Globo trans-atlanti...
Globo trans-atlantico Ahora KD2AUC-1
EB3TC
#19335  - 24 marzo, 2012 14:10
Globo de 5850g Plastic
The Project Blue Horizon 6 high-altitude transatlantic balloon flight is scheduled for Friday, March 23rd at 2300 EST from Owego, NY. The Project Blue Horizon team is attempting to break current Amateur Radio high-altitude balloon record for duration and duration (57 hours 2 minutes). We currently estimate a 4400 mile flight spanning 100 hours. Please see www.projectbluehorizon.com for detailed flight path information. The payload will be carried beneath a 54,000 cubic foot capacity helium-filled balloon cruising between 85,000 and 100,000 feet. During the flight amateurs worldwide are encouraged to monitor the N2XE CW telemetry beacons at 7.1023 and 10.1466 MHz. The balloon is also equipped with an APRS beacon at 144.39 MHz using the call sign KD2AUC. Amateurs can send reports via e-mail to pbh18.data@gmail.com or manually enter received data points at www.projectbluehorizon.com. More information about the program is at the Project Blue Horizon website. Launch and flight updates will also be available on Twitter @PBHVI. NOTE: If you or anyone else knows a Ham operator in the Azores who can communicate with our payload please send the contact information to pbh18.data@gmail.com. We will require communications with the payload as it approaches the Azores.
Los yankies han tirado un globo que intentan que cruze el charco, está en vuelo ahora
http://aprs.fi/info/a/KD2AUC-1
Podeis hacer el seguimiento por aprs.fi lleva baliza en 144.390 Mhz. que es la frecuencia americana, así que los amigos portugeses y los gallegos monitorizar esa frecuencia a ver si lo escuchais y poneis el globo en la red con un igate.
Xavi Pérez
EB3TC JN00HX DME 43121
http://www.fcr.cat/eb3tc
https://twitter.com/EB3TC
En solidaridad con EA1YN
d'allà on no n'hi ha no en pot mai rajar
EA3BNF
#183491  - 25 marzo, 2012 07:18
Seguiremos atentos al acontecimiento. Gracias Xavi, gracias Rafa por el aviso.
¿No lleva el icono equivocado? :huh:
EA5KGD
#183538  - 25 marzo, 2012 08:05
A la hora de este mensaje hace más de 6 horas que no reporta vía 144.390 MHz.
Kike
Enrique Gil EA5KGD
Almussafes, Valencia - IM99th
Dénia, Alicante - JM08au
EA4EOZ
#183539  - 25 marzo, 2012 11:24
Si el globo ha entrado lo suficiente en el Atlántico, ya no lo reciben y por tanto no pueden reportar más posiciones.
Si la cosa funciona y pasa cerca de las Azores, y hay alguien a la escucha allí en 144.390, pues a lo mejor lo reportan.
Si no pasa por las Azores y aparece directamente en África o Europa, pues como no haya nadie a la escucha en 144.390 difícilmente se va a reportar.
Sigo sin explicarme por qué si la intención es que llegue a Europa, no lo ponen directamente en 144.800.
Allá ellos.
#183552  - 25 marzo, 2012 12:39
Pero el descenso en altitud indicado en los últimos reportes dan a pensar que estará dándose un baño en el Atlántico.
EB3TC
#183556  - 25 marzo, 2012 15:11
Pues si Miguel Angel, es lo que pensé.
Si fuese al revés, que los Europeos tirasemos uno, lo hubieramos hecho, pero ellos son yankyes, fijate si son gilis que ponen de icono una casa......., ¿será publicidad de la pelicula que pone EA3BNF ? yo creo que es lo que dige yo..... gilis.....
En fín como dices Miguel Angel... alla ellos.
Referente a llegar, no creo, a eso de la 1 de la madrugada ya estaba bajando a 28.000 metros, se había mantenido a 32.000 durante muchas horas y el descenso había empezado, a menos de que cogiera una corriente cálida, este no llegó a las Azores.
Llevaba tambien telemetría en 7.1023 y 10.1466 MHz., se puede probar de sintonizar esas frecuéncias a ver si se escucha algo.
