Terremoto en Haití ...
Terremoto en Haití - Frecuencias de trabajo
EA4FSI
#7982  - 13 enero, 2010 11:29
Buenos días,
Adjunto un mensaje que me acaba de llegar y que no he tenido tiempo de traducir. Desde IARU se solicita mantener libres de tráfico las frecuencias 7.045 MHz y 3.720 MHz para facilitar las operaciones de socorro en la zona de Haití tras el terremoto de ayer.
Información actualizada en la web de IARU-R1.
73 de Ismael - EA4FSI
Radio amateurs are requested to keep 7.045MHz and 3.720MHz clear for any emergency traffic resulting from the Earthquake which struck Haiti on 12th January 2010 in case any Haitian hams manage to get on the air, and in case of other related events in surrounding areas, including aftershocks.
Arnie Coro, CO2KK, IARU-R2 Area C Emergency Coordinator calls reported at 0245 UTC that they haven't been able to communicate with any radio amateur in Haiti but if there is presence from amateurs from other countries in the area that also felt the tremor. We ask for your support to keep this frequencies clear.
The following is from an e-mail from CO2KK posted to the CQ/WorldRadio Online Newsroom:
"A few minutes after the earthquake was felt in eastern Cuba's cities, the Cuban Federation of Radio Amateurs Emergency Net was activated, with net control stations CO8WM and CO8RP located in the city of Santiago de Cuba, and in permanent contact with the National Seismology Center of Cuba located in that city.
Stations in the city of Baracoa, in Guantanamo province, were also activated immediately as the earth movements were felt even stronger there, due to its proximity to Haiti. CO8AZ and CO8AW went on the air immediately , with CM8WAL following. At the early phase of the emergency, the population of the city of Baracoa was evacuated far away from the coast, as there was a primary alert of a possible tsunami event or of a heavy wave trains sequence impacting the coast line at the city's sea wall ...
Baracoa could not contact Santiago de Cuba stations on 40 meters due to long skip after 5 PM local time, so several stations in western Cuba and one in the US State of Florida provided relays. CO2KK, as IARU Region II Area C Emergency Coordinator, helped to organize the nets , on 7045 kHz and also on 3720 kHz, while local nets in Santiago de Cuba and Baracoa operated on 2 meters.
As late as 9,45 PM local time 0245 UTC we have not been able to contact any amateur or emergency services stations in Haiti.
Amateurs from the Dominican Republic, Puerto Rico, Venezuela were monitoring the 40 meter band frequency, that I notified to the IARU Region II executive Ramon Santoyo XE1KK as in use for the emergency, requesting that 7045 kHz be kept as clear as possible ...
We are still keeping watch on 7045 kHz hoping that someone in Haiti may have access to a transceiver and at least a car battery to run it.
All information that has so far come from the Cuban seismologists tell us of a very intense earthquake, and also of the possibility of other events following.
Following the advice of the geophysicists, we are keeping the 7045 and 3720 kiloHertz frequencies active until further notice."
Information from Ramon Santoyo V, XE1KK, Jim Linton VE3PC and the CQ / WorldRadio Online Newsroom
73,
Greg, G0DUB
IARU Region 1 Emergency Communications Co-Ordinator
73 de Ismael
EA4FSI - IN80EN
Web: http://www.ipellejero.es/
Blog: http://emercomms.ipellejero.es/
Twitter: @ipellejero
EC7ZK
#93304  - 13 enero, 2010 11:35
Gracias por el aviso Ismael, le daré publicidad en varios sitios.
Toni / EC7zK
https://ec7zk.wordpress.com/
Carmona (Sevilla)
EA2CCG
#93306  - 13 enero, 2010 12:19
yo tambien lo he posteado en mi blog.
Joaquín
http://ea2ccg.blogspot.com/
EA4FSI
#93307  - 13 enero, 2010 14:02
La traducción:
Se solicita a todos los radioaficionados mantener libres las frecuencias 7.045MHz y 3.720MHz, para posibilitar el envío de cualquier tráfico de emergencia resultante del terremoto que ha asolado Haití el 12 de enero de 2010, para el caso de que los radioaficionados haitianos consigan ponerse en el aire y en caso de que se produzcan otros eventos relacionados en áreas cercanas, incluyendo réplicas del terremoto.
Arnie Coro, CO2KK, Coordinador de Emergencias del Área C de IARU-R2, informó a las 0245 UTC que todavía no se han establecido comunicaciones con ningún radioaficionado de Haití, pero que hay actividad de radioaficionados de otros países de la zona en los que también se ha sentido el temblor. Solicita apoyo para que dichas frecuencias se mantengan libres.
