AMPLIFICADORES HF C...
AMPLIFICADORES HF CHINOS
EA2AAJ
#168729  - 12 noviembre, 2011 17:44
No veo razon para que URE se dedique a comprar aparatos, antenas y otros caprichos y probarlos; si pagaramos 1500 € por año y socio tal ve se podrian plantear otras opciones.
Un abzo.
Miguel.
EA2AAJ (Zaragoza) IN91nq
EA2AAJ@gmail.com
EA2AAJ@ure.es
EA7DLD
#168730  - 13 noviembre, 2011 13:40
yo prefiero esperar a ver si los chinos copian este:
http://www.dc9dz.de/en/index.html
Data of Tsunami RF Linear Amplifier
RF linear amplifier covers all amateur bands from 1.8 MHz to 29.7 MHz
3 Power supply transformers
Plate voltage at full output power
Screen voltage, stabilized
Grid voltage, regulated
Filament
10000 VA , 1200 VA & 1 VA
6500 V
1000 V
- 245 V +/- 20 V
7.5 V / 75 A
Input SWR in the middle of band
160 m – 30 m
20 m
15 m
12 m – 10 m
1 : 1.25
1 : 1.35
1 : 1.45
1 : 1.65
Gain (1.8 – 29.7 MHz)
Neutralization 1.8 – 29.7 MHz:
Isolation between input and output
20 – 21.6 dB
45 – 50 dB
Output with:
5 W Input:
10 W Input:
20 W Input:
30 W Input:
40 W Input:
50 W Input:
60 W Input:
70 W Input:
80 W Input:
90 W Input:
100 W Input:
0.75 KW
1.5 KW
2.9 KW
4.4 KW
5.8 KW
7.3 KW
8.7 KW
10.1 KW
11.6 KW
13.1 KW
14.6 KW
Input: SSB Signal:
33% of full 1 KHz Modulation
on / off Ratio 1:2, Interruptions: 20 Hz
Equipment:
R&S 20 KW Dummy Load
Bird Power Meter
Measurements
on 7.1 MHz
Harmonic output
Intermodulation distortion
Tube
50 dB below rated output
35 dB or better
Eimac 4CX10000D
Input network:
1:9 Transformation, 450 Ohm, 500 W HF Resistor, Tube Input Reactance Compensation & Neutralization for each band, 11 pol. bandswitch, two levels
Output network:
Roller inductor 20 uH & 2 motorized vacuum capacitors 500 pF / 15 KV and 2.5 nF / 5 KV
Metering: Display of all parameters – no switching
Computer control of all switching functions: No relays switching under power conditions
Soft start inrush, 10 sec delay time for full power
Turbine blower with 2 speeds
Well regulated screen and grid supply for +ve and -ve currents as well as current limiting to protect the tube and minimize the IMD. It's impossible to override the screen and grid dissipation at any working conditions
The finish is of high quality black eloxial aluminia
Dimension
Weight
Accessory (for Icom-Transceivers)
Price
575w x 310h x 585d mm
132 Kg
Module for optimized tuning (1 KHz; on / off: 1:2, 20 Hz)
Very low: About 1.7 €/W (1.7 €/W x 14.6 KW = 24.8 K€)
EA3GEG
#169159  - 13 noviembre, 2011 17:57
Filament
6500 V
1000 V
- 245 V +/- 20 V
7.5 V / 75 A
160 m – 30 m
20 m
15 m
12 m – 10 m
1 : 1.25
1 : 1.35
1 : 1.45
1 : 1.65
20 – 21.6 dB
45 – 50 dB
Output with:
5 W Input:
10 W Input:
20 W Input:
30 W Input:
40 W Input:
50 W Input:
60 W Input:
70 W Input:
80 W Input:
90 W Input:
100 W Input:
0.75 KW
1.5 KW
2.9 KW
4.4 KW
5.8 KW
7.3 KW
8.7 KW
10.1 KW
11.6 KW
13.1 KW
14.6 KW
Input: SSB Signal:
Equipment:
Bird Power Meter
Measurements
on 7.1 MHz
Harmonic output
Tube
35 dB or better
Eimac 4CX10000D
Input network:
Output network:
Dimension
Weight
Price
132 Kg
Para el proximo WW SSB tendre uno de estos :P :P :P
EA5BCQ
#169175  - 14 noviembre, 2011 03:19
Como en todo, hay copias, copias malas, originales y originales malos.
Para los detractores sin mas razon que el "por que si", os asombrarias de ver no solo amplificadores sino antenas, etc, etc Made in China y el rendimiento que ofrecen.
Saludos y Sed buenos!! :)
Jose
EB5BBM/BA7IP
Dongguan City
Guangdon Province
P.R. of China
Jose M. Molero EA5BCQ / CT7AOE
Ex EB5BBM - 3W9CQ - XX9TBM
,, Me preocupaba por el color de mis zapatos, hasta que conocí a un hombre que no tenia pies ,,
EA1S
 EA1S
#169225  - 14 noviembre, 2011 06:59
Hola Jose, espero que todo este bien por alla. Tu que andas continuamente por aquellas tierras nos podias informar mejor de como conseguir y traer un "bicho" de esos, de cuanto puede constar etc etc
🅴🅰1🆂▁ ▂ ▃ ▄ +𝟲𝟬𝗱𝗕
𝗠𝗮𝗿𝗰𝗼 𝗘𝗔𝟭𝗦 - 𝗘𝗔𝟭𝗦𝗕 📡
EC1CT
#168731  - 14 noviembre, 2011 12:54
Dadle un vistazo a este video y fotos:
>> This is our new 2000W auto tune amplifer :
>> This is our manual 2000W amplifer in Brazil last weekend :
Yo no lo veo claro, pero por si alguno se anima...73s
EC1CT // KD0IGJ Fernando
ec1ct@esbesaya.com
EA5ELF
#169265  - 14 noviembre, 2011 14:14
Pus yo lo que no veo claro con el de valvulas es su precio, pero los transistorizados yo si me atrevo, es mas voy a investigar para traer un CG-HF 1200.
