El ciclo 25, ¿el ma...
El ciclo 25, ¿el mayor de los últimos tiempos?
#355815  - 20 noviembre, 2020 09:59
La "ARRL Letter" de ayer ha publicado una reseña de un trabajo científico.
Academic Paper Predicts Sunspot Cycle 25 Could be Among the Strongest Ever
A research paper ( https://arxiv.org/pdf/2006.15263.pdf ), "Overlapping Magnetic Activity Cycles and the Sunspot Number: Forecasting Sunspot Cycle 25 Amplitude," by Scott W. McIntosh, Deputy Director of the National Center for Atmospheric Research in Boulder, et al., has concluded that Solar Cycle 25 could be among the strongest sunspot cycles ever observed, and will almost certainly be stronger than the just-ended Solar Cycle 24 (sunspot number of 116). The scientists say it will also most likely be stronger than Solar Cycle 23 (sunspot number of 180). As the abstract explains:
"The sun exhibits a well-observed modulation in the number of spots on its disk over a period of about 11 years. From the dawn of modern observational astronomy, sunspots have presented a challenge to understanding -- their quasi-periodic variation in number, first noted 175 years ago, stimulates community-wide interest to this day. A large number of techniques are able to explain the temporal landmarks, (geometric) shape, and amplitude of sunspot 'cycles;' however, forecasting these features accurately in advance remains elusive.
"Recent observationally motivated studies have illustrated a relationship between the sun's 22-year magnetic cycle and the production of the sunspot cycle landmarks and patterns, but not the amplitude of the sunspot cycle. Using (discrete) Hilbert transforms on more than 270 years of (monthly) sunspot numbers, we robustly identify the so-called 'termination' events that mark the end of the previous 11-year sunspot cycle, the enhancement/acceleration of the present cycle, and the end of 22-year magnetic activity cycles. Using these, we extract a relationship between the temporal spacing of terminators and the magnitude of sunspot cycles.
"Given this relationship and our prediction of a terminator event in 2020, we deduce that Sunspot Cycle 25 could have a magnitude that rivals the top few since records began. This outcome would be in stark contrast to the community consensus estimate of Sunspot Cycle 25 magnitude." (Fuente: ARRL Letter, November 19, 2020)
Según dicen, este ciclo va a ser muy activo, con un número de manchas solares de hasta 180, en comparación con el de 116 de este ciclo. Esperemos que estén acertados.
EA1CN, EA3TA, EA3ERD y 3 personas más reaccionaron
EA2AJO
#355823  - 20 noviembre, 2020 11:43
Ya podría ser verdad..... 🙂
73 y salud.
EAQRP-122 - - - URE-51622
EGV-40 By EA3GCY =2,5W
Yaesu ft-818 =6W
Pixie 7,023Mhz =0,6w
QRP Labs QCX CW 30m=5W
Howes 40m =2W
EA1ETV
#355826  - 20 noviembre, 2020 12:10
Si fuesen, con al menos, más de 300 manchas solares, entonces, sí que sería un gran récord de propagación en todas las bandas en todo el mundo. No habría ni problema...
EA1ETV
QTH Locator: IN53UI41
UserID DMR: 2140294
Correo-e: ea1etv@gmx.es
Web: https://www.sjlopezb.es/
EA5BRE
#355834  - 20 noviembre, 2020 14:39
@ea1etv
Estudios recientes motivados por la observación han ilustrado una relación entre el ciclo magnético de 22 años del sol y la producción de los patrones y puntos de referencia del ciclo de las manchas solares, pero no la amplitud del ciclo de las manchas solares. El uso de transformaciones (discretas) de Hilbert en más de 270 años de ( mensuales) números de manchas solares, identificamos de manera sólida los llamados eventos de 'terminación' que marcan el final del ciclo anterior de manchas solares de 11 años, la mejora / aceleración del ciclo actual y el final de los ciclos de actividad magnética de 22 años. de estos, extraemos una relación entre el espaciamiento temporal de los terminadores y la magnitud de los ciclos de las manchas solares.
Y yo sin enterarme...Oye..!!
73..Luis
EA3ERD reaccionó
EA1ETV
#355837  - 20 noviembre, 2020 15:05
@ea5bre
Así es Luis.