Es una pena que una operación de ese calibre, se prepare tan mal, esas cagadas las hacemos los EA's y salimos hasta en el "papus", pero ellos..... son yankies.
Xavi Pérez
EB3TC
#183566  - 25 marzo, 2012 19:43
Parece que algún radioaficionado de Azores lo ha escuchado.
Lo podeis seguir en https://twitter.com/#!/PBHVI
Xavi Pérez
EC1AME
#183590  - 25 marzo, 2012 21:03
domingo 20.40z.... problemas de altitud parecen arreglados... Volando a 32 mil metros de altitud
Fernando Casanova
EC1AME
www.ec1ame.com
www.ea1uro.com
https://www.facebook.com/fercasanovaRadio
https://www.facebook.com/ec1ame/
EA5DOM
#183492  - 26 marzo, 2012 09:19
Aparte del detalle de transmitir APRS solo en frecuencia americana, el proyecto es absolutamente increíble y esta a años luz de cualquier otro lanzamiento de aficionados
Es muy interesante seguir los comentarios en Twitter http://twitter.com/#!/PBHVI
porque van dando detalles muy interesantes sobre lo que puede hacer este globo
Quizas lo mas curioso sea el sistema automático de estabilización de altura, que consiste en un control que va lanzando lastre cuando desciende por debajo de los 17.000m (50k feet). Esto garantiza que se compensen las pérdidas de helio que inevitablemente se producen y gracias a esto se puede mantener la flotabilidad a largo plazo. Unido a que se esta utilizando un globo plástico (no de látex) y sin presión, osea que el helio en el interior no "hincha" las paredes del globo y por lo tanto no lo fuerza, es lo que explica que se pueda mantener volando tantas horas. Quizas la limitación mas grande sea la vida de la batería
Aqui hay un esquema del globo donde se puede apreciar de qué va todo esto http://twitter.com/#!/PBHVI/media/slideshow?url=pic.twitter.com%2FynY9tx8g
Otra mejora importante sobre anteriores lanzamientos ha sido la telemetría CW en HF. Hay que tener en cuenta que no se transmite constantemente sino que solo lo hace en minutos concretos de cada hora.
30 meter 10.14661 MHz 00, 20, 40 every hour
40 meter 7.10241 MHz 10, 30, 50 every hour
CW Morse Code with call sign N2XE followed by Latitude, Longitude, Altitude and Battery Voltage
En la página del proyecto se puede ver el tracking y la predicción
Flight Path
Observad que cuando pase de Azores tomará rumbo casi norte. Esto es debido a que sobre la península los vientos en altura son casi nulos ahora mismo y la corriente que circula desde NA se divide en dos, una hacia Irlanda y otra que baja a Africa. Así que va a ser difícil que el globo pase por EA .... o que caiga aquí ! :(
73 de Luis
URE BENIDORM
ea5dom@ure.es
Postales no, gracias
EB3TC
#183627  - 26 marzo, 2012 16:20
En Azores ya lo escuchan en 144.390 MHz.
2012-03-26 16:02:05 UTC: KD2AUC-1>APBL10,WIDE1-1,WIDE2-1,qAS,CU3HY:!4011.26N/03251.31W-085/041/A=092078V3A1www.projectbluehorizon.com
A las 18:02 EA sigue en 28.000 metros y viajando a 76 Km/h. dirección 85 grados.
Gracias Luis por tus explicaciones, pero sigo diciendo que es una chapuza, eso de poner solo la frecuéncia de USA y el icono de la casa....., puede ser muy profesional, pero esos pequeños detalles ...., en fin es una opinión.
A ver quien es el primer EA que la escucha y la pone en internet.
Saludos y gracias,
Xavi Pérez
EA3BNF
#183696  - 26 marzo, 2012 17:56
Pues parece que ha evitado las corrientes en chorro que lo hubiera dirigido directamente hacia el norte. Con la atmósfera tan estable que vamos a tener estos días encima de EA y si las baterías lo permiten, tiene pinta de que se va a estar buen rato emitiendo encima de nuestras cabezas. Ésto promete! :silly:
EB3TC
#183702  - 26 marzo, 2012 18:10
Pues si, si estabamos aburridos, tenemos diversión para unos dias...
