ARRL International ...
ARRL International DX Contest 2009 SSB
EA1CJ
#3653  - 6 marzo, 2009 02:01
Bueno, pues otro grande para este finde, y no paramos. ¿Quien dijo crisis? :laugh:
Aqui el enlace a la web con las bases
Aqui las bases:
1. Object:
1. 1.1. W/VE amateurs work as many amateur stations in as many DXCC countries of the world as possible on 160, 80, 40, 20, 15, and 10 meter bands.
2. 1.2. Foreign amateurs (also including KH6, KL7, CY9, and CYØ) work as many W/VE stations in as many of the 48 contiguous states and provinces as possible.
2. Date and Contest Period:
1. 2.1. CW: Third full weekend in February (February 21-22, 2009).
2. 2.2. Phone: First full weekend in March (March 7-8, 2009).
3. 2.3. Contest Period: 48 hours each mode (separate contests). Starts 0000 UTC Saturday; ends 2400 UTC Sunday.
3. Entry Categories:
1. 3.1. Single Operator:
1. 3.1.1. All Band:
1. 3.1.1.1. QRP.
2. 3.1.1.2. Low Power.
3. 3.1.1.3. High Power.
2. 3.1 2. Single Band.
1. 3.1.2.1. A participant may submit only one single band entry. If contacts are made on other bands, the log file must clearly be marked as Single Band in the header of the Cabrillo file.
2. 3.1.2.2. The same callsign may not be used by a different operator(s) to generate additional single band entries.
2. 3.2. Single Operator Assisted.
3. 3.3. Multioperator:
1. 3.3.1. Single Transmitter.
2. 3.3.2. Two Transmitter.
3. 3.3.3. Multi-transmitter.
4. Contest Exchange:
1. 4.1. W/VE stations in the 48 contiguous United States and Canada (except in the islands of St Paul and Sable) send signal report and state or province.
2. 4.2. DX stations send signal report and power (number indicating approximate transmitter output power).
5. Scoring:
1. 5.1. QSO Points - W/VE stations count three points per DX QSO. DX stations count three points per W/VE QSO.
2. 5.2. Multiplier
1. 5.2.1. W/VE stations: Sum of DXCC entities (except US and Canada) worked per band.
2. 5.2.2. DX stations: Sum of US states (except KH6/KL7), District of Columbia (DC), and Canadian provinces/territories: NB (VE1, 9), NS (VE1), QC (VE2), ON (VE3), MB (VE4), SK (VE5), AB (VE6), BC (VE7), NWT (VE8), NF (VO1), LB (VO2), NU (VYØ), YT (VY1), PEI (VY2) worked per band (maximum of 63 per band).
3. 5.3. Final Score: QSO points X multipliers = final score.
6. Miscellaneous:
1. 6.1. Your call sign must indicate your DXCC station location (KH6XYZ/W1 in Maine, KG4/W1INF at Guantanamo Bay, etc).
2. 6.2. The same station may be worked only once per band: no cross-mode or repeater contacts.
3. 6.3. Aeronautical and maritime mobile stations outside the US and Canada may be worked by W/VE stations for QSO credit only.
4. 6.4. DXpedition scores may be included in the Medium and Unlimited club totals only.
5. 6.5. Participants are reminded they should be aware of the ARRL Band Plans ( http://www.arrl.org/FandES/field/regulations/bandplan.html).
7. Submission:
1. 7.1. Entries for the CW competition must be emailed or postmarked by 2359 UTC March 23, 2009.
2. 7.2. Entries for the Phone competition must be emailed or postmarked by 2359 UTC April 6, 2009.
3. 7.3. Electronic entries for the CW competition must be emailed to DXCW@arrl.org
4. 7.4. Electronic entries for the Phone competition must be emailed to DXPhone@arrl.org
5. 7.5. Submissions that are created electronically must be in the Cabrillo file format and must include the log file.
