Liberar Transmision...
Liberar Transmision bandae WARZ en TS 930
EA4AS
#23655  - 13 julio, 2015 20:18
Hola a todos , desearia conocer el metodo de liberar en Tx, las bandas WARZ en el Kenwood TS-930; Saludos Y gracias
EA7AH
#279350  - 14 julio, 2015 11:06
1.
Disconnect the power and antenna.
2.
Remove the top and bottom covers of the radio.
3.
Remove the four screws from the speaker mounting and the top panel assembly.
4.
Swing the assembly away and unplug the Red/Black battery leads from the digital unit X54-168-00.
5.
Solder small ga. wires between the following locations.
IC21 pin 12 to IC11 pin 9
IC22 pin 12 to IC12 pin 9
IC23 pin 12 to IC24 pin 8
Tack sodering on the component side of the board is O.K.
6.
Reassemble the radio
You should now be able to Transmit on the MARS/CAP frequencies.
EA4AS
#279351  - 20 julio, 2015 23:49
Muchas gracias, no lo habia encontrado, saludos Juan