Xavi Pérez
EB6AOK
#183703  - 26 marzo, 2012 19:48
estos yankees son como ellos solo.
si me da la vena pondré el equipo en SPLIT me niego a TX
en una frecuencia que no esta atribuida a eso en nuestro plan de bandas
una cosa es que se les escape un globo y otra que lo suelten con la intención
de que llegue por aquí
73 es Dx
Enric EB6AOK JM09RB
http://eb6aok.ure.es/
EA4EOZ
#183713  - 26 marzo, 2012 19:54
El globo no recibe nada, solo transmite en 144.390 MHz y esa es la cuestión:
Si preparas el lanzamiento de un globo que esperas que llegue a la región 1, que menos que usar las frecuencias de la región si tienes interés en hacerle seguimiento...
Porque vamos, igualito ir pidiendo a la gente que se ponga en la frecuencia a ver si oyen algo (que al final son 4 los que lo hacen) que ir ya en la frecuencia de APRS, que con que te oiga una sola de las miles de estaciones ya lo tienes hecho.
En fin...
EB3TC
#183714  - 26 marzo, 2012 19:56
Hola Enric:
Se trata de poner un equipo en RX 144.390 MHz. y poner las tramas a internet.
Según creo como tú lo tienes, siempre puedes desenchufar el conector de micro o como tú dices en split, RX 144.310 y TX 144.800 MHz. no es mala idea.
Xavi Pérez
EB2DJB
#183717  - 26 marzo, 2012 20:00
¡¡¡QUE VIENEEEEEE!!!
Está ya por las Azores, y viene derecho hacia la península.
Para quienes no tengáis (aún...) APRS,
he creado una paginita en la web de AiseKom donde se muestra en tiempo real la posición del globo.
http://aisekom.euskobyte.org/2012/03/26/blue-project-ataca-de-nuevo/
Mañana QRV todos los igates en 144.390... que viene derecho a la península!!
73's Rafa EB2DJB
Bilbao
Twitter: @eb2djb
EB3TC
#183720  - 26 marzo, 2012 20:06
A ver quien es el primer EA que pone una trama a internet !
Las baterias no durarán mucho, creo que mañana puede ser el día clave, por que a la velocidad que va y la altura que lleva, en 12 horas lo tenemos en EA.
PD. que la gente no ponga los igates en 144.390 a ver si van a meter todo el tráfico de EA en el segmento de SSB, solo RX !!!!!!!.
Xavi Pérez
EA4EOZ
#183721  - 26 marzo, 2012 20:11
El anterior globo que les llego hasta aquí fue perderlo en las Azores y empezarse a recibir en Portugal.
Sí, mañana por la mañana estará revoloteando por aquí si no le ocurre nada raro. Aunque veo que este va más despacio que el anterior...
EB2DJB
#183722  - 26 marzo, 2012 20:27
¿Pero hay alguien que saque por radio todo el tráfico que circula por APRS-IS? Porque a 1200 bps, puede estar todo el rato en TX...
Si, es conveniente deshabilitar la TX, no sea que justo en ese momento lance una baliza el globo...
Ah! Y es un globooo, no recibeeee, así que nada de llamarle, ni en APRS, ni en voz, ni en nada!!
Xavi, ¡¡APRENDE!! Un globo, que se cruza todo el atlántico ¡¡¡Y no se va al agua!!! jajajajaja
Viene, porque le está llamando su hermanito "Aise"... ya verás como cae al lado de Bilbao.... Voy a pasar la escoba en la terraza, para que no se pinche al aterrizar...
Tengo una curiosidad tremenda, por saber cómo han hecho para que se mantenga a 30.000 y no explote... Muy poca info sobre eso en la web.
73's Rafa EB2DJB
Bilbao
Twitter: @eb2djb
EB3TC
#183723  - 26 marzo, 2012 20:37
Si y cayó en el Mediterráneo, entre Baleares y Argélia.
Hicierón la misma operación, solo TX en 144.390 MHz. y no avisarón a nádie, esta vez, menos mal que Enrique EA3IK está en la lista de distribución de esta gente en USA y se enteró y dió la alarma, si no pasa como el otro.
Veremos como acaba este, estos yankies es para darles de comer aparte....
Xavi Pérez