1. 7.5.1. Paper copies of electronic logs are not an acceptable substitute for the electronic Cabrillo format file. Paper logs that are entered into an electronic medium after the contest are considered electronic logs.
6. 7.6. Hand-written paper entries or diskettes should be marked on the envelope as either DX Phone or DX CW entries and mailed to: ARRL, 225 Main St, Newington, CT 06111.
1. 7.6.1. Entries for the CW and Phone portions of the competition are considered separate contests and must be submitted in separate emails or envelopes to the appropriate contest address.
7. 7.7. Submissions of Cabrillo files that are manually created (not created automatically by contest logging software) may be made using the web applet at www.b4h.net/cabforms
1. 7.7.1. Forms for all ARRL contests may be downloaded from the Contest Home Page at: http://www.arrl.org/contests
8. 7.8. Contest forms and rules may be requested from the ARRL by sending an SASE with 2 units of postage.
8. Awards:
1. 8.1. Plaques (if sponsored) will be awarded in the following categories for both the CW and Phone contests.
1. 8.1.1. Top W/VE scorer in each entry category; single operator-all band-QRP, single operator-all band-low power, single operator-all band-high power, single operator-single band (160-10 Meters), single operator assisted, multi-operator-single transmitter, multi-operator-two transmitter, multi-operator-multi-transmitter.
2. 8.1.2. Top scorer in the single operator-all band category worldwide and on each continent. In addition, worldwide leaders in the single operator-all band-QRP, single operator-all band-low power, single operator-single band, single-operator assisted, multioperator-single transmitter, multi-operator-two transmitter and multioperator multi-transmitter categories will receive plaques.
3. 8.1.3. Additional special plaques will be awarded as sponsored.
2. 8.2. Certificates will be awarded to:
1. 8.2.1. Top single operator-all band entries (QRP, low power, and high power) from each DXCC entity and ARRL/RAC Section.
2. 8.2.2. Top single-band entries in each ARRL/RAC section and each DXCC entity.
3. 8.2.3. Top single operator assisted entries in each ARRL/RAC section and each DXCC entity.
4. 8.2.4. Top multi-operator entries (single, two and multi-transmitter) in each DXCC entity, US call area and in Canada.
5. 8.2.5. DX entrants making more than 500 QSOs on either mode will receive certificates.
6. 8.2.6. Additional certificates will be awarded as appropriate.
9. Other:
1. 9.1. See "General Rules for All ARRL Contests" and "General Rules for ARRL Contests on bands below 30 MHz (HF)" on the ARRL Web at http://www.arrl.org/contests/forms/
2. 9.2. For information, contact contests@arrl.org or by phone (860) 594-0232.
EA1CJ
#62927  - 6 marzo, 2009 02:06
Aqui estan los records del concurso:
http://www.arrl.org/contests/results/intldx-rec.html
Aqui el articulo de la QST sobre el concurso del 2008.
http://www.arrl.org/contests/results/2008/dxph.pdf
EA2AF
#62932  - 6 marzo, 2009 23:08
Yo empezare esta noche, espero que caiga alguno que otro, y que funcione correctamente los equipos.
EC2ACC
Roberto
#62933  - 6 marzo, 2009 23:31
Os paso unos Mapas de USA
Mas grande pincha aqui
Mas Mapas en:
Mapa de Canada
EB2RA
#62926  - 7 marzo, 2009 10:35
Gracias por los mapas, muy aprovechables para varias cosas.
A ver si caen de una vez los 2 estados del W7 que me faltan.
Esta mañana primer escarceo en 40m, 31 QSOs max W6 en 20 minutejos, veremos por la tarde noche como se da.
#62928  - 7 marzo, 2009 17:36
Puntuación: Cada QSO con estaciones W/VE vale tres puntos.
