Opiniones sobre el ...
Opiniones sobre el cluster
EA3NY
#3529  - 27 febrero, 2009 17:23
Extraido del blog de F6EXV. No hará mucho tiempo escribí algo remotamente parecido pero que en definitiva opinaba en la misma dirección. Aunque F6EXV opina al final que el cluster es maravilloso, yo no estoy muy de acuerdo. Lo único que sirve es para acortar todavía más las diferencia entre hablar con otra persona en un chat de internet a la de cazar un DX. Está en inglés.
Hi !
DXing is no longer what it used to be … thanks to new technologies. When I started Dxing, over 30 years ago, rare country hunters would organize VHF network, or would even telephone each other as soon as an extraordinary DX or a missing one would appear on the air. In Bordeaux, we would monitor 145.450 in those days. So we could sometimes hear brief annoucements like “VK9YA is presently on 21.295, split up 5 ; here is F6BKI”.
Today, all internet-connected Dxers share the results of their hunts live, but also the hunt of the whole world, thanks to the world-wide cluster network. A ZL8 appears on 17m, and the whole world knows in a matter of one minute.
Nevertheless, erroneous or useless info occasionnally appear, and I thought it would be nice to remind users of basic rules which, in my humble opinion, should rule the use of the cluster.
The cluster is not meant to make QSO
It is more and more common to see two connected hams exchange reports on the cluster, sometimes after having taken a sked on 160m for example. Reports should not be passed on the cluster, but only on the air, otherwise why not telephone each other to make QSO ?? Giving reports over the cluster may invalidate the QSO for DXCC.
The cluster is not meant to spot stations you cannot hear How many times have we seen info like :
DX de F6XYZ 21260.0 FK8ZZ No copy in Paris
Most of the time, the info was given a few minutes before by someone else who copies the DX; Imagine all the
connected stations informing the world they are not copying that DX…The clusters would be full of useless info.
The cluster is not a chat box
Limit the use of “announce” and “announce/full” to what is really necessary. Before asking for a QSL manager, search the internet or the cluster itself, typing “SH/QSL DX0AA”. It is likely the info will be displayed, without you to bother the world. Avoid chating with your local friends : use the “talk” command rather than “Ann”.
If you want to inform that you have received a card for a recent Dxpedition and you have been lucky to be one of the firts to receive it, use “ann” rather than spot the DX like :
DX 14000.0 KH8SI QSL received today
In that case, remember that the spot will be trated like a real one and computer bells will ring all over the world for those with logging programs indicating that entity is still needed on that band. These guys will hate you forever… Comments should be info usefull to others, not to your ego. Give the split rather than say 599 or “yesssssssssss first call !”
The cluster is not a parrot
Once you have read the info on the cluster, you are lucky to make the contact yourself. There is no need to spot it again, as the whole world already knows that DX is there, and avoid repeats. How many times do we see the same spot repeated 20 times in 5 minutes ?
Many info are wrong in terms of callsign. 6W1XX spotted as BW1XX. The cluster is not a bible, and you should
LISTEN for the call on the air rather than fully trust the cluster info
A Dxpedition is not necessarily connected to the cluster network
You hear that rare IOTA expedition to P29 on 15m. You need P29 on 17m. Ask them through the cluster to
QSY to that band is unlikely to reach them. On a desert island, the expedition is not connected to the web, and they will not see your request. Not only the expedition did not go there just for you, but you will be seen as an selfish by the whole world-wide community.
The cluster is not meant for complaints, at least in terms of spots. Don’t criticize an dxpedition for not beeing on a band you need it on, just listen and they will be there sooner or later. You are not there yourself, and you cannot imagine what circumstances the guys are facing on their side.
The cluster is not meant for you to spot yourself
Don’t spot yourself as calling on a certain frequency, even if you have a sked. If you are on a IOTA, someone ill spot you quickly after you show up on the air, your ego will have to bear with waiting for the spot. Imagine every active station spotting themselves : the cluster would be full of useless info.
Don’t spot your next door neighbour, even to say he is calling DX. You hear him Cqing DX, but this does not
mean he is heard on the other side. Let some DX spot him instead.
Not everybody is connected to his local cluster
It is useless to thank the guy you just worked when you spot him. Hopefully you will have thanked him over the air, and he is not necessarily connected to read your thanks. Send him a QSL better !
The common “Tnx new one” may be nice, but who cares ? Imagine everyone spotting all their new ones…
The cluster is not a copy of your log
It is not worth informing the whole world you just worked a common DL on 20m, or a SP on PSK on 17m.
Even a beginner can find this kind of stations by just switching on his rig. It is a wrong excuse to say a beginner needs everything : a beginner must also learn to turn his VFO knob…
If there is no DX today, there is no need to feed the cluster with useless local info.
What to spot, what not to spot
Common sense should dictate your choices. The desire to help a beginner is a wrong excuse to spot “anything”.
There is no general rule or a list of what to spot. What is rare and of interest is not limited to what you need. Nevertheless.. To work a Ukrainian on 15m PSK is not a fabulous achievement of which the whole world must be informed. To work Florida on 17m CW may be nice, but should the world know ? Any station has a least one reference for a local award (DOK for DL, zip code for Spain, department for F, county for USA, etc). This does not mean you must spot everything you hear. What are these awards worth if you just need to watch your screen to get them ? A special prefix can be spotted, without exagerating in terms of repeats. A semi rare US state can be spotted (like Wyoming or the Dakotas) but who needs a spot from New York ?
As a conclusion, I would like to say this is only a point of view. The cluster system is a fabulous technical achievement, but do not forget that everything that goes through it travels the entire world in a matter of seconds. And it is better to find the DX before it is spotted : less competitors, easier to get though… so get to your VFOs !
F6EXV
Eduardo EA3NY
www.ea3ny.com
www.siemprenavegando.com
www.internetyvoz.com
