Actualización del C...
Actualización del Comite del CQWW
EA3CX
#16514  - 30 agosto, 2011 02:15
Información y cambios en las reglas para los Multi Op este año:
Dear fellow contesters,
Another CQ WW season is just over the horizon. This CQ WW Contest Committee
update is part of our continuing effort to keep you informed.
The new award program for assisted entrants continues to expand. Plaques
now exist for high power and low power assisted for the World, Europe and
the U.S.A. and certificates for all deserving assisted winners. An update to
the complete list of available plaques will be posted to cqww.com in the
near future.
In early October, the CQ WW CC will provide another informative Webinar.
Stay tuned for the exact time and date.
This CQ WW Contest Committee update deals three subjects:
1. Compliance with Rule III.10: Only one signal is allowed on a band at
any time.
2. What happens to your log after your submit it to cqww.com?
3. Paper logs
1. Beginning with the 2010 contest season, the CQ WW Contest Committee began
utilizing SDR technology enabling the entire CQ WW contest to be recorded.
We are grateful to several individuals for allowing us to utilize their
recordings. Our purpose was two-fold: To create a “live” archive of the CQ
WW contests and to check compliance with Rule III.10: “Only one signal is
allowed on a band at any time.” The purpose was to discover whether two
signals actually were on the SAME band at exactly the same time. You can
find the results of our studies within the CQ WW CW results and the expanded
result on the CQ magazine Web site.
For more than 40 years, multi-multi stations have utilized two or more
stations on a single band. Recently, the use of two transmitters on a single
band has been more broadly adopted by the MS and M2 categories as well.
Many stations utilize either a software or hardware lockout device to
prevent two simultaneous signals. *However, many do not.* It is almost a
certainty that unless you have a lockout device, you will violate Rule
III.10. *Starting with the 2011 contests we are requiring a station with
two transmitters on the same band to utilize a lockout device.* New Rule
III.12 addresses this issue, “When two or more transmitters are present on
a band, *either a software or hardware device MUST be used to prevent more
than one signal at any one time; *interlocking two or more transmitters on a
band with alternating CQs (soliciting contacts) is not allowed.”
The second part of rule III.12 concerns dueling CQs. This new rule simply
expands the already existing ban on dueling CQ’s in the multi-multi category
to any station with two or more transmitters on the same band. The main
purpose of this rule is to prevent, for example, 50 stations from taking up
100 different frequencies on already crowded contest bands.
You can find the full rules for the CQ WW at cqww.com under RULES or in the
September issue of CQ magazine.
2. What happens to your log after it received?
In summary:
A. A database is created from all submitted contacts.
B. The database is cleaned up to remove non-callsigns, etc.
C. The country file current to the contest weekend is utilized.
D. All logs are treated the same, i.e., the logs are analyzed using the
same country file and callsign database mentioned above.
E. The final results are produced.
Members of the CQ WW Contest Committee are all active contesters. Log
checking members do not interact or check their own category of entry.
3. The address has changed for paper logs. All paper logs should be sent
to: Paper Logs, Box 481, New Carlisle, OH 45344, USA. Please mark SSB or CW
on the envelope.
As always, feel free to contact us at questions at cqww.com.
Thanks and see you this fall in the CQ WW!
73,
CQ WW Contest Comittee
Por lo tanto, no se permite mas a los Multis tener 2 o mas estaciones llamando CQ en la misma banda, aunque solo emitan una señal a la vez, justo cuando estaba preparando la estación jajaja :laugh:
#160565  - 30 agosto, 2011 07:10
Siempre habia pensado que eso no se podia-debia hacer, hasta que hace 2 o 3 años "pillamos" a unos alemanes haciendolo.
Analizando la situacion llegue a la conclusion de que tecnicamente era posible evitar la transmision simultanea, y por tanto cumplir las bases escritas, pero implicaba una situacion extraña y una falta de respeto a los corresponsales, porque suponia desatender a quien contestaba un CQ mientras durase la transmision de la otra estacion. En la escucha de las 2 estaciones alemanas en la misma banda no note nada extraño, por lo que supongo que simplemente no respetaban la regla.
EA3NY
#160566  - 30 agosto, 2011 08:50
A mi que me perdonen, pero si estoy haciendo dos QSO´s en el mismo minuto y en diferentes bandas (con una sola señal en el aire) como puñetas el comite va a saber si estoy saliendo con dos señales o una???