EA1ETV
UserID DMR: 2140294
EA2AJO
#355843  - 20 noviembre, 2020 15:55
@ea1etv
Tampoco hacen falta 300 manchas, 180 están ya muy bien, si con 116 de máximo en este último ciclo con un simple dipolo y 5 W en BLU he contactado con Australia varias veces, que más lejos no se puede llegar, si llegamos a 180 habrá que probar con 1W......y si alguna vez llegamos a 300, cosa que yo no creo que vea, con 0,1W se podría llegar hasta el otro lado del mundo con un simple dipolo y en FM.
73 y salud.
Yaesu ft-818 =6W
Howes 40m =2W
EA3ERD reaccionó
EA1ETV
#355845  - 20 noviembre, 2020 16:27
@ea2ajo
No entendiste, era una metáfora. No es que sea así, ni mucho menos. Pero es un modo previsible.
EA1ETV
UserID DMR: 2140294
EA3ERD
#355856  - 20 noviembre, 2020 19:27
Pues ojalá se cumpla el vaticinio.
Como "QRPero" no soy demasiado ambicioso, de manera que me conformo con un puñado de manchas que alegren la actividad en QRP.
Pecas solares
73, Ernesto - EA3ERD
EA3ERD desde 2004
EA1CN, EA5DO y EA2AJO reaccionaron
EA4AFP
#355866  - 21 noviembre, 2020 09:05
Buenas,
este estudio estaba recogido en una recopilación de Carl, K9LA, a la que se aludía en la sección "The K7RA Solar Update" de la página web de la ARRL en agosto y de la que ya habló en este foro.
Cuando Jon ha puesto la nota, pensaba que era porque se había corregido la predicción hecha en la publicación inicial. Pero no es así. Si se mira el artículo, la cosa queda clara, "It is the intent of the authors to submit a clarification to the SC25 prediction presented herein when the SC24 terminator occurs."
El dato usado para calcular la fuerza del próximo ciclo es una estimación, ya lo recoge la "ARRL Letter", y no el real. Así que habrá que esperar a tener una predicicón más fina.
73 jose   EA4AFP
y ojo, que en mi interior tengo la certeza de que se quedan cortos en sus estimaciones
#355876  - 21 noviembre, 2020 14:15
Lo siento, José, no sabía que se había citado ya. Tal como escribí lo publicó la ARRL en sus Letter, por lo que pensé que era nuevo. Hoy los amigos del Southgate ARC también se hacen eco de ello. Esperemos que los científicos solares acierten.
EA4AFP
#355878  - 21 noviembre, 2020 15:50
@ea2sn
no veas el alegrón que me llevé al verlo porque pensaba que era la versión corregida del artículo con el "SC terminator" real y no estimado.
Y no tienes que sentir nada, soy uno de los muchos que disfrutan con tus contribuciones al foro y siempre que veo algo tuyo pincho porque seguro que aprendo algo. Así que en cuanto salgan nuevas noticias de este tema, quedas encargado de ponerlas.
Por cierto, que la gráfica sobre el comportamiento de las manchas según el hemisferio en la que salieron, comparando C24 con C23, da que pensar.
Espero volver a leer tus siempre interesantes contribuciones.
73  jose   EA4AFP
EA3TA
#356019  - 23 noviembre, 2020 19:37
 😀 Otra vez estamos con 3 manchas solares y el SFI casi a 90.
73, Juan - EA3TA
#356046  - 24 noviembre, 2020 13:11
A última hora de ayer, 23, la AR2785 soltó un zambombazo de clase C4. Según vaya rotando el Sol la tendremos más a la vista, a ver si durante el finde, que es el CQWW, nos da un poco de vidilla. Aunque esperemos que los UV no bloqueen las bandas bajas como hicieron ayer en zonas de Australia y toda Nueva Zelanda (ver https://spaceweather.com/ y diagrama de Rayos X en https://www.swpc.noaa.gov/ )
Cuidaos mucho.
EA1ETV
#356047  - 24 noviembre, 2020 13:16
¡Huy! ¡Va a ser “la gorda”! Entonces, sí que va a haber propagación. Aunque, va a haber más fuerte la propagación en meses.
EA1ETV
UserID DMR: 2140294