El párrafo siguiente está extraído de un email de CO2KK, publicado en la CQ/WorldRadio Online Newsroom:
"Unos minutos después de que el terremoto se sintiese en las ciudades del este de Cuba, se activó la red de emergencia de la Federación Cubana de Radioaficionados, siendo las estaciones de control de la red CO8WM y CO8RP, ubicadas en la ciudad de Santiago de Cuba y en contacto permanente con el Centro Nacional Sismológico de Cuba, ubicado en esa misma ciudad.
Inmediatamente se activaron estaciones en la ciudad de Baracoa, en la provincia de Guantánamo, donde el temblor se sintió incluso con más fuerza debido a su proximidad a Haití. CO8AZ y CO8AW se activaron inmediatamente, seguidos por CM8WAL. En la primera fase de la emergencia, la población de la ciudad de Baracoa fue evacuada lejos de la costa y se activó una alerta primaria de posible tsunami o de posibles secuencias de olas fuertes que podrían impactar en la línea costera de la ciudad.
Desde Baracoa, no se pudo contactar con estaciones de Santiago de Cuba en 40 metros, debido a la excesiva longitud del salto después de las 5 PM hora local, por lo que varias estaciones del oeste de Cuba y una del estado norteamericano de Florida proporcionaron enlaces. CO2KK, como Coordinador de Emergencias del Área C de la IARU Región II, ayudó a organizar las redes en 7045 kHz y en 3720 kHz, mientras que las redes locales en Santiago de Cuba y Baracoa se organizaron en 2 metros.
Hastas las 9,45 PM hora local (0245 UTC) no hemos sido capaces de establecer contactos con ninguna estación de radioaficionado o de emergencias en Haití.
Radioaficionados de la República Dominicana, Puerto Rico y Venezuela están monitorizando la frecuencia de la banda de 40 metros, informando al ejecutivo de IARU Región II Ramón Santoyo (XE1KK) de su activación para la emergencia, solicitando que 7045 kHz se mantenga lo más libre posible de tráfico.
Todavía estamos monitorizando la frecuencia de 7045 kHz con la esperanza de que alguien en Haití pueda tener acceso a una radio y al menos una batería de coche para poder operarla.
Toda la información que hasta ahora ha llegado de los sismólogos cubanos nos indica que se ha tratado de un intenso terremoto y que hay posibilidades de que haya réplicas.
Siguiendo los consejos de los geofísicos, mantendremos activas las frecuencias 7045 y 3720 kHz hasta nuevas noticias."
Información de Ramón Santoyo V (XE1KK), Jim Linton (VE3PC) y la CQ / WorldRadio Online Newsroom
73 de Ismael - EA4FSI.
73 de Ismael
EA4FSI - IN80EN
EA3BOX
#93303  - 13 enero, 2010 14:31
Hola, os comento que estoy de vacaciones con mi esposa en la república Dominicana (HI) y os comento para tranquilidad de todos que por lo menos al sur de la Isla, NO HAY DAÑO NINGUNO EN ABSOLUTO, está todo en perfectas condiciones. Joan EA3BOX.
ESTARÉ QRV ENTRE LAS 23 y LA 1 hora de EA alrededor de 7150 Kcs, con el indicativo HI7/EA3BOX. Salu2.
Joan Solà Vilaseca.
Sant Feliu de Guixols
Costa Brava, Girona.
EA4FSI
#93302  - 13 enero, 2010 18:27
Hola Joan,
Me alegro de que por allí no os haya afectado mucho. He estado revisando mis correos y hace justo un año estuve echando una mano a un equipo que trataba de establecer enlaces HF NVIS entre Saint Michel de l'Atalaye y una zona montañosa de Gonaives, ambos en Haití. Consiguieron trabajar en torno a 5 MHz. Te lo comento por si tienes oportunidad de escuchar en torno a esa frecuencia, por si hubiera alguien operando allí, ya que te encuentras dentro de su radio de cobertura NVIS y por las noticias que están llegando el tema de las comunicaciones está muy complicado en la zona.