Eduardo EA3NY
www.ea3ny.com
www.siemprenavegando.com
www.internetyvoz.com
#160588  - 30 agosto, 2011 09:12
Eduardo, lee lo que ha escrito Ariel que te lo explica.
EA4TX
#160589  - 30 agosto, 2011 11:57
Eduardo,
El comité te va a pillar de todas todas o bien por tu fichero cabrillo, pues lógicamente un multi/multi va a estar por sentido común con el CAT, o bien por el cabrillo de tus corresponsales.
Luego aunque una estación manipule su cabrillo (digamos que unos listos) para dejar únicamente una de las 2 frecuencias usadas y pensando que no les van a pillar, el log de los corresponsales tendrá rastros de las 2 frecuencias empleadas. Luego te pillan sin despeinarte y sin necesidad que usen un SDR o algún competidor conocedor de la nueva regla lo denuncie.
73's Pablo EA4TX
http://ea4tx.wordpress.com/
http://www.ea4tx.com/
EA2HA
#160648  - 30 agosto, 2011 15:16
EA2HA Humberto
#160718  - 30 agosto, 2011 23:53
Humberto, ni tu ni yo tenemos la culpa, asi que tranquilo que esos contactos nos cuentan.
EA3CX
#160760  - 31 agosto, 2011 01:26
Hola todos, aquí va traducido con ayuda de San Google para los compañeros que se le dificulta en Inglés:
Otra temporada CQ WW está en el horizonte. Esta actualización del Comité de Concursos CQ WW forma parte de nuestro continuo esfuerzo para mantenerle informado.
El nuevo programa de premios para los participantes “Assisted” sigue creciendo. Ahora existen Placas para alta y baja potencia asistida para el Mundo, Europa y los EE.UU. y certificados para todos los ganadores. Una actualización de la completa lista de Placas disponibles se publicará en cqww.com en un futuro próximo.
Esta actualización del Comité de Concurso CQ WW trata de tres temas:
1. Conformidad con el Artículo III.10: sólo una señal es permitida en una banda en cualquier momento.
2. ¿Qué sucede con su planilla después de enviarla a cqww.com?
3. Las planillas en papel
1. A partir de la temporada de concursos de 2010, el CC CQ WW comenzó
la utilización de la tecnología SDR que permite grabar todo el concurso CQ WW . Estamos muy agradecidos a varias personas por permitirnos utilizar sus grabaciones. Nuestro propósito era doble: para crear un archivo "en vivo" de los CQWW y para verificar el cumplimiento con el Artículo III.10: "Sólo una señal es permitida en una banda en cualquier momento".
El objetivo era descubrir si dos señales en realidad estaban en la MISMA banda al MISMO tiempo. Usted puede encontrar los resultados de nuestros estudios en los resultados del CQ WW CW y los resultados expandidos en el sitio web de la revista CQ.
Durante más de 40 años, las estaciones multi-multi han utilizado dos o más
estaciones en una sola banda. Recientemente, el uso de dos transmisores en una sola banda ha sido más ampliamente adoptado también en las categorías Multi Single y M2. Muchas estaciones utilizan ya sea un software o un dispositivo de hardware de bloqueo para evitar dos señales simultáneas. * Sin embargo, muchos no.* Es casi seguro de que a menos que tenga un dispositivo de bloqueo, se viola la Regla III.10. * A partir de los concursos de 2011 se requiere que una estación con dos transmisores en la misma banda utilice un dispositivo de bloqueo. La Nueva regla III.12 aborda esta cuestión: "Cuando dos o más transmisores están presentes en
una banda, debe ser usado un software o dispositivo de hardware para prevenir más de una señal en un momento dado; interconectar dos o más transmisores en una banda con CQs alternados (solicitando contactos) no está permitido. "
La segunda parte de la regla III.12 concierne los CQ dobles. Esta nueva regla sólo amplía la prohibición ya existente en la categoría multi-multi a cualquier estación con dos o más transmisores en la misma banda. El principal objetivo de esta norma es evitar que, por ejemplo, 50 estaciones tomen 100 frecuencias diferentes en las bandas ya llenas de estaciones.
Usted puede encontrar las reglas completas para el CQ WW en cqww.com bajo reglas o en la revista CQ de Septiembre.
2. ¿Qué sucede con su planilla después de haberla recibido?