Multiplicador: Cada estado USA (excepto KH6/KL7), el distrito de Columbia (DC)
y los provincias/territorios canadiense:
NB, (VE1, 9),
NS (VE1),
QC (VE2),
ON (VE3),
MB (VE4),
SK (VE5),
AB (VE6),
BC (VE7),
NT (VE8),
NF (VO1),
LB (VO2),
YT (VY1),
PEI (VY2)
cuentan como multiplicador por banda.
Máximo de multiplicadores por banda, 63.
Puntuación final: Es el resultado de multiplicar los puntos por la suma de multiplicadores de todas las bandas.
Mapas de Prefijos de Radioaficionados de Canada (Canada Prefix map ham)
Map from RAC (tnx!)
Mas mapas
http://www.ve5nn.ca/Ham%20Map%20of%20Canada.pdf
EA7Z
 EA7Z
#63083  - 9 marzo, 2009 17:17
Bueno, poco tiempo le puede dedicar al concurso. Esto de tener una niña de 4 meses como que no deja mucho tiempo para la radio. Las caquitas, el baño, los paseos, los biberones, etc. Pero así pude hacer el concurso en 20 metros con 510 contactos y 53 estados. Otro año será, je, je.
EB2RA
#62929  - 9 marzo, 2009 22:11
¿Y te parece poco 510 QSOs?
Madre, quien se hubiese acercado con mis modestos 90 QSOs y mis tres horitas de concurso casi me muero de envidia.
EA1CQ
#62930  - 10 marzo, 2009 10:45
Felicidades Salvador, por esos "escasos" resultados. Yo por mi parte el concurso lo hice monobanda 80m alta potencia. Quedando como sigue:
201 qso válidos 198 y con 34 estados
El equipamiento usado, algo más o menos sencillo:
TS-950SD + 500W y como antena HF6V pinchada en el jardín sin radiales.
Se escaparon varios QSO, por no tener una antena de recepción.
Nos vemos en el WPX y posíblemente otra vez monobanda 80m, más que nada por compaginar con la familia.
Un saludo desde Santander de David/EA1CQ
EA3BOX
#63363  - 11 marzo, 2009 21:44
:) Hola, los dos días la propa en 40 estuvo bastante bién y casi sin QRM, yo lo trabajé en monooperador monobanda en 40 Mts, el resultado fué:
680 Contactos, 46 Estados y 93840 Puntos.
73s, Joan EA3BOX. ;)
EA3BOX
#63521  - 11 marzo, 2009 23:29
EA3BOX escribió:
:) Hola, los dos días la propa en 40 estubo bastante bién y casi sin QRM, yo lo trabajé en monooperador monobanda en 40 Mts, el resultado fué:
EB2AM
#63533  - 15 marzo, 2009 23:54
Espero que pasarais un buen rato en el concurso.
Yo la verdad, participe en monobanda 20 metros como EE2W con la esperanza de probar a ver que tal rendía o funcionaba la nueva antena, ya que tras la "visita" del tifoncillo de marras el diciembre pasado, con las desastrosas consecuencias para mi Explorer14 ( me la partio por la mitad ), y tras poder montar "in extremis" la reluciente X7 ( haciendome "caquitas" los días posteriores por las rachas de viento ), pues eso que me subí al "txabolo".
Empece a probarla a ver si soplaba la flauta y no reventaba nada, termine de montar todo a las 3 de la tarde del sábado y empece un poco después.
Cual fue mi sorpresa que llamo y de primeras se me lanzan una docena de californianos, y ya se monto la marimorena.
Sin calentamiento y a lo loco.
Al final y todavía sin "pulir" el log ( alguno tendrá que desaparecer, y otros 2 que tengo que meter a mano por que no me permitía meter el indicativo )estos son + ó -
los resultados:
QSO´s: 1308
estados : 60 ( se me escaparon 3 de Canadá , NU-NWT y YT )
puntos: 235.440
P.D: Creo que para prueba no esta nada mal no???
Teniendo en cuenta que a sido mi primera vez solo con los yankees.....UFFFFFFFFF¡¡¡¡¡¡
JULEN EB2BXL ( EE2W )