73 de Ismael
EA4FSI - IN80EN
EA4FSI
#93301  - 13 enero, 2010 20:33
Acabo de recibir el siguiente mensaje de LU1AS, Coordinador de Emergencias del Área G de IARU-R2:
"Además de las frecuencias 7.045MHz y 3.720MHz de la red de emergencias de IARU R2, se solicita también dejar libres las correspondientes a la red SATERN (14.265 MHz, 14.300 MHz, 7.265 MHz, 3.977 MHz)
SATERN ha comenzado a aceptar requerimientos de tráfico sanitario y de localización de personas, desde su Web site http://qso.com/satern/emailfrm.htm "
73 de Ismael
EA4FSI - IN80EN
EA4FSI
#93300  - 13 enero, 2010 20:50
Otro mensaje que acaba de entrarme de G0DUB, Coordinador Regional de Emergencias de IARU-R1:
"Del CQ / WorldRadio Online Newsroom:
Se está empezando a escuchar actividad de radioaficionados desde Haití, tras el devastador terremoto de ayer.
El padre John Henault, HH6JH, en Puerto Príncipe, consiguió contactar el miércoles por la tarde con la Red Intercontinental de Asistencia y Tráfico (IATN) en 14.300 MHz, la frecuencia global central de actividad de IARU para comunicaciones de emergencia. Según enlaces monitorizados por W2VU, el padre John informó que tanto él como los suyos estaban a salvo, pero que no disponía ni de suministro eléctrico ni de teléfono. Se encontraba operando con baterías y esperaba conseguir un grupo electrógeno a última hora del día. Solicitó a la estación con la que contactó, William Sturridge (KI4MMZ), en Flagler Beach, Florida, que telefonease a algunos allegados para informarles de que se encontraba bien.
Las siguientes frecuencias están en uso con tráfico relacionado con el terremoto y deberían mantenerse libres, a no ser que se pueda proporcionar la asistencia que se requiera: 14.300 (IATN), 14.265 (SATERN), 7.045 (IARU Región 2) y 3.720 (IARU Región 2) kHz. Se podrán activar frecuencias adicionales en otras bandas durante otras horas del día, por lo que se solicita que se escuche cuidadosamente antes de transmitir para evitar interferir al tráfico de emergencia".
Mensaje original:
>From the CQ / WorldRadio Online Newsroom:
Some ham radio activity from Haiti is beginning to be heard,following yesterday's devastating earthquake.
Father John Henault, HH6JH, in Port-au-Prince, made contact late Wednesday morning with the Intercontinental Assistance and Traffic Net (IATN) on 14.300 MHz, the IARU Global Centre of Activity frequency for emergency communications. Based on relays monitored at W2VU, Father John reported that he and those with him were safe, but had no power and no phone service. He was operating on battery power and hoping to get a generator running later in the day. He asked the station copying him, William Sturridge, KI4MMZ, in Flagler Beach,Florida, to telephone relatives with information that he was OK.
The following frequencies are in use for earthquake-related traffic and should be kept clear unless you are able to provide requested assistance:14300 (IATN), 14265 (SATERN); 7045 (IARU Region II) and 3720 (IARU Region II) kHz. Additional frequencies may be activated on different bands at different times of day, so be sure to listen carefully before transmitting to make sure you are not interfering with emergency traffic.
73 de Ismael
EA4FSI - IN80EN
EA1R
 EA1R
#93371  - 13 enero, 2010 21:41
Como Puse en el otro hilo que lleva el mismo titulo que este, he podido escuchar a HH6JD a eso de las 19:00:
Escuchado ahora con señales de 3/4 y mucho qsb (muy justito) a HH6JH en qso con estaciones USA y caribe (mucho mejor rx), en 14300.00
El ultimo qso que escuché en 20M fué con una estacion de Martinica, a la que le dio las frecuencias que estan usando y le informó un poco como estan las cosas, depués y ya en peores condiciones me pareció escuchar que hacia qsy a 40m.
A ver si mañana hay ocasion de escucharlo otra vez y en mejores condiciones.
EA4FSI
#93299  - 14 enero, 2010 00:33
Como era de esperar, también hay actividad en Echolink.
IRESC (International Radio Emergency Support Coalition) ha activado su nivel 4 de alerta y solicita la asistencia de operadores que hablen francés:
IRESC LEVEL 4 (ORANGE) ACTIVATION
EARTHQUAKE HAITI
7.0MW earthquake
IRESC members please report to the *IRESC* Echolink conference and also monitor SPARK.
IRESC particularly requests assistance from French speakers. All members who can take an NCS duty are requested to register a slot on the NCS CALENDAR and monitor the NCS LIVE text conference on IRESC SPARK.
Más información en: http://www.iresc.org/
P.S.: espero no ser pesado, pero me parece interesante compartir la información que me va llegando.
