The 5th EPC PSK63 Q...
The 5th EPC PSK63 QSO Party 2010
EA5U
 EA5U
#12257  - 13 noviembre, 2010 19:20
European PSK Club has the honour to invite radio amateurs from all over the world to participate in the 5th EPC PSK63 QSO Party 2010. The objective of the competition is to establish as many contacts as possible between radio amateurs around the world by using the BPSK63 mode. Everybody can work everybody for QSO and multiplier credit. The contest will be held from 00:00 UTC to 24:00 UTC on Sunday, 21st November, 2010. The rules and other information can be found at our website. This is strictly BPSK63 contest, no other modes are allowed. The maximum output power is 100 watts. Recommended frequencies are: 160 meters (1.838 – 1.840 MHz), 80 meters (3.582 – 3.590 MHz), 40 meters (7.040 – 7.050 MHz), 20 meters (14.072 – 14.080 MHz), 15 meters (21.072 – 21.080 MHz), and 10 meters (28.072 – 28.080 MHz). Please note that since this year EPC members should send signal report plus 5-digit EPC membership number (example – 599 EPC00001). Please make sure that you don't separate «EPC» from the «Number», and you don't use any characters between. Please make sure that your EPC number consists of 5 digits! Other stations should send signal report plus QSO number, starting 001 (example – 599 001). You should send your log via E-mail: ut7fp@srars.org
All the very best and see you all in the 5th EPC PSK63 QSO Party 2010!
Using MixW in this Contest. The new set of files for the MixW data mode software makes your particiapation in the EPC PSK63 QSO Party most enjoyable. You can download this set of files at StatsEUEPC.zip.
After the deadline all logs will be published as UBN reports..
ea5u@ure.es
