINERO.
Podrán Vds. seguir con éste hilo abierto durante décadas, pero el que subscribe, como si oye llover.
Juro que no volveré a leer ni una sola linea más de este atufante hilo del echolink.
Saludos cordiales de Javier ea2agv.
73 de Javier, EA2AGV
EA5GVP
#50370  - 15 octubre, 2008 12:59
Siguiendo la tónica de estos días contesto a El Señor Javier en cual respeto su opinión por supuesto.
Que tengo muchas faltas de ortografía Si lleva razón mis padres intentaron darme una educación que no aproveche adecuadamente, pero me inculcaron el respeto y derechos que todos témenos a expresarnos libremente
Eso de Caballeros Radioafionados suena un poco a Legionario yo me considero Radioafionado a secas. porque hay también por cierto un numero muy alto de mujeres RAdioafionados es una nota de humor no lo tome como un ofensa
Si no entra a lucida quien o n tiene razón , piensa entonces existe , que es una diferencia personal eso denota que no ha leído bien lo único que se ha pretendido es sacar a la luz los desmanes que El vocal de nuevas tecnologías EB3GHN que si me afecta como socio de URE las locuras que esta haciendo a día de hoy sigue igual que me a tocado a mi hacer público sus desmanes prejuzga que es un asunto personal pues tengo que decir que es un problema de todos los socios de ure pues implica entre otras cuestiones el nombre de URE en incitacion a ilegalidades lea bien por favor pese a mis faltas de ortografía
Reitero que respeto a todos sus opiniones pero por favor lean el fondo de lo que como yo y otros dicen
El vocal de nuevas tecnologías de ure y su actos si nos afectan a todos claro que si
que es un guerra ? entre este señor y yo de eso nada de nada que cada uno obre en consecuencia a lo ya expuesto en todo el log o hilo
Que esto sale a la luz por la provocacion que hace publicamente El señor Eduardo Si eso si es verdad-- que cuando empiezan los problemas empezamos a analizar l oque esta haciendo Si claro que si
Que no dio oportunidad a expresarme libremete en otros foros tambien es cierto
Saludos 73
Ex EC5
EA7EE
#50372  - 15 octubre, 2008 16:29
Después de releer varios post yo no me entero de na.. será que no está en mi idioma..
Esto me suena a ECOPOLLO.. vagos recuerdos del DIGIPOLLO que yo no viví (soy muy joven).
Esperemos que se solucione todo y se calme la cosa..
EA7EE
EA5GVP
#50385  - 16 octubre, 2008 00:51
Vaneados o expulsados A día de hoy 16/10/2008 o como dice el gran Dictador
EB3GHN>de todas formas esa lista es el secreto dl funcionamiento
de estas conferencias y no nos hemos cortado nunca en
decirlo....el que no quiera al carajo
o otra muy buena del Dictador Vocal de nuevas Tecnologías de URE públicamente muy bueno dice
refiriéndose a mi --
EB3GHN>NO CONMIGO ENBUSTERO CHIVATO LENGUALARGA o
EB3GHN>SIN NADA....NO ERES NADA EUSEBIO....NADA¡¡¡¡¡¡ como dice la canción sin ti no soy nada
EA5GVP-L>Yo tambien te quiero Eduardo
EB3GHN>ERES AQUI UN CERO ALA IZQUIERDA......CHIVATO....PUBLICAR LA
LISTA E BANEOS
EB3GHN>YA TE VERAS REFLEJADO EN LA WEB DE LINKADOS
EB3GHN>NADA ERES AQUI NADA
hombre ? si me han dado la lista día de hoy sigues haciendo de echolink tu jardín de infancia
Señor que con gorra y pito te has creído el General de la compañía
Sigamos con el juego señores--- algunos flasicicais de dipollo o de pelea de niños o de Gallos pero en algo nos tenemos que entretén digo yo , el libre para todos o solo se va ha divertir el ínclito Dictador Vocal de Nuevas Tecnologías de URE
Hay va la nueva lista de vaneados Secreta , de un Bocazas el chache le rende EA5GVP
Conferencia *DSTAR-ES* banned users:
*AMIRED* -
*ARAGON* -
*AZTECA* -
*DSTAR-EA* -
*EA1SPAIN* -
*EA4SPAIN* -
*EA8SPAIN* -
*ERASPAIN* -
*LIBERDAD* -
*LIBERTAD* -
*LINKADOS* -
*NCFFLINK* -
*SUR* -
*ZONA-EA8* -
CT2IYZ -
CT2JAY -
DO3DT -
EA1ATH -
EA1BH -
EA1CWS-L -
EA1GHQ -
EA1GUP -
EA2AQV-L -
EA2CZC -
EA2FL -
EA2RCU-L -
EA3BLK -
EA3DGI -
EA3DSP-L -
EA3EUL -
EA3IC -
EA3IK -
EA3RDG -
EA4EPP -
EA4EZY -
EA4FG-L -
EA4LT-L -
EA5CB -
EA5GID -
EA5GSI-R -
EA5GTO-L -
EA5GVP - <
YA me cazo El Dictador ya no puedo entrar
EA5RCA -
EA7WL-L -
EA8ADH -
EA8CAG -
EA8CAZ-L -
EA8CDT -
EA8CLL -
EA8EE -
EA8RCT-R -
EAFL-R -
EB2CUJ-L -
EB3EHJ -
EB3EPP -
EB3TC -
EB4FLT-L -
EB4HJL-L -
EB5CCO -
EB5HUO -
EB7EEE-L -
EB8BLL-L -
EC1CWS-L -
EC2AMR -
ED5ZAA -
HP2BWJ-R -
HS4PXR -
I6XCN -
IR6UH-R -
IZ6FKI-L -
KA3KDL-R -
LU2ALE-L -
LU2HCR -
LU4HH-L -
LU5DNP-L -
LU6ASG -
LU7FBG-L -
LU7FDV-L -
LU7HBD-L -
PU2FPT-L -
PU2GCD-L -
PU2LOO-R -
PU2TMT-R -
PU4XUI-L -
PU5PEX -
PU6GCD-L -
PUGCD-L -
PUGGCD-L -
PY3PDT -
WP3MH-L -
Ex EC5
EA5GVP
#50443  - 16 octubre, 2008 00:54
[color=]EB3GHN>NO CONMIGO ENBUSTERO CHIVATO LENGUALARGA o[/color]
LISTA E BANEOS
Sigamos con el juego señores--- algunos flasificais de digipollo o de pelea de niños o de Gallos pero en algo nos tenemos que entretén digo yo , el libre para todos o solo se va ha divertir el ínclito Dictador Vocal de Nuevas Tecnologías de URE por fonia el echolink tirando patadas como los asnos digo yo.