73 de Ismael
EA4FSI - IN80EN
EA8DD
#93411  - 14 enero, 2010 01:03
Hola a todos
Ismael, toda informacion es buena, lo que no veo muy bien es el jaleo que tienen montadas varias estaciones de la zona ocupando la frecuencia de 7045 y llamando como locos a Haiti y sobremodulandose entre ellos.
Cualquiera diría que se solicitó qrx en esas frecuencias...oir para creer
73 de EA8DD, Dani
EA4FSI
#93298  - 14 enero, 2010 11:04
Nuevo mensaje de G0DUB, Coordinador Regional de Emergencias de IARU-R1:
RCD y URDA en ruta hacia Haití:
Víctor Baez, HI8VB, Secretario del Radio Club Dominicano (RCD), informa que el RCD y la URDA, Unión Dominicana de Radioaficionados, se están preparando para dirigirse a Puerto Príncipe a primera hora de la mañana del viernes 15 de enero, con el objetivo de instalar una estación de radio de emergencia, HI8RCD/HH y una estación móvil.
Víctor tiene un blog en el que esperamos que pueda publicar más noticias sobre Haití: www.hi8vb.tk
Mensaje original:
RCD and URDA en route to Haiti
Victor Baez, HI8VB, Secretary of the Radio Club Dominicano (RCD) reports that the RCD with UDRA, Unión Dominicana de Radio Aficionados, are preparing to go to Port au Prince early morning of Friday January 15 to install an emergency radio Communications stastion, HI8RCD/HH, and a mobile station.
Victor has a blog which hopefully he will update with more news from Haiti: www.hi8vb.tk
Información adicional del blog de HI8VB:
La comitiva estará compuesta inicialmente, aparte de Pepe Goico, por los miembros radioaficionados del RCD y la UDRA siguientes: HI8FLB, HI8CJG, HI8DBF, HI8SAR, HI8JLH, HI8ROD y HI3TEJ
73 de Ismael
EA4FSI - IN80EN
EA4FSI
#93436  - 15 enero, 2010 02:13
Buenas noches,
Según informa la ARRL, en la tarde del miércoles se pudo escuchar a una segunda estación desde Haití. Se trata de Jean-Robert Gaillard, HH2JR, transmitiendo desde Puerto Príncipe gracias a un grupo electrógeno prestado por su vecino. Consiguió contactar con W3ZU en Estados Unidos, quien pudo facilitarle un phone-patch.
Merece la pena seguir a la escucha por si llega el caso de ayudar y mantener libres las frecuencias de emergencia.
73 de Ismael
EA4FSI - IN80EN
EA4FSI
#93579  - 15 enero, 2010 10:59
Actualización de G0DUB, Coordinador Regional de Emergencias de IARU-R1 (15/01/2010 01:34 EA):
Siguen llegando algunos informes de situación desde Haití, pero de momento no hay informaciones relativas a supervivientes ni se está pasando tráfico relacionado con asuntos sanitarios y sociales.
Cualquier persona que trate de localizar a familiares o amigos en Haití, debe registrar los detalles en la Federación Internacional de la Cruz Roja, en;
http://www.familylinks.icrc.org/web/doc/siterfl0.nsf/htmlall/familylinks-haiti-eng?opendocument
El ICRC está cooperando con la Sociedad Haitiana de la Cruz Roja y otras Sociedades de la Cruz Roja y la Media Luna Roja de todo el mundo para acelerar el proceso de restauración del contacto entre miembros separados de familias.
Grupos adicionales de apoyo de radioaficionados se están dirigiendo a la isla. Víctor Baez, HI8VB, Secretario del Radio Club Dominicano (RCD) informa que el RCD y la URDA, Unión Dominicana de Radioaficionados, se están preparando para desplazarse a Puerto Príncipe a primera hora del viernes 15 de enero, para instalar una estación de radiocomunicaciones de emergencia, HI8RCD/HH y una estación móvil. Víctor tiene un blog en el que esperamos que pueda proporcionar noticias actualizadas sobre Haití: www.hi8vb
Algunos países de la Región 1 han activado a sus propias estaciones para responder ante el desastre. Jari Perkiömäki, OH6BG, ha realizado algunas predicciones de propagación para las bandas de 40m y 20m, asumiendo un transmisor con 10 W de potencia (muy baja) y una antena de compromiso. En todos los puntos de recepción en el mapa (hay varios centenares de receptores similares en una misma cuadrícula), se asume que hay una antena cuya ganancia es equivalente a la de una Yagi de 3 elementos ubicada a 55 pies (unos 17 metros) sobre el suelo. Sus predicciones pueden descargarse desde;
http://www.voacap.com/hh.zip - Predicciones de propagación en 7 MHz
http://www.voacap.com/hh14b.zip - Predicciones de propagación en 14 MHz
Alonso, EA3EPH, ha generado una predicción alternativa de MUF, disponible en español en;
http://www.ipellejero.es/remer/emercomms/Estudio_Circuitos_HF_desde_Puerto_Principe.pdf
En internet hay conexiones en directo con receptores bien ubicados en la Región 2, desde donde puede monitorizarse el tráfico. Estas conexiones están disponibles en: http://bit.ly/69Mqbr
Mensaje original:
Some status reports are now coming from Haiti but at the moment , no
data regarding survivors or any other 'Health and Welfare' traffic is
currently being passed.
