IC-7300, the Most Powerful Compact HF/50MHz Transceiver
with High-Quality Real-Time Spectrum Scope and RF Direct Sampling System
Icom Inc. will begin shipping the IC-7300 HF/50MHz transceiver within 40 days from this release date*.
This new model has a high-performance real-time spectrum scope and employs a new RF direct sampling system. The IC-7300’s real-time spectrum scope provides top-level performance in resolution, sweep speed and dynamic range. While listening to received audio, the operator can check the real-time spectrum scope and quickly move to the intended signal. The combination of the real-time spectrum scope and waterfall function improves the quality and efficiency of HF operation.
The new RF direct sampling system employed to the IC-7300 realizes class leading RMDR and Phase Noise characteristics. In addition, the IC-7300 has a large touch screen color TFT LCD, convenient multi-function dial knob, automatic antenna tuner, voice recorder function and more. The IC-7300 is a revolutionary compact radio that will excite HF operators from beginners to experts.
* For Japan domestic market, will be released in other countries at a later date.
Main Features
• High-Performance Real-Time Spectrum Scope
• RF Direct Sampling System
• Class Leading RMDR and Phase Noise Characteristics
• Large Touch Screen Color TFT LCD
• Built-in Automatic Antenna Tuner