siento que algunos paseis verguenza y esas cosas con humor hay que tomarse estoas peleas de ¡Gallos¡ por el gallinero
*AMIRED* -
*ARAGON* -
*AZTECA* -
*DSTAR-EA* -
*EA1SPAIN* -
*EA4SPAIN* -
*EA8SPAIN* -
*ERASPAIN* -
*LIBERDAD* -
*LIBERTAD* -
*LINKADOS* -
*NCFFLINK* -
*SUR* -
*ZONA-EA8* -
CT2IYZ -
CT2JAY -
DO3DT -
EA1ATH -
EA1BH -
EA1CWS-L -
EA1GHQ -
EA1GUP -
EA2AQV-L -
EA2CZC -
EA2FL -
EA2RCU-L -
EA3BLK -
EA3DGI -
EA3DSP-L -
EA3EUL -
EA3IC -
EA3IK -
EA3RDG -
EA4EPP -
EA4EZY -
EA4FG-L -
EA4LT-L -
EA5CB -
EA5GID -
EA5GSI-R -
EA5GTO-L -
EA5GVP - :silly: <
YA me cazo El Dictador ya no puedo entrar :P
EA5RCA -
EA7WL-L -
EA8ADH -
EA8CAG -
EA8CAZ-L -
EA8CDT -
EA8CLL -
EA8EE -
EA8RCT-R -
EAFL-R -
EB2CUJ-L -
EB3EHJ -
EB3EPP -
EB3TC -
EB4FLT-L -
EB4HJL-L -
EB5CCO -
EB5HUO -
EB7EEE-L -
EB8BLL-L -
EC1CWS-L -
EC2AMR -
ED5ZAA -
HP2BWJ-R -
HS4PXR -
I6XCN -
IR6UH-R -
IZ6FKI-L -
KA3KDL-R -
LU2ALE-L -
LU2HCR -
LU4HH-L -
LU5DNP-L -
LU6ASG -
LU7FBG-L -
LU7FDV-L -
LU7HBD-L -
PU2FPT-L -
PU2GCD-L -
PU2LOO-R -
PU2TMT-R -
PU4XUI-L -
PU5PEX -
PU6GCD-L -
PUGCD-L -
PUGGCD-L -
PY3PDT -
WP3MH-L -
XE1ROU-L -
Ex EC5
EB3TC
#50444  - 16 octubre, 2008 15:26
No seas tan duro Eusebio, que al menos aún te puedes conectar con el indicativo de EB !!!!
Yo ni eso, estoy con el de Bravo y el de Alfa ...... y por si intento con el del Radio Club......Tambien.
EB3TC, EA3DGI, EA3RDG !!!!!
Eduardo tengo tantas ganas de conectarme, que no duermo por las noches pensando en como.......
Vaya que no sé si lo que me quita el sueño son las ganas de conectarme o de participar en un concurso que se celebra en Septiembre :laugh: :laugh: :laugh:
En fín, bromas a parte, me quedan 3 indicativos que aún no sabe ( por lo que veo en la lista negra ).
Por cierto muy bueno lo de la Conferencia Linkados.... dice se la voy a pasar a Eusebio, me cae bien.
Xavier Pérez.
Presidente de DIGIGRUP-EA3
Secretário de AMIRED
EB3TC / EA3DGI / 25T606
JN01XL / JN01SU
Xavi Pérez
EA5GVP
#50599  - 17 octubre, 2008 12:15
Ex EC5
EB3TC
#50600  - 5 diciembre, 2008 21:45
A pasado un mes y medio desde que Eusebio empezó el link y hay cosas que no cambian:
Eusebio vuelve a ser amiguete de Eduardo, por tanto aquello que denunció y acusó de dictatorial ahora aprueba, ya que sigo baneado / expulsado sin razón aparente de todas sus conferencias.
Hay gente que no cambia...
Eusebio me has decepcionado, por ese cambio de rumbo sin quitar ningún post, por acusaciones que apruebas ahora, por que mantienes la lista de excluidos y por lo que escribes en el foro canario
http://www.my-forum.org/foros.php?id=131086
Xavier Pérez
EB3TC / EA3DGI
JN01XL / JN01SU
Xavi Pérez
Página 2 / 4