Anyone trying to trace family or friends in Haiti should register their
details with the International Federation of the Red Cross at;
The ICRC are co-operating with the Haitian Red Cross Society and other
Red Cross/ Red Crescent societies around the world to accelerate the
process of restoring contact between separated family members.
Further amateur radio support is on its way to the island, Victor Baez,
emergency radio Communications station, HI8RCD/HH, and a mobile station.
Haiti: www.hi8vb.tk
Some countries in Region 1 have activated their own stations to respond
to the disaster, Jari Perkiömäki, OH6BG has produced some propagation
predictions for 40m and 20m assuming the transmitter has an output power
of 10 watts (very low power) and a compromise antenna. On all receiver
sites on the map (there are hundreds of similar receivers in a grid), it
is assumed that there is an antenna whose gain is equivalent to that of
an 3-element Yagi and is 55 ft (appr. 17 meters) above the ground. His
predictions can be downloaded from;
http://www.voacap.com/hh.zip - 7Mhz propagation predictions
http://www.voacap.com/hh14b.zip - 14MHz propagation predictions
Alonso EA3EPH has produced an alternative MUF prediction available in
Spanish at;
Live feeds are available on the internet from receivers better placed in
Region 2 where any traffic can be monitored, these feeds are available
at http://bit.ly/69Mqbr
73 de Ismael
EA4FSI - IN80EN
EA4FSI
#93599  - 15 enero, 2010 12:04
Información facilitada por el Radio Club Dominicano (RCD), en su grupo de Facebook:
"En la Noche de siniestro los radioaficionados recibieron la solicitud de Cruz roja Dominicana para el uso de un repetidor aficionado para la comunicación entre Haiti y RD el cual empezó a operar inmediatamente asistidos por el Señor Joal Cleto HI8RYF y Angel Carpio HI8ABC, actualmente otro grupo dirigido por Joal Cle...to está instalando otros repetidores para facilitar la comunicación.
EL Club Dominicano envió equipos de comunicación al vecino país, se espera que puedan trasmitir desde la embajada Dominicana en Pétionville en las frecuencias 7.045 7.065 7.265 3.720 (establecidas por la IARU para casos de desastres) y en 2m 147.970 repetidor.
Los Radio Aficionados que van a operar la estación de Radio Club Dominicano con las siglas HI8RCD/HH son:
Teddy Jimenez HI3TEJ
Candido Guzmán HI8CJG
Fausto Alvarado HI8FLB
En agradecimiento al Sr. Goyco quien ofreció la logística de transporte hacia el vecino país y al INDOTELl por la facilidad de las frecuencias."
Según un contacto que he tenido con ellos, esperan activar la estación sobre las 10:00 AM, hora local de Haití. Su objetivo principal es tratar de poner en contacto a personas desaparecidas.
Su operación está previsto que dure más de 3 días, e informan que la situación es difícil por la ausencia de comida, electricidad y agua.
73 de Ismael
EA4FSI - IN80EN
EA2FT
#93410  - 15 enero, 2010 12:07
En el siguiente enlace podéis escuchar el streaming cortesía de N4QLB
monitorizando 80 metros: 3997.70 LSB
Enlace:
www.ustream.tv/channel/shackfeed
73s.
EB2BPH
Juan
www.ea2ft.com
Juan Ángel
IN91LL
EA4FSI
#93607  - 15 enero, 2010 15:14
Actualización de G0DUB, Coordinador Regional de Emergencias de IARU-R1, en el sitio web de IARU-R1 (15/01/2010 13:54 EA).