EA5BCQ
#169231  - 18 noviembre, 2011 04:17
Hola Marco,
Con retraso leo tu post. Gracias x el QSO nuevamente desde aqui mi pais "adoptivo".
Hoy he conseguido hablar con BG6CG fabricante de los HF CG1200 y 600 que se mencionan por aqui. El precio es el que aparece de 8.880 RMB y 5.800 RMB respectivamente.
Habria que entregar una señal y el tiempo de fabricacion es de 2 semanas.Él no exporta con lo cual c/u se tendria que buscar el modo de traerlo. El coste de enviarlo a cualquier lugar en China es de 200 RMB, y el peso de ambos dos una vez embalado es de 40kgrs. El de 600w no tiene ventilador.
En cuanto a como se puede traer, las opciones mas viables son pagar un exceso de equipaje si no consigues que cuele sin que se den cuenta en cabina y traerlo en equipaje de mano, a tal efecto yo me desharia del embalaje especial para evitar peso y dejarlo en 26kgrs. Lo traes tú en mano y por tanto ya te guardaras de golpearlo.
La otra opcion es la misma con el embalaje especial pero que viaje en bodega y aqui si pagarias si o si el extra coste por peso. Aun asi pienso que te resultaria rentable.
Aduanas chinas? Son jodidas pero permisibles. Por ley no puedo entrar mis equipos de HF, la ultima vez arriesgue y probé entrando y saliendo del pais (a Hong Kong) y sin problema, lo cual no quita que lo pueda haber.
Aduanas en EA? al menos en Madrid Barajas, no son minuciosos salvo que lleves un chino en la maleta y se le salga un pie :cheer:
Un abrazo Marco,
Jose
EB5BBM/BA7IP
EA1I
 EA1I
#169698  - 18 noviembre, 2011 07:43
Muchas gracias por la informacion de PRIMERISIMA MANO y que tengas una buena estancia:
8800 China - Renmimbi Yuan = 1,027.71322 € HF GC 1200
5800 China - Renmimbi Yuan = 677.35644 € HF GC 600
EA5BCQ
#169749  - 18 noviembre, 2011 08:38
Mis disculpas Virginio,
Olvidé indicar el cambio del yuan!
Muchas gracias y un atento saludo,
Jose
EB5BBM/BA7IP
EA1I
 EA1I
#169752  - 18 noviembre, 2011 11:33
¡¡¡¡¡POR DIOS, NADA QUE DISCULPAR!!!! Muchas gracias a ti.
Seria interesante saber si hay alguna posibilidad de que el coloega chino los envia el , pues ir a china a buscarlo es un poco complicado para la mayoria.
EA1S
 EA1S
#169699  - 18 noviembre, 2011 20:11
EB5BBM escribió:
Hola Marco,
Un abrazo Marco,
Jose
EB5BBM/BA7IP
Hola de nuevo Jose, gracias por toda la info que nos das.
Ya sabes que para mi siempre es un placer saludarte y mas con tantos KM por medio, buena estancia y mejor regreso, un abrazo
🅴🅰1🆂▁ ▂ ▃ ▄ +𝟲𝟬𝗱𝗕
EA7KP
#168732  - 23 noviembre, 2011 17:10
Hola!! acabo de leer la noticia de los Amplis CG y creo, según me han comentado,los que en EA comercializan algunos de sus productos,que éstos,NO se comercializarán en EU,al no poseer su certificado de impor/export en EU,a mi ya me gustan.....habrá que esperar,digo..
saludos.
Mitxel.EA7KP
Mitxel-EA7KP-
Vera-playa.IM97CF-ALMERIA-
ea7kp@hotmail.es
#170503  - 24 abril, 2012 15:03
Por si a alguien le interesa.
Conozco un colega chino (de fiar) que vende esos amplificadores de Hf chinos, nuevos claro.
Hay dos modelos, 2010DX manual y el 2011DX-A automático.
Los precios son; 3.000 USD el manual (unos 2.300 €) y 5.000 USD (unos 3.800 €) el automático, más portes.
Si a alguien le interesa alguno, le puede escribir (en inglés) a Hsu; hsu4qro@gmail.com
[img] [/img]
[img] [/img]
[img] [/img]
[img] [/img]
[img] [/img]
[img] [/img]
[img] [/img]
[img] [/img]
EA5BCQ
#187315  - 24 abril, 2012 19:36
Hola Maximo,
Calidad de los mismos probada por un servidor (adjunto foto aunque el "big boy" queda a un lado y se ve solo el canto)y te aseguro que van muy finos. Conozco al fabricante (eye ball QSO) y es una persona de fiar.
Muchas grcs por la info y fotografias.
73's
Jose
EB5BBM/BA7IP