En resumen:
A. Se crea una base de datos a partir de todos los contactos enviados.
B. La base de datos se limpia para eliminar no indicativos de llamada, etc
C. Se utiliza el archivo actual de países (country file) correspondiente al fin de semana de concurso.
D. Todas las planillas son tratadas igual, es decir, las planillas se analizan con el mismo archivo de países y la misma base de datos de indicativos mencionada anteriormente.
E. Se producen los resultados finales.
Los miembros del Comité de Concurso CQ WW son todos concursantes activos. Los miembros que comprueban planillas no interactúan ni comprueban su propia categoría de entrada.
3. La dirección ha cambiado para las planillas en papel. Todas deben ser enviados a: Paper Logs, Box 481, New Carlisle, OH 45344, EE.UU.. Por favor, marque SSB o CW en el sobre.
Como siempre, no dude en contactar con nosotros en: preguntas cqww.com.
Gracias y nos vemos este otoño en el CQ WW!
EA3CX
#160763  - 31 agosto, 2011 01:47
Lo que yo entiendo, que no se permite mas que una frecuencia llamando CQ (running) por banda, pero si puedes cazar otras estaciones (no tienen porque ser multiplicadores, solo que no sean duplicados)en la misma banda, con la única condición que no emitan las 2 estaciones simultaneamente.
Esto es para los MULTIOPERADOR y no afecta a los Mono operadores.
A lo que yo iba y por lo cual comencé el hilo es que tecnología vienen aplicando (según dicen desde hace mas de 40 años)para tener 2 estaciones (o mas) operando por cada banda!!!
En el CQWW CW del año pasado era muy evidente que P33W estaba llamando en 2 frecuencias por banda, si lo hicieron de forma que no hubiera mas de una señal al aire al mismo tiempo, no lo se, supongo que con esas grabaciones de SDR lo podrán comprobar...
Que lindos eran los concursos cuando no había tanta tecnología... creo que me estoy poniendo viejo...
EC1KR
#160764  - 31 agosto, 2011 10:58
P33W lo viene haciendo en varios Contest, siempre les escuchas llamando muy abajo y muy arriba de la banda.
Seria interesante saber que sistema de bloqueo existe actualmente para que no te permita sacar una señal nueva en el aire dentro de la misma banda, vamos que solo hagas TX desde la segunda radio cuando la Run ha parado de hacer su qso (lo que se hace desde el 2º vfo pero desde otra radio).
Saludos. B)
73 de Jesus EC1KR
EA2HA
#160761  - 31 agosto, 2011 16:05
EA2HA Humberto
EA2HA
#160573  - 31 agosto, 2011 16:29
EA2HA Humberto
EA3NY
#160811  - 31 agosto, 2011 22:21
El Win test te permite hacer eso, pero claro, yo siempre hablo de mono-op que es lo que yo he hecho......
No creo que sea muy complicado hacer algún sistema que te impida llamar al mismo tiempo en la misma banda.
En RTTY es bastante sencillo hacer 2 qso´s al mismo tiempo, bastante sencillo, SSB ya es más complicado y CW la leche. En realidad creo que es bastante más complicado tener dos señales simultáneas al mismo tiempo y en la misma banda, bastante más complicado.
Eduardo EA3NY
www.ea3ny.com
EC3A
 EC3A
#160932  - 1 septiembre, 2011 12:11
en el pasado RUSSIAN DX CONTEST ya han descalificado a algunas estaciones rusas por el motivo que estáis citando.
El uso de dos señales simultáneas en dos frecuencias diferentes en la misma banda hace muchos años que venia haciéndose por parte de algunas estaciones . Quienes hace años participamos en Multis con la estación de busqueda de multiplicadores a veces oíamos a Multis en running en dos frecuencias simultaneas pero era dificil de demostrar. Mas recientemente los que vamos aprendiendo a operar en SO2R también hemos ido constatando lo mismo. La evolución del software y de los equipos facilitando la detección de estas cosas. Y la aparición de la tecnología del SDR para la grabación del todo el espectro y posterior análisis de un contest facilita de demostración de dichas trampas y la descalificación de quien incumpla las bases.
De todos modos y si se respeta que no se simultanee la transmisión no me parece tan mal el que se pueda transmitir en dos frecuencias distintas en la mismas banda pues el operador u operador y equipo pueden si son capaces de obtener mayor rendimiento a su instalación. Otra cuestión a debatir es si es o no ético.
Aquí os adjunto el link para acceder a la WEB del Russian DX Contest donde podréis escuchar algunas grabaciones de las estaciones descalificadas :
RUDX Contest
Fernando EA3KU.
(socio 13494 - desde 1975)
