Kenwood TS-990
Kenwood TS-990
EA6Y
 EA6Y
#21762  - 6 octubre, 2012 13:42
TS-990S HF/50MHz Dual receiver & Dual TFT display Available Winter 2012. – Now will open a new chapter in Kenwood history - The Kenwood TS-990S is a new flagship transceiver – On the TS-990S one of the noteworthy planning policies is improvement of fundamental receive performances and a drastic modification to the external appearance. – !! See the first internal views, the Front-end block diagam and more – download the PDF 1st Leaflet ENG. below.
Receiver performance is one of the key indicators that is used to evaluate a transceiver. And, above all, the capability to protect against interference from adjacent signals close to the target signal is of the utmost importance. On the TS-990S three RF filter systems protect the early stages of the main receiver from overload caused by strong out-of band signals (RF BPF – Pre Selector combine and five Roofing Filters after the 1st mix) – The Preselector is a variable bandpass filter that can be inserted or not after a series of fixed bandpass filters.
Main Receiver: Full down conversion (IF: 8.248MHz) – Newly-developed mixer IP3: +40dBm class – Roofing filters (270Hz/500Hz/2.7kHz/6kHz/15kHz) – Sub Receiver: Up/Down conversion (similar to TS-590 system) – Simultaneous dual receive. – Source Kenwood-electronics Co.Uk Leaflet ENG – Download here (link to ML&S Uk)
Mode: SSB/CW/FSK/PSK/AM/FM – TX power: 5-200W (AM 50W) – 2xVRF150 FET final working at 50V – Rear panel: Antenna connector x 4, RX IN/OUT connector, key jack, ACC2 connector, optical IN/OUT, keypad jack, USB connector (+ USB x 2 Front panel) display connector, LAN connector, REF I/O 10MHz, etc.
[Note] – Pricing and final detailed specifications are yet fixed, please see the official JVCKenwood sources - All specifications are subject to change without notice – All trademarks belong to their respective holders - This device has not been approved by the appropriate authorities in each country etc.
:( muy bonito pero nada de nuevo...
LOCATION, LOCATION, LOCATION,
´73 de EA6Y