Nota: solamente traduzco la parte que no teníamos. El resto hace referencia a informaciones sobre el RCD publicadas anteriormente.
"Las frecuencias en uso en Haití parecen ser actualmente:
14.300MHz, 14.265MHz, 7.045MHz , 7.065MHz, 7.265MHz, 3.720MHz, 3.977MHz y un repetidor de 2m en 147.970MHz
La International Radio Emergency Support Coalition (IRESC) también está activa en el nodo 278173 de Echolink.
Se ruega mantener libres estas frecuencias incluso aunque no se escuche ningún tráfico de emergencia - las estaciones de la zona usan muy baja potencia y pueden sufrir interferencias."
Mensaje original:
Frequencies in use from Haiti are now believed to be;
14.300MHz, 14.265MHz, 7.045MHz , 7.065MHz, 7.265MHz, 3.720MHz, 3.977MHz and a 2m repeated on 147.970MHz
The International Radio Emergency Support Coalition (IRESC) is also active on EchoLink node 278173
Please keep clear of these frequencies even if you cannot hear any emergency traffic - stations in the area are low powered and may suffer interference.
Interesting news from the Radio Club Dominicano (RCD) group in Facebook ( Translation by Ismael EA4FSI ):
"During the night of the tragedy, amateur radio operators received a message from the Dominican Red Cross, requesting the use of an amateur radio repeater in order to establish communications between Haiti and the Dominican Republic. This repeater started to operate immediately, with the assistance of Mr Joal Cleto HI8RYF and Mr Angel Carpio HI8ABC. Mr Joal Cleto is now leading another group installing additional repeaters in order to improve the communications.
The Radio Club Dominicano has sent communication teams to the neighbour country, in the hope of transmitting from the Dominican Embassy Pétionville, in the following frequencies: 7.045, 7.065, 7.265 and 3.720 (recommended for disasters by IARU) and the 2m repeater in 147.970.
The hams which will operate the Radio Club Dominicano station with callsign HI8RCD/HH are:
We would like to thank Mr. Goyco, who offered the transport logistics to the neighbour country, and INDOTEL for granting the frequencies."
73 de Ismael
EA4FSI - IN80EN
EA4FSI
#93297  - 15 enero, 2010 18:20
Nota del Radio Club Dominicano (RCD) hace una hora:
"Nota el grupo que va a instalar la repetidora esta detenido en el 15 de azua por un problema en uno de los vehiculos por lo que la instalación y programación de equipos de cruz roja tardara un poco mas!"
73 de Ismael
EA4FSI - IN80EN
EA4FSI
#93296  - 15 enero, 2010 18:25
URGENTE
Acaban de comunicar por la red de SATERN que un operador de radio de Haití está en el aire en 7.045.
Se están solicitando operadores que hablen francés.
Feed de audio de SATERN: http://www.radioreference.com/apps/audio/?action=wp&feedId=3577
Frecuencia de trabajo de SATERN: 3.977
Estación coordinadora: "Net Control".
73 de Ismael,
EA4FSI.
73 de Ismael
EA4FSI - IN80EN
EA4FSI
#93295  - 15 enero, 2010 21:16
Desde IARU-R2 se informa que HK3L está en ruta hacia Haití, integrado en el grupo de Protección Civil de Colombia.
Más información en Twitter:
http://twitter.com/iaru_r2
Por otro lado, estamos realizando gestiones para que el contingente internacional de Cruz Roja que se encuentra en Santo Domingo y del que forma parte el colega EB9GF, pueda coordinarse con el Radio Club Dominicano (RCD) si es necesario. El equipo del RCD que se está desplazando a Haití se encuentra ahora mismo en la ciudad fronteriza de Jimani, esperando ser escoltados por personal de MINUSTAH.
Finalmente, radioaficionados cubanos han estado solicitando apoyo para cubrir la frecuencia 7.045 MHz con operadores capaces de comunicarse en francés, ya que hay estaciones haitianas que están tratando de ponerse en el aire en dicha frecuencia e idioma. Radioaficionados canadienses están intentándolo incluso con 1 kW, pero no tienen condiciones de propagación. Tras difundirse esta alerta, los radioaficionados de la FNRASEC francesa, movilizados por el gobierno de su país de forma continuada al menos hasta mañana, van a tratar de activar sus estaciones de las Islas Caribeñas y las Antillas. La estación central de FNRASEC en París mantiene escucha continua.
73 de Ismael,
EA4FSI.
73 de Ismael
EA4FSI - IN80EN
